Request Component Info - CBBJR26
Please help to advise the below information for MPN: CBBJR26.
MPN: CBBJR26
MFG: Cinch Connectivity Solutions
Component Body Sizes:
  1. Component Body Width ( mm ) :
  2. Component Max Thickness / Height ( mm ) :
  3. Lead / Ball Pitch ( mm ) :
  4. Lead / Ball Quantity :
Wave Soldering Details:
  1. Peak Temperature ( Max Temperature allowed in Wave Solder ) :
  2. Contact Time / Dwell Time ( Max Time at Peak Temperature ) :
  3. Heat Cycle / Wave Cycle ( Recommended number of Wave Solder passes ) :
  4. Component Washability ( Washable? ) : Yes / No
We only use Deionized Water via Aqueous Machine with Drying process after washing.
  1. Width ( mm ) : 48.768 (1.92")
  2. Height ( mm ) : 48.768 (1.92")
  3. Lead Pitch ( mm ) : 6.5532 (0.258") between outer pins, 3.2766 (0.129") between center and outer pins, see diagram in datasheet.
  4. Lead Quantity : Five Leads
Full dimensional diagram found in the datasheet, linked here: CBBJR26 DIAGRAM
Wave Soldering: As for the wave soldering specifications, I did not see any information available. I do not believe this part is washable, but I will verify with a product specialist for Cinch Connectivity to see what they can tell us. I will follow up with another post once I have more information.
Thank you!
Per the manufacturer they do not have specifications available for wave soldering, but it is compatible with water wash, deionized or otherwise.
