A question that comes up often is I am looking for a through hole version of a surface mount part for prototyping. Unfortunately more and more often we are finding that it is hard to find part options in a through hole version for prototyping your project on a breadboard. The solution to this issue is often an adapter or breakout board for your surface mount components so you can insert them into bread board.
Types
How to find the Breakout Board
.Go to the Adapter, Breakout Boards Section Here
Select the package under the filter “Package Accepted”
Example of packages listed
BGA
CSP
CSP,TCSP
CSP,TCSP,UCSP
CSP,UCSP
DFN
DFN, MLP
FPC/FPC CONNECTOR
HSOP
LCC, JLCC, PLCC
LGA
LLP
LQFP
LQFP, MQFP, TQFP
LQFP, PQFP
LQFP, PQFP, TQFP, VQFP
LQFP, TQFP
LQFP, TQFP, VQFP
LSOP
MICROMAX, MSOP, SOT-552, TSSOP, USOP
MICROSMD, BGA
MINISOIC
MINISOIC EP
MLP, MLF
MQFP
MSOP
MSOP, SC70, SOIC, SOT23, SOT23, SOT563, TSSOP
MSOP, SOIC, SSOP
MSOP, SOIC, TSSOP
MSOP, TSSOP
MSOP, uMAX, uSOP
PLCC
POS
PowerSOIC
PowerSOIC, PSOP, HSOP
PowerSSO
PQFP
PQFP, QFP, RQFP
PQFP, TQFP
PSOP
PSOP, SSOP, TSOP
QFN
QFN, THIN
QFN, QFN
QFN, QFP
QFP
QSOP
RQFP, QFP
SC-59, SC-74, SOT23, SOT-25
SC-70, SC-82, SOT-343
SC-70, SC-88, SOT-363
SC-70-SC88A, SOT323, SOT353
SC-70, SOT-323
SC-73, SOT-223
SC-74, SOT-23, SOT-26, SOT-59, SOT-457, TSOP, TSOT
SC-75-6, SC-89, SOT-66, SOT-563, SOT-666
SC-8, SC-70, US8
SM-8, SOT-228
SOIC
SOIC, SOP
SOIC, SSOP
SOIC, SSOP, 0805, DO-323, SOT23, XTAL, QFP
SOIC, TSSOP
SOJ
SOP
SOP, SSOP
SOT
SOT-143
SOT-223
SOT-223, SC-63
SOT-23
SOT-23, SC-59
SOT-23, SC-59, SC-74A
SOT-23, SOT-28
SOT-23, SOR-89, SOT-223, TO-252
SOT-23, TO-236
SOT-23, TSOT
SOT-523F
SOT-553, SOT-665
SOT-563F
SOT-666
SOT886
SOT-89
SOT-963
SSOP
SSOP, TSSOP
SuperSOT
SuperSOT, TSOT
TO-252 (DPAK)
TO-263
TO-263 (DDPAK/D3PAK)
TQFP
TQFP, VQFP
TSOC
TSOP
TSSOP
TVSOP
VSOP
VSSOP
0402
0603
0805
1206
1206, Mini MELF
1210
1813
5050 LED
Applicable Part numbers
