SC628 STC
The SC628 addition to a aircraft may require a STC (Supplemental Type Certificate) does
DigiKey have one for installation purposes?
It looks like the supplier would have to get the STC if they intend for this to be used in an aircraft. Looking at the suppliers approvals and certificates, the STC is not included in them. If you want to use this in an aircraft, you may have to seek the STC yourself.
https://mspindy.com/technical-resources/certifications/
Aircraft (supplemental) type certificates are a matter between an aircraft design holder and the applicable civil aviation authority. A supplier of component products cannot unilaterally and in blanket fashion provide such certification.
Rick,
Garmin GPS provides STCs for their client base. It can be done.
WB
