Hi @pcarff , that is very strange, i wonder what is causing the reset… As written i’m seeing this:
=> ums 0 mmc 0
UMS: LUN 0, dev mmc 0, hwpart 0, sector 0x0, count 0x720000
CTRL+C - Operation aborted
=> reset
resetting ...
U-Boot SPL 2021.04 (Dec 20 2021 - 15:07:13 -0600)
Trying to boot from MMC1
U-Boot 2021.04 (Dec 20 2021 - 15:07:13 -0600)
CPU: Freescale i.MX7D rev1.2 1000 MHz (running at 792 MHz)
CPU: Commercial temperature grade (0C to 95C) at 49C
Reset cause: WDOG1
Model: TechNexion PICO-IMX7D Board and PI baseboard
Board: i.MX7D PICOSOM
I2C: ready
DRAM: 512 MiB
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
MMC: FSL_SDHC: 2, FSL_SDHC: 1, FSL_SDHC: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@30be0000
Hit any key to stop autoboot: 0
Saving Environment to MMC... Writing to MMC(0)... OK
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
194 bytes read in 2 ms (94.7 KiB/s)
1: Linux 5.10.83-armv7-lpae-x58
Retrieving file: /boot/vmlinuz-5.10.83-armv7-lpae-x58
11629056 bytes read in 259 ms (42.8 MiB/s)
append: root=/dev/mmcblk2p1 ro rootfstype=ext4 rootwait quiet
Retrieving file: /boot/dtbs/5.10.83-armv7-lpae-x58/imx7d-pico-pi.dtb
49000 bytes read in 6 ms (7.8 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 83000000, end 8300ef67
Starting kernel ...
[ 0.093733] debugfs: Directory 'dummy-iomuxc-gpr@30340000' with parent 'regmap' already present!
[ 1.731865] debugfs: Directory 'dummy-reset-controller@30390000' with parent 'regmap' already present!
[ 1.854703] CPUidle arm: CPU 0 failed to init idle CPU ops
[ 2.695908] systemd[1]: System cannot boot: Missing /etc/machine-id and /etc is mounted read-only.
[ 2.705133] systemd[1]: Booting up is supported only when:
[ 2.710738] systemd[1]: 1) /etc/machine-id exists and is populated.
[ 2.717086] systemd[1]: 2) /etc/machine-id exists and is empty.
[ 2.723066] systemd[1]: 3) /etc/machine-id is missing and /etc is writable.
Debian GNU/Linux 10 arm ttymxc4
default username:password is [debian:temppwd]
arm login: [ 32.924240] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
debian
Password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
debian@arm:~$ uname -r
debian@arm:~$ sudo ifconfig -a
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for debian:
can0: flags=128<NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 60
can1: flags=128<NOARP> mtu 16
device interrupt 61
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
ether 00:1f:7b:86:60:19 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 88 bytes 6988 (6.8 KiB)
TX packets 88 bytes 6988 (6.8 KiB)
debian@arm:~$
Edit, just updated the guide, to u-boot 2021.10, Kernel v5.15.x, and Debian 11.x… Everything still works…
=> ums 0 mmc 0
=> reset
resetting ...
U-Boot SPL 2021.10 (Dec 20 2021 - 15:37:22 -0600)
U-Boot 2021.10 (Dec 20 2021 - 15:37:22 -0600)
CPU: Commercial temperature grade (0C to 95C) at 51C
Reset cause: WDOG1
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 3, FSL_SDHC: 1, FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
194 bytes read in 3 ms (62.5 KiB/s)
1: Linux 5.15.10-armv7-lpae-x15
Retrieving file: /boot/vmlinuz-5.15.10-armv7-lpae-x15
12116480 bytes read in 270 ms (42.8 MiB/s)
Retrieving file: /boot/dtbs/5.15.10-armv7-lpae-x15/imx7d-pico-pi.dtb
49781 bytes read in 6 ms (7.9 MiB/s)
Kernel image @ 0x80800000 [ 0x000000 - 0xb8e200 ]
Using Device Tree in place at 83000000, end 8300f274
Starting kernel ...
[ 0.071618] debugfs: Directory 'dummy-iomuxc-gpr@30340000' with parent 'regmap' already present!
[ 1.733232] debugfs: Directory 'dummy-reset-controller@30390000' with parent 'regmap' already present!
[ 1.854932] CPUidle arm: CPU 0 failed to init idle CPU ops
Debian GNU/Linux 11 arm ttymxc4
arm login: debian
Password:
debian@arm:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk2 179:0 0 3.6G 0 disk
└─mmcblk2p1 179:1 0 3.6G 0 part /
mmcblk2boot0 179:256 0 2M 1 disk
mmcblk2boot1 179:512 0 2M 1 disk
device interrupt 60
device interrupt 61
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
RX packets 15 bytes 1805 (1.7 KiB)
TX packets 15 bytes 1805 (1.7 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 8a:2f:a5:89:07:ed txqueuelen 1000 (Ethernet)
debian@arm:~$
Regards,