1568-1098-ND 1568-1123-ND PA0001-ND PA0034-ND 309-1121-ND 309-1122-ND A744-ND A745-ND A747-ND A724-ND A751-ND A799AR-ND A720-ND A320-ND A756-ND 33206CA-ND 33006CA-ND PCB3007-1-ND PCB3005A1-ND PA0087-ND PA0085-ND PA0086-ND PA0083-ND 1528-1071-ND PCB3008-1-ND PCB3001-1-ND PA0042-ND PA0089-ND PA0032-ND PA0180-ND PA0026-ND PA0002-ND PA0003-ND PA0004-ND FPC050P010-ND PA0033-ND FPC100P010-ND 9082CA-ND 1528-1067-ND A883AR-ND PA0027-ND PA0006-ND PA0005-ND PCB3006-1-ND A886AR-ND A885AR-ND A887AR-ND 1528-1066-ND PA0008-ND PA0035-ND IPC0060-ND FPC100P020-ND PA0061-ND DC0603T-10X-ND DC0805T-10X-ND DC1206T-10X-ND 1528-1072-ND 1528-1069-ND 309-1120-ND PA0036-ND PA0193-ND PA0009-ND PA0063-ND IPC0051-ND IPC0067-ND PA0037-ND IPC0077-ND A891AR-ND IPC0079-ND A892AR-ND A755-ND A725-ND A726-ND IPC0014-ND FPC030P045-ND 309-1110-ND A321-ND A824AR-ND 309-1125-ND A849AR-ND 309-1097-ND A171-ND PA0096-ND A748-ND A753-ND A758-ND 33003CA-ND 6103CA-ND 6303CA-ND 33205CA-ND 1528-1085-ND 33115CA-ND 6908CA-ND 6008CA-ND 33108CA-ND 33208CA-ND 33008CA-ND 33608CA-ND 33113CA-ND 33508CA-ND 33708CA-ND 6010CA-ND 1528-1096-ND 33117CA-ND 33010CA-ND 6012CA-ND 1528-1068-ND 1528-1088-ND 9163CA-ND 1528-1065-ND 9210CA-ND 6415CA-ND 16-350000-11-RC-P-ND A880AR-ND 1738-1002-ND LS0003-ND LS0002-ND 1738-1003-ND PA0088-ND A879AR-ND 1568-1093-ND 1568-1484-ND PA0049-ND PA0168-ND A881AR-ND PA0182-ND 1568-1091-ND 1568-1092-ND 1568-1095-ND 1568-1096-ND PA0017-ND PA0184-ND PA0007-ND PA0101-ND PA0028-ND PA0060-ND PA0185-ND FPC050P020-ND DR050D254P020-ND PA0018-ND DC1210T-10X-ND DC0805S-10X-ND DC0402T-10X-ND DC0603S-10X-ND 309-1099-ND 309-1128-ND 309-1100-ND PA0019-ND PA0186-ND IPC0088-ND A888AR-ND A889AR-ND PA0194-ND PA0011-ND PA0030-ND FPC050P030-ND IPC0036-ND PA0064-ND IPC0078-ND PA0103-ND IPC0070-ND PA0039-ND FPC050P040-ND FPC030P025-ND IPC0072-ND 309-1112-ND PA0040-ND PA0065-ND PA0091-ND IPC0006-ND FPC050P050-ND IPC0049-ND 309-1129-ND PA0208-ND PA0067-ND IPC0012-ND A322-ND DR050D254P060-ND PA0041-ND PA0210-ND 309-1124-ND PA0093-ND IPC0020-ND PA0094-ND PA0240-ND PA0188-ND PA0109-ND PA0107SOCKET-ND 33223CA-ND 33143CA-ND 33343CA-ND 6004CA-ND 33105CA-ND 33505CA-ND 6405CA-ND 33405CA-ND 6106CA-ND 6006CA-ND 33406CA-ND 33623CA-ND 6808CA-ND 6109CA-ND 1597-1263-ND 1597-1262-ND 33213CA-ND A884AR-ND 1528-1070-ND 1528-1453-ND 1528-1389-ND 1528-1064-ND 9164CA-ND 9165CA-ND A896AR-ND A750-ND A727-ND 309-1123-ND 1597-1260-ND A800AR-ND A839AR-ND 309-1115-ND A731-ND A734-ND 438-1014-ND 309-1119-ND 33305CA-ND 33106CA-ND 