Replacement for Weidmuller 1512760000
------Question for 1512760000 Please Put your question below------
Weidmuller 15127600 is now obsolete but 11467400 is available. What, if any, is the difference?
Hello @joyce.farnese
Welcome to the community!
Part 11467400 is listed as the Weidmüller‑recommended substitute. They have the same footprint and function.
The main difference is in the pin length and ratings: 15127600 uses 4.5 mm solder pin and is standard‑rated, while 11467400 uses 3.2 mm solder pins and is a high‑current (HC) upgraded version.
Connectors, Interconnects | Headers, Plugs and Sockets | DigiKey
Many thanks. That’s very helpful.
