Please suggest 3 alternate part numbers for each of the following component:
TPS62175DQCR, ADS7044IRUGR & GDZ20LP5-7
Hello kamali.k,
Thank you for posting in the TechForum
Part number TPS62175DQCR is an active part with only one alternative listed on our page and the only difference is the reel size.
Part number ADS7044IRUGR is an active part with 1 alternative with a part number of 296-48819-1-ND. The main difference is a part number 296-48819-1-ND has a higher sampling rate.
Part number GDZ20LP5-7, I don’t find anything for when I search our website or when I google it. We do have part number GDZ20LP3-7 and I don’t see an alternative for that.
Hi jeff,
Thank you for sharing the details regarding ADS7044IRUGR and its alternative 296-48819-1-ND.
After reviewing the specifications, we observed that the alternative part requires a minimum analog supply voltage of 2.35V, whereas our design operates at 1.8V. Due to this difference, the alternative part is not suitable for our application.
Please let us know if you can suggest any other alternatives that support an analog supply voltage range starting from 1.65V (similar to ADS7044IRUGR).
Looking forward to your recommendations.
Thanks & Regards,
Kamali K
Hello kamali.K,
Unfortunately, I have been unable to find an alternative that would be more in line with your specifications.
