On the Digi-key site, OMRON lists an ‘H’ option and an ‘H1’ option for some relays within their G5V-2 series. Questions may arise because the ‘H1’ version is shown in the datasheet, but not the ‘H’ version, so it appears as if the ‘H’ option isn’t valid.
Part numbers G5V-2-H-DC24 and G5V-2-H1 DC24 can be used as examples. The product page and datasheet links are posted, below.
G5V-2-H DC24 [click here https://www.digikey.com/short/z092zh ]
G5V-2-H1 DC24 [click here https://www.digikey.com/short/z0924q ]
Datasheet link: [click here https://omronfs.omron.com/en_US/ecb/products/pdf/en-g5v_2.pdf ]
The datasheet only shows ‘H1’ as a valid option, and this indicates “High-sensitivity.”
A request was recently sent to OMRON regarding the ‘H’ option, and they explained that they decided to remove the ‘H’ option from the product line, in general, but a few of those part numbers had enough sales to justify their continuation. However, the ‘H’ option was removed from later datasheets because there was no intent to expand on that version. These remained active only to accommodate the customers that were currently using them.
In the older datasheet, ‘H’ was labeled as the ‘High-sensitivity’ version, and ‘H1’ was the ‘Ultra-sensitive’ option. With the ‘H’ option removed from the documentation, ‘H1’ was relabeled as the only ‘High-sensitivity’ version as opposed to G5V-2 (no additional suffix) which is the ‘Standard’ offering.
More products from the G5V-2 series can be found in our signal relay category: [click here https://www.digikey.com/short/z09nm2 ]. Product Index > Relays > Signal Relays, Up to 2 Amps > Series Filter = “G5V-2”.
The relevant main categories for this type of product are linked below:
Product Index > Relays > Signal Relays, Up to 2 Amps [click here https://www.digikey.com/en/products/filter/signal-relays-up-to-2-amps/189 ].
Product Index > Relays > Power Relays, Over 2 Amps [click here https://www.digikey.com/en/products/filter/power-relays-over-2-amps/188 ].
As always, relays and many other products can be found by searching from our Digi-key home page: [click here https://www.digikey.com/ ].
