Hi Tech team,
I’m looking for the printer which can printing the label from Hellermann Tyton P/N: TAG22T3-100B as I couldn’t found the information from the datasheet or website. So, I need your advise on the printer model.
Hi Tech team,
Hi Erik,
Here are listed some of their own printer products.
Cheers,
heke, AsamaLab
Which material should I refer from? As I do not see any with TAG22T3
Hi Erik,
TAG22T3 datasheets states:
HellermannTyton thermal transfer labels work in any thermal transfer
printer so that the user always has options to get labels printed without
being locked into a single vendor
So you can choose any printer from them or choose from e.g. Digi-key’s selection (that accepts 85mm wide liner).
For example:
However, to be sure, it may be a good idea to ask the supplier’s recommendation.
Cheers.
heke