33306CA-ND 6007CA-ND 33518CA-ND 6510CA-ND 33110CA-ND 33310CA-ND 33410CA-ND 6112CA-ND 6816CA-ND 6916CA-ND 6115CA-ND 6520CA-ND 9301CA-ND A869AR-ND A730-ND A746-ND 438-1032-ND 438-1054-ND 438-1017-ND 438-1016-ND 438-1058-ND 438-1057-ND PA0090-ND PA0016-ND DC1210S-10X-ND DC1206S-10X-ND DR050D254P040-ND PA0107-ND PA0110-ND PA0189-ND PA0106SOCKET-ND PA0214SOCKET-ND PA0223-ND PA0219SOCKET-ND 438-1015-ND BGA0019-ND BGA0023-ND 1568-1094-ND 296-35646-ND BGA0010-ND 309-1098-ND A323-ND A882AR-ND PA0062-ND DC1813T-10X-ND A890AR-ND PA0071-ND 309-1109-ND PA-TQFP-BB001-1-ND PA0113-ND PA0174-ND IPC0142-ND PA0183-ND IPC0083-ND IPC0076-ND IPC0061-ND PA0020-ND FPC100P030-ND IPC0096-ND PA0195-ND A894AR-ND A895AR-ND 309-1117-ND PA0092-ND A865AR-ND A873AR-ND IPC0107-ND IPC0048-ND 309-1111-ND A875AR-ND 309-1116-ND 1597-1261-ND 309-1130-ND 309-1108-ND 309-1107-ND A823AR-ND 309-1106-ND 309-1118-ND 309-1105-ND 6306CA-ND 6309CA-ND 33308CA-ND 6410CA-ND 9302CA-ND A893AR-ND A736-ND A874AR-ND 309-1103-ND 438-1031-ND DC0402S-10X-ND IPC0103-ND PA0190-ND PA0105SOCKET-ND BOB-13005-ND PA0082-ND PA0179-ND PA0048-ND PA0173-ND PA0084-ND PA0175-ND PA0177-ND PA0152-ND PA0172-ND PA0043-ND PA0044-ND PA0015-ND PA0170-ND PA0169-ND PA0058-ND PA0225-ND PA0133-ND PA0050-ND FPC040P010-ND IPC0148-ND IPC0052-ND PA0181-ND PA0057-ND FPC080P010-ND PA0243-ND FPC125P010-ND PA0045-ND PA0132-ND PA0153-ND PA0075-ND PA0178-ND IPC0087-ND IPC0056-ND PA0191-ND PA0171-ND IPC0054-ND PA0244-ND PA0154-ND IPC0053-ND PA0059-ND PA0051-ND PA0098-ND PA0134-ND PA0076-ND PA0046-ND IPC0130-ND IPC0119-ND IPC0129-ND 08-350000-10-P-ND 08-350000-11-RC-P-ND IPC0057-ND PA0192-ND FPC125P020-ND IPC0055-ND FPC040P020-ND PA0052-ND PA0077-ND IPC0123-ND FPC080P020-ND IPC0153-ND 16-350000-10-P-ND 20-350000-10-P-ND 14-350000-11-RC-P-ND 18-350000-11-RC-P-ND 20-350000-11-RC-P-ND 14-350000-10-P-ND IPC0062-ND IPC0063-ND PA0010-ND PA0029-ND IPC0064-ND IPC0086-ND PA0053-ND PA0115-ND PA0078-ND PA0135-ND IPC0085-ND PA0155-ND PA0206-ND IPC0065-ND IPC0058-ND IPC0059-ND PA0047-ND IPC0001-ND IPC0121-ND IPC0165-ND IPC0066-ND IPC0035-ND PA0031-ND IPC0068-ND FPC040P030-ND IPC0069-ND IPC0050-ND FPC125P030-ND PA0237-ND FPC080P030-ND PA0187-ND PA0054-ND IPC0150-ND