Dear Digikey,
I have bought some THS4021ID from your website, ref 296-7516-5-ND (https://www.digikey.com/en/products/detail/texas-instruments/THS4021ID/374211)
. However, there is no “dot” in the corner indicating pin number 1, only a line on the bottom (see picture). What is the correct orientation of this IC?
Thank you in advance,
best regards,
Thibault CAPELLE
I am checking into this for you. Will let you know as soon as I have an answer.
It is relatively common to use a line at the pin 1 end of the package instead of a dot.
There are three pin 1 indicators often used on IC packages:
- Notch in the middle of the pin 1 package end
- Marked line at the pin 1 package end
- Dot at pin 1 corner
Thank you for your answer, I feel stupid now
