O128O032DWPP3N0000 Footprint
Hi all,
The O128O032DWPP3N0000 footprint is incorrect. For a PCB where the OLED flex is mounted on the underside of the PCB and the OLED on the top side, the pad mask and paste layers need changing to the bottom (the pads are currently on the bottom but the mask and paste for each pad are on the top).
Obviously this is an easy change, just pointing it out!
Thanks for the library, its great.
@h.shallcross
Thanks for pointing this out. I will dig into it and get that fixed as soon as possible.
Thank you,
Reid L.
