If you look at the marking on the cable surface of Prysmian’s cable products, you may see the temperature rating value is not the same as the specification. For example, for C0785A.41.10 the maximum temperature rating is +80degC, but 105degC may be listed on the cable surface.
Verified by manufacturer, a product line of CAROL® Classics Electronics with an enhanced 105degC temperature rating is now available. Check the below document to show the links to each design that now has a 105degC rating.
ELE-0005-0122_CAROL Electronics 105C Rated Offering Guide_LR.pdf (107.1 KB)
