Hammond 1540M25
I am designing a faraday motor generator a Dynamo which has no brushes no commutator and uses no alternating current at all.
The Armature is a single passive toroidal inductor which must be wound in a single layer to bring the windings close to the magnets.
So did you key if you are listening do you know if Hammond 1540 m25 is wound in a single layer or will I have to call Hammond to determine this?
I have Hammond 1540 m21 which is a single layer of much thicker wire.
Thanks in advance
Douglas
Replikon Research