IPC0002-ND A897AR-ND A898AR-ND IPC0164-ND IPC0172-ND IPC0037-ND PA0102-ND PA0099-ND PA0038-ND PA0021-ND IPC0071-ND PA0239-ND PA0136-ND PA0100-ND PA0238-ND PA0055-ND PA0119-ND IPC0104-ND IPC0131-ND IPC0127-ND IPC0106-ND IPC0124-ND IPC0090-ND PA0079-ND 3677-3-ND PA0012-ND IPC0157-ND IPC0161-ND IPC0162-ND IPC0182-ND IPC0151-ND FPC040P040-ND IPC0084-ND FPC100P040-ND PA0218-ND IPC0038-ND FPC080P040-ND IPC0003-ND IPC0115-ND PA0116-ND IPC0004-ND IPC0117-ND IPC0149-ND PA0013-ND 10-350000-10-ND 12-350000-10-ND IPC0155-ND IPC0176-ND PA0023-ND PA0022-ND IPC0140-ND PA0097-ND PA0066-ND PA0137-ND PA0228-ND PA0216-ND IPC0073-ND IPC0074-ND IPC0005-ND PA0157-ND PA0056-ND IPC0152-ND 22-350000-10-ND PA0024-ND PA0014-ND 28-350002-10-P-ND 28-505-111P-ND IPC0168-ND IPC0173-ND 44-505-110-P-ND IPC0154-ND IPC0181-ND IPC0007-ND PA0227-ND IPC0039-ND IPC0008-ND IPC0143-ND IPC0110-ND IPC0009-ND IPC0075-ND FPC040P050-ND IPC0169-ND PA0025-ND PA0217-ND IPC0011-ND PA0068-ND IPC0082-ND IPC0102-ND PA0080-ND IPC0010-ND PA0207-ND IPC0108-ND IPC0040-ND IPC0126-ND PA0224-ND PA0138-ND IPC0013-ND PA0229-ND IPC0113-ND IPC0163-ND IPC0180-ND IPC0183-ND FPC050P060-ND IPC0081-ND IPC0041-ND PA0209-ND IPC0089-ND IPC0125-ND PA0117-ND FPC040P060-ND IPC0015-ND IPC0174-ND IPC0167-ND IPC0175-ND IPC0177-ND IPC0190-ND IPC0191-ND IPC0186-ND IPC0018-ND IPC0017-ND IPC0042-ND PA0069-ND IPC0091-ND PA0211-ND IPC0080-ND IPC0016-ND PA0226-ND PA0139-ND PA0242-ND IPC0114-ND IPC0116-ND IPC0092-ND IPC0112-ND PA0159-ND IPC0184-ND IPC0158-ND IPC0159-ND IPC0187-ND IPC0188-ND IPC0047-ND FPC050P070-ND PA0120-ND IPC0093-ND FPC040P070-ND PA0235-ND IPC0178-ND IPC0022-ND PA0212-ND PA0105-ND PA0070-ND PA0140-ND IPC0100-ND IPC0023-ND IPC0141-ND IPC0021-ND IPC0134-ND IPC0122-ND IPC0019-ND PA0081-ND IPC0094-ND IPC0043-ND IPC0145-ND IPC0135-ND IPC0185-ND PA0196-ND FPC040P080-ND IPC0179-ND PA0072-ND IPC0024-ND IPC0098-ND PA0106-ND IPC0105-ND PA0213-ND IPC0095-ND IPC0132-ND IPC0111-ND PA0141-ND IPC0109-ND IPC0160-ND IPC0025-ND FPC030P071-ND FPC040P090-ND IPC0147-ND IPC0170-ND IPC0192-ND PA0073-ND IPC0026-ND IPC0044-ND PA0214-ND PA0142-ND IPC0171-ND PA0118-ND IPC0128-ND PA0074-ND IPC0099-ND IPC0027-ND PA0241-ND PA0095-ND IPC0136-ND PA0143-ND