OSRMALED replacement
This LED just went end of life GW CSHPM1.PM-LRLT-XX52-1
Can anyone validate if this recommendation is equivalent to the part number above? GW CSHPM1.PM-LSLU-XX52-1
The only thing I noticed is one is cool and the other is warm.
Greetings,
The two part numbers are substantially similar, with the discontinued model being a lower flux/efficacy bin range. Substituting the LSLU variant should result in similar or slightly greater brightness compared to the LRLT version.
