If DigiKey does not normally carry a specific Vishay VJ series capacitor from our VJ Ceramic Capacitors or VJ Ceramic Capacitor Kits we do have the ability to special order them. Manufacturer minimum order quantity and lead-time may apply, and the quote process can take anywhere from 3-10 business days to complete. To request a special-order product from any of our vendors, simply fill out our Special Order Product Request Form.
Within the VJ series datasheet, there is a part number builder:
Notes
(1) Case size designator may be replaced by four digit drawing number used to control non-standard products and / or special requirements
(2) DC voltage rating should not be exceeded in application. Other application factors may affect the MLCC performance.
(3) Process code may be added with up to three digits, used to control non-standard products and / or special requirements
(4) Termination code “E” is for conductive epoxy assembly
(5) Polymer termination for size 0603 and larger. Packaging only in plastic tape “T” / “R”
(6) Variable plastic / paper tape, see ratings in “Selection Charts”
Click here for all Capacitors
Click here for all Capacitor Kits
Applicable Part Numbers
VJ0603A221KXBAC97
VJ0402D430FCAAC
1481219-10X
1481274-10X