PA0104-ND IPC0045-ND PA0230-ND PA0108-ND IPC0028-ND IPC0029-ND PA0144-ND IPC0097-ND PA0111-ND IPC0156-ND IPC0030-ND IPC0120-ND IPC0137-ND PA0200-ND IPC0031-ND PA0114-ND PA0203-ND IPC0144-ND IPC0138-ND PA0219-ND IPC0101-ND IPC0133-ND PA0145-ND IPC0146-ND IPC0032-ND PA0121-ND PA0122-ND IPC0139-ND IPC0046-ND PA0146-ND IPC0033-ND PA0220-ND IPC0034-ND PA0147-ND PA0199-ND PA0201-ND PA0148-ND PA0202-ND IPC0118-ND PA0149-ND PA0221-ND BGA0011-ND PA0150-ND PA0205-ND PA0151-ND BGA0016-ND BGA0004-ND BGA0001-ND BGA0007-ND BGA0014-ND BGA0012-ND BGA0002-ND BGA0015-ND BGA0006-ND BGA0009-ND GSPA-K1-ND GSPA-K2-ND 33408CA-ND 438-1033-ND 438-1018-ND 1568-1090-ND 1597-1258-ND 1597-1259-ND
IPC0169 PA0025 PA0217 IPC0011 PA0068 IPC0082 IPC0102 PA0080 IPC0010 PA0207 IPC0108 IPC0040 IPC0126 PA0224 PA0138 IPC0013 PA0229 IPC0113 IPC0163 IPC0180 IPC0183 FPC050P060 IPC0081 IPC0041 PA0209 IPC0089 IPC0125 PA0117 FPC040P060 IPC0015 IPC0174 IPC0167 IPC0175 IPC0177 IPC0190 IPC0191 IPC0186 IPC0018 IPC0017 IPC0042 PA0069 IPC0091 PA0211 IPC0080 IPC0016 PA0226 PA0139 PA0242 IPC0114 IPC0116 IPC0092 IPC0112 PA0159 IPC0184 IPC0158 IPC0159 IPC0187 IPC0188 IPC0047 FPC050P070 PA0120 IPC0093 FPC040P070 PA0235 IPC0178 IPC0022 PA0212 PA0105 PA0070 PA0140 IPC0100 IPC0023 IPC0141 IPC0021 IPC0134 IPC0122 IPC0019 PA0081 IPC0094 IPC0043 IPC0145 IPC0135 IPC0185 PA0196 FPC040P080 IPC0179 PA0072 IPC0024 IPC0098 PA0106 IPC0105 PA0213 IPC0095 IPC0132 IPC0111 PA0141 IPC0109 IPC0160 IPC0025 FPC030P071 FPC040P090 IPC0147 IPC0170 IPC0192 PA0073 IPC0026 IPC0044 PA0214 PA0142 IPC0171 PA0118 IPC0128 PA0074 IPC0099 IPC0027 PA0241 PA0095 IPC0136 PA0143 PA0104 IPC0045 PA0230 PA0108 IPC0028 IPC0029 PA0144 IPC0097 PA0111 IPC0156 IPC0030 IPC0120 IPC0137 PA0200 IPC0031 PA0114 PA0203 IPC0144 IPC0138 PA0219 IPC0101 IPC0133 PA0145 IPC0146 IPC0032 PA0121 PA0122 IPC0139 IPC0046 PA0146 IPC0033 PA0220 IPC0034 PA0147 PA0199 PA0201 PA0148 PA0202 IPC0118 PA0149 PA0221 BGA0011 PA0150 PA0205 PA0151 BGA0016 BGA0004 BGA0001 BGA0007 BGA0014 BGA0012 BGA0002 BGA0015 BGA0006 BGA0009 GSPA-K1 GSPA-K2 33408 8100-SMT11 8100-SMT9 BOB-00494 319010042 319010045 BOB-00717 BOB-13655 PA0001 PA0034 PA-SOD3SM18-14 PA-SOD3SM18-16 08-350000-11-RC 14-350000-11-RC 