I want to know the storage temperature data for this P/N: CRCW04020000Z0EDHP. I checked in the datasheet, but the storage data was not mentioned in the datasheet. Can you please provide documentation or proof from the manufacturer regarding the storage temperature for mentioned part number?
Many manufacturers give the following recommendations:
Ideal storage conditions are +10 to +30°C, avoiding temperature changes greater than ±10°C in a 24-hour period, and 30 to 60% RH. Chemical fumes, sulphur-bearing gases and particulate air pollution should not be present. Original packaging should remain intact until first use.
