I can’t find “Primitives” in custom symbol. It was very useful for quick drawing.
Was it removed after the update? Can it be restored?
Thank you for your question. We are working on this for you.
It looks like Primitives is not missing and has been replaced with the “Build a Symbol”
Thank you for feedback. I already noticed that “Build a Symbol” function but it is more advanced and time consuming if i need to create simple object with ability to add and remove pin during work.
Is it possibility to restore “primitives” in custom symbol?
Checking on this for you.
@Wojtas91 - Thank you for your inquiry. Unfortunately, the support for Symbol Primitives has been deprecated in Scheme-it.
If you are looking for a simple way to manipulate pins on an object while working within the schematic you could try utilizing the Port or Node options located under Schematic Symbols > Ports.
The limitation of this method is that the pins are not “attached” to the object or shape. In order to do this, you would need to utilize the Symbol Builder to build, save, and manage custom symbols.