16-350000-11-RC 08-350000-10 20-350000-11-RC 1109814 24-650000-10 28-650000-10 28-650000-11-RC 33206 33006 PCB3007-1 PCB3005A1 PA0087 PA0085 PA0086 PA0083 1212 PCB3008-1 PCB3001-1 PA0042 PA0089 PA0032 PA0180 PA0026 PA0002 PA0003 PA0004 FPC050P010 PA0033 FPC100P010 9082 1207 LCQT-SOIC14 PA0027 PA0006 PA0005 PCB3006-1 LCQT-SOIC16 LCQT-TSSOP16 LCQT-SOIC16W 1206 PA0008 PA0035 IPC0060 FPC100P020 PA0061 DC0603T-10X DC0805T-10X DC1206T-10X 1230 1210 PA-MSD3SM18-08 PA0036 PA0193 PA0009 PA0063 IPC0051 IPC0067 PA0037 IPC0077 LCQT-TSSOP28 IPC0079 LCQT-SOIC28 24-350000-11-RC 14-350000-10 16-350000-10 IPC0014 FPC030P045 PA-SSD3SM18-20 28-350002-10 16-666000-00 PA-SOD3SM18-24 28-35W000-10 PA-SOD3SM18-28 68-505-110 PA0096 16-351000-11-RC 20-351000-11-RC 28-351000-11-RC 33003 6103 6303 33205 1325 33115 6908 6008 33108 33208 33008 33608 33113 33508 33708 6010 1492 33117 33010 6012 1208 1436 9163 1163 9210 6415 16-350000-11-RC-P LCQT-SOIC8-8 FIT0290 LS0003 LS0002 FIT0291 PA0088 LCQT-SOT23-6 BOB-00497 BOB-13994 PA0049 PA0168 LCQT-MSOP10 PA0182 BOB-00495 BOB-00496 BOB-00499 BOB-00500 PA0017 PA0184 PA0007 PA0101 PA0028 PA0060 PA0185 FPC050P020 DR050D254P020 PA0018 DC1210T-10X DC0805S-10X DC0402T-10X DC0603S-10X PA-SOTD3SM18-06 PA-SSD3SM18-08 PA-MSD3SM18-10 PA0019 PA0186 IPC0088 LCQT-TSSOP20 LCQT-SSOP20 PA0194 PA0011 PA0030 FPC050P030 IPC0036 PA0064 IPC0078 PA0103 IPC0070 PA0039 FPC050P040 FPC030P025 IPC0072 PA-SSD3SM18-14 PA0040 PA0065 PA0091 IPC0006 FPC050P050 IPC0049 PA-SSD3SM18-16 PA0208 PA0067 IPC0012 24-350000-10 DR050D254P060 PA0041 PA0210 PA-SOD3SM18-20 PA0093 IPC0020 PA0094 PA0240 PA0188 PA0109 PA0107SOCKET 33223 33143 33343 6004 33105 33505 6405 33405 6106 6006 33406 33623 6808 6109 319010352 319010351 33213 LCQT-SOIC14W 1211 1762 1377 1162 9164 9165 LCQT-TSOP32-1 18-350000-11-RC 20-350000-10 PA-SOD3SM18-18 319010047 1110748 20-35W000-11-RC PA-SOD6SM18-32 16-351000-10 28-351000-10 8100-SMT4 PA44QL8-1D 33305 33106 33306 6007 33518 6510 33110 33310 33410 6112 6816 6916 6115 6520 9301 LCQT-QFP0.8-44 14-351000-10 14-351000-11-RC 8100-SMT10 8100-SMT14 8100-SMT8 8100-SMT7 8100-SMT10-LF 8100-SMT8-LF PA0090 PA0016 DC1210S-10X DC1206S-10X DR050D254P040 PA0107 PA0110 PA0189 PA0106SOCKET