You may encounter either version of this router from Teltonika while searching for replacements for your equipment. As the products have recently gone obsolete, it’s important to know whether remaining supplies of one can be used to replace the other. What is the difference between the ‘100’ version of this product at the ‘000’ version?
In this case, the router itself is the same. The “100” indicates that the device ships with a U.S. power supply, while ‘000’ ships with a European power supply. If your existing power supply still works, you can replace one number with the other without issue.
If you’re looking to replace the router with an active, supported device, Teltonika recommends their RUT301 series, per their PCN: Obsolescence: Teltonika EOL Notice for RUT300 Series. We do not currently have this product on the shelves, but we can special order it for you at your request.
