Spec for Coil Craft Part RFC0807BV-124KE
The description for this part has
486 MOHM in it but when you look at
the datasheet the DCR listed is between
0.442 and 0.486 ohms. Not sure which
is correct.
Thanks
Thank you for contacting the Tech Forum.
I was able to confirm the max for this part is the 486mOhms and the 422mOhms is for the typical at 25C temperature. This part can fluctuate that given range and should not exceed the .486mOhms ratings.
Thank you
ryan