PA0214SOCKET PA0223 PA0219SOCKET 8100-SMT6 BGA0019 BGA0023 BOB-00498 DIP-ADAPTER-EVM BGA0010 PA-SOD3SM18-08 32-650000-10 LCQT-TSSOP14 PA0062 DC1813T-10X LCQT-SOIC20W PA0071 PA-SSD3SM18-28 PA-TQFP-BB001-1 PA0113 PA0174 IPC0142 PA0183 IPC0083 IPC0076 IPC0061 PA0020 FPC100P030 IPC0096 PA0195 LCQT-SOIC32W LCQT-TSOP32 PA-QSD3SM18-16 PA0092 LCQT-QFP0.5-32 LCQT-QFP0.5-64 IPC0107 IPC0048 PA-SSD3SM18-18 LCQT-QFP0.8-64 PA-QSD3SM18-20 319010053 PA-SSD3SM18-24 PA-SSD6SM18-24 PA-SSD6SM18-28 16-665000-00 PA-SSD6SM18-32 PA-QLD6SM18-32F-88 PA-SSD6SM18-40 6306 6309 33308 6410 9302 LCQT-SOIC32 18-350000-10 LCQT-QFP0.65-64 PA-TS1D6SM18-32 8100-SMT3 DC0402S-10X IPC0103 PA0190 PA0105SOCKET BOB-13005 PA0082 PA0179 PA0048 PA0173 PA0084 PA0175 PA0177 PA0152 PA0172 PA0043 PA0044 PA0015 PA0170 PA0169 PA0058 PA0225 PA0133 PA0050 FPC040P010 IPC0148 IPC0052 PA0181 PA0057 FPC080P010 PA0243 FPC125P010 PA0045 PA0132 PA0153 PA0075 PA0178 IPC0087 IPC0056 PA0191 PA0171 IPC0054 PA0244 PA0154 IPC0053 PA0059 PA0051 PA0098 PA0134 PA0076 PA0046 IPC0130 IPC0119 IPC0129 08-350000-10-P 08-350000-11-RC-P IPC0057 PA0192 FPC125P020 IPC0055 FPC040P020 PA0052 PA0077 IPC0123 FPC080P020 IPC0153 16-350000-10-P 20-350000-10-P 14-350000-11-RC-P 18-350000-11-RC-P 20-350000-11-RC-P 14-350000-10-P IPC0062 IPC0063 PA0010 PA0029 IPC0064 IPC0086 PA0053 PA0115 PA0078 PA0135 IPC0085 PA0155 PA0206 IPC0065 IPC0058 IPC0059 PA0047 IPC0001 IPC0121 IPC0165 IPC0066 IPC0035 PA0031 IPC0068 FPC040P030 IPC0069 IPC0050 FPC125P030 PA0237 FPC080P030 PA0187 PA0054 IPC0150 IPC0002 LCQT-TSOP40 LCQT-TSOP40-1 IPC0164 IPC0172 IPC0037 PA0102 PA0099 PA0038 PA0021 IPC0071 PA0239 PA0136 PA0100 PA0238 PA0055 PA0119 IPC0104 IPC0131 IPC0127 IPC0106 IPC0124 IPC0090 PA0079 3677-3 PA0012 IPC0157 IPC0161 IPC0162 IPC0182 IPC0151 FPC040P040 IPC0084 FPC100P040 PA0218 IPC0038 FPC080P040 IPC0003 IPC0115 PA0116 IPC0004 IPC0117 IPC0149 PA0013 10-350000-10 12-350000-10 IPC0155 IPC0176 PA0023 PA0022 IPC0140 PA0097 PA0066 PA0137 PA0228 PA0216 IPC0073 IPC0074 IPC0005 PA0157 PA0056 IPC0152 22-350000-10 PA0024 PA0014 28-350002-10-P 28-505-111P IPC0168 IPC0173 44-505-110-P IPC0154 IPC0181 IPC0007 PA0227 IPC0039 IPC0008 IPC0143 IPC0110 IPC0009 IPC0075 FPC040P050
