Polamco Part Number: PE93-10.0-N availability
We are trying to source the following Polamco part from TE Connectivity:
Related TE Reference: AAD2393-00
Required Quantity: 138 meters
This is a make-to-order item (not normally stocked).
Please note the suffix is critical:
“-T” = tinned copper braid
“-N” = nickel-plated copper braid (this is the version required)
Could you please confirm whether DigiKey can support this part, and advise MOQ, lead time, and pricing?
Hello rparis, unfortunately the PE93-10.0-N does not go into our system so we do not carry it, we only have the PE93-10.0-T. The only way we can source the PE93-10.0-N for you is if you get a quote/referral from the MFG, which can be sent to techs@digikey.com and we will process this request through our non-catalog dept.
