Wiha Tools have provided the public with officially designed tool holders for their products. The 3D printable files are available for free below and on the https://tlbx3d.com/ website. In support of this, Digikey has also provided an extended set of models.
The project notes are available by clicking below
Official Design Downloads
| Pliers | Screwdrivers & Pliers | T-Handles |
| Pliers.stl | Screwdrivers and pliers.stl | T-Handles.stl |
| Large Screwdrivers | Precision Screwdrivers | |
| Large Screwdrivers.stl | Precision screwdrivers.stl |
| 12 Piece Metric Nut Drivers | 9 Piece SAE Nut Drivers | Blank Tool Holder |
| 12 Piece Metric Nut Driver Holder.stl | 9 Piece Imp Nut Driver Holder.stl | Blank Tool Holder.3mf |
| Din Rail Mount A | Din Rail Mount B |
| Din Rail Adapter - Din Mount A.stl | Din Rail Adapter - Din Mount B.stl |
| End Cap A | Pegboard Adapter | End Cap B |
| EndCapA.stl | American Pegboard adapter.stl | EndCapB.stl |
These tool holders are based on metric measurements and because of this, they are not able to create a continuous strip on 1" spaced pegboard holes unless an adapter is used. That is why the adapter above is available.
This is an image of these tool holders in action on an actual tech station in our applications engineering department at Digikey. This set up is using a din rail with the adapters.
The Tools
These are the tools found in the holders above if you would like to set this up for yourself.
| MFR PART # | 33490 |
| DIGIKEY PART # | 431-1063-ND |
| MANUFACTURER | Wiha |
| DESCRIPTION | Hex Hex Key Set 6 Pieces |
| MFR PART # | 26187 |
| DIGIKEY PART # | 431-26187-ND |
| DESCRIPTION | Philips, Slotted Screwdriver Set |
| MFR PART # | 32093 |
| DIGIKEY PART # | 431-1066-ND |
| DESCRIPTION | Phillips, Slotted Screwdriver Set 10 Pieces |
| MFR PART # | 32987 |
| DIGIKEY PART # | 32987-ND |
| DESCRIPTION | PLIERS, CUTTERS INSULATED SET |
| MFR PART # | 38701 |
| DIGIKEY PART # | 431-1386-ND |
| DESCRIPTION | Handle, Bit Holding 1/4" Drive 5.83" (148.0mm) |
| MFR PART # | 76086 |
| DIGIKEY PART # | 431-2239-ND |
| DESCRIPTION | Hex Socket Nut Driver Set 12 Pieces |
| MFR PART # | 76085 |
| DIGIKEY PART # | 431-2238-ND |
| DESCRIPTION | Hex Socket Nut Driver Set 9 Pieces |
If you do decide to build a set up for yourself we would love to see an image posted below. Additionally, if you see a Wiha tool or tool set that you feel would benefit from a tool holder, feel free to add a suggestion and we will look into it!
