Replacement for TG-A6050-24-21.01-1.0
This post is for informational purposes only, please review the manufacturer data for each part number before using any recommended items in your application.
Part number 1168-TG-A6050-24-21.01-1.0-ND made by t-Global Technology has been discontinued. Currently, the best alternative we have in stock is part number 1168-TG-A6200-24-21.01-1.0-ND, produced by the same manufacturer. This is a good match for the thermal conductivity, adhesive, and size of the original pad, which I would consider the critical specifications for most use cases.
It is not a direct cross-reference however, so please review the datasheet before using this as a replacement. See below for more details and a link to the datasheet.
MFR PART # TG-A6200-24-21.01-1.0
DIGIKEY PART # 1168-TG-A6200-24-21.01-1.0-ND
MANUFACTURER t-Global Technology
DESCRIPTION THERM PAD 24MMX21.01MM BLUE
DATASHEET Click Here
