Simple question on (opto)
Hi, if VO618A-3X017T has 48V present at the collector pin while off is this okay and how much leakage current can I expect at temperature?
I’m trying to determine if I’m looking in the right place, I see 80V VCEO and about 100nA at 80C
Thank you for your inquiry.
It is ok, because the Collector Emitter Voltage is good up to 80V, like you mentioned.
Based on the graph scale I would say it’s probably around closer to 400nA or so at 80C if you’re at 40V or above.
Thanks for your help!
