If you have received any TE ring terminal connectors that appear blackened on the surface and look oxidized, please do not be concerned; the part is still fully functional and safe to use.
Kindly refer to the information below, from one of TE’s engineers:
The dark discoloration observed on the tin-plated surface of the parts is a condition called tin fretting.
Fretting is not caused by the plating process but is an inherent characteristic of tin and tin lead plating deposits. All tin plated surfaces will form an oxide on the surface, the oxide resides on top of a relatively soft tin layer. Tin fretting is actually a form of build-up of this tin oxidation. When the tin plated surface is disturbed such that the tin oxide layer is moved (like a scratch or smear), fresh metal is exposed which can oxidize. If this happens repeatedly, such as when parts rub together in shipping (or in a feeder bowl, or other handling and processing), then the oxide thickness can build in the disturbed area resulting in a dark spot of tin oxide build up - fretting.
This condition occurs when the parts are subject to repeated disturbance of the tin plated surface, such as what happens in handling, shipping, application and usage. This condition is often accelerated in warm and humid environments, often seen more frequently in the summer months.
This condition is often a concern for connectors with small electrical contact surfaces and low contact normal force, as tin oxide can increase contact resistance. However, in this case, either the fretted area is in a non-electrical contact region of the part, or it is minimal in comparison to the entire electrical contact surface. Additionally, the connection is made with a high contact force to the mating surface. Therefore, this condition should not impact product performance and is purely cosmetic.
As the fretting is only cosmetic, we recommend that the parts be used as is.
Check more article on this:
TE Plasti-Grip Terminal Connector Oxidation Condition
Applicable Part Numbers
| A29890TR-ND,A29890CT-ND | 60771-2 |
| A29907TR-ND,A29907CT-ND | 640052-1 |
| A107160TR-ND,A107160CT-ND | 160344-2 |
| A29894TR-ND,A29894CT-ND | 61386-1 |
| A103992TR-ND,A103992CT-ND | 34839 |
| A100602TR-ND,A100602CT-ND | 40955 |
| A29867TR-ND,A29867CT-ND | 40725 |
| A111337TR-ND,A111337CT-ND | 60422-3 |
| A105490TR-ND,A105490CT-ND | 62638-1 |
| A100610TR-ND,A100610CT-ND | 41558 |
| A27147-ND | 31425 |
| A105459TR-ND,A105459CT-ND | 40888 |
| A28255-ND | 31423 |
| A0923-ND | 34123 |
| A0915-ND | 34105 |
| A0928-ND | 33457 |
| A0957-ND | 34148 |
| A100613TR-ND,A100613CT-ND | 41582 |
| A09017-ND | 34145 |
| A104038TR-ND,A104038CT-ND | 61588-1 |
| A0917-ND | 34109 |
| A27006-ND | 34107 |
| A27023-ND | 321684 |
| A107158TR-ND,A107158CT-ND | 160102-2 |
| A1060-ND | 36152 |
| A1062-ND | 36154 |
| A27233-ND | 51863 |
| A0957TR-ND,A0957CT-ND | 2-34148-1 |
| A0958TR-ND,A0958CT-ND | 2-34149-1 |
| A1072-ND | 36160 |
| A0965TR-ND,A0965CT-ND | 2-34161-1 |
| A1071-ND | 320565 |
| A27234-ND | 36151 |
| A1061-ND | 31890 |
| A27237-ND | 320551 |
| A27241-ND | 36153 |
| A1060TR-ND,A1060CT-ND | 2-36152-1 |
| A1071TR-ND,A1071CT-ND | 2-320565-1 |
| 35684-ND | 35684 |
| A1072TR-ND,A1072CT-ND | 2-36160-1 |
| A1061TR-ND,A1061CT-ND | 2-31890-1 |
| A1062TR-ND,A1062CT-ND | 2-36154-2 |
| A27237TR-ND,A27237CT-ND | 1-320551-1 |
| A27233TR-ND,A27233CT-ND | 51863-1 |
| A27256TR-ND,A27256CT-ND | 2-320560-1 |
| A27256-ND | 320560 |
| A135378TR-ND,A135378CT-ND | 2-130014-1 |
| A27262TR-ND,A27262CT-ND | 2-320563-2 |
| A0927-ND | 32994 |
| A27033-ND | 321828 |
| A0970TR-ND,A0970CT-ND | 2-34854-1 |
| A27238-ND | 31886 |
| A0956-ND | 34144 |
| A28117TR-ND,A28117CT-ND | 51864-4 |
| A27238TR-ND,A27238CT-ND | 2-31886-2 |
| A127614-ND | 130098 |
| A1082-ND | 35109 |
| A27262-ND | 320563 |
| A27284-ND | 36161 |
| A28221TR-ND,A28221CT-ND | 2-328527-1 |
| A0969TR-ND,A0969CT-ND | 2-34853-1 |
| A27255-ND | 51864-1 |
| 130191-ND | 130191 |
| A1082TR-ND,A1082CT-ND | 2-35109-1 |
| A27038-ND | 322454 |
| A0885-ND | 31894 |
| A0963TR-ND,A0963CT-ND | 2-34159-1 |
| A0971TR-ND,A0971CT-ND | 2-34855-1 |
| A122969TR-ND,A122969CT-ND | 160181-2 |
| 130094-ND | 130094 |
| A128749-ND | 34104-6 |
| A27284TR-ND,A27284CT-ND | 2-36161-2 |
| A27059-ND | 33461 |
| A27269-ND | 34805 |
| A27246TR-ND,A27246CT-ND | 2-320571-2 |
| A1083-ND | 35110 |
| A1095TR-ND,A1095CT-ND | 2-35111-1 |
| A135580TR-ND,A135580CT-ND | 2-342143-1 |
| A27226TR-ND,A27226CT-ND | 2-326875-1 |
| A135535TR-ND,A135535CT-ND | 2-324075-1 |
| A27288-ND | 320569 |
| A27055-ND | 33460 |
| A27281-ND | 32883 |
| A27413-ND | 323062 |
| A27277-ND | 35787 |
| A27341-ND | 1-320551-3 |
| A27320-ND | 52041-1 |
| A122834-ND | 321021 |
| A27049-ND | 35135 |
| A135564TR-ND,A135564CT-ND | 2-34119-1 |
| 321827-ND | 321827 |
| A27344-ND | 51863-4 |
| 8-31880-1-ND | 8-31880-1 |
| A27323-ND | 52265 |
| 323985-ND | 323985 |
| A100528TR-ND,A100528CT-ND | 2-35107-1 |
| A122551-ND | 165028 |
| A27085-ND | 33470 |
| A28127TR-ND,A28127CT-ND | 2-34805-1 |
| A122040-ND | 130205 |
| A135379-ND | 2-130094-1 |
| A122328-ND | 171505-2 |
| A135202-ND | 171505-1 |
| A100499TR-ND,A100499CT-ND | 2-321684-1 |
| A27067-ND | 52197 |
| A27084-ND | 31811 |
| A27531-ND | 52291-1 |
| 321262-ND | 321262 |
| A135596TR-ND,A135596CT-ND | 2-35684-1 |
| 321884-ND | 321884 |
| A112452-ND | 160013 |
| A112030-ND | 130552 |
| A128038-ND | 150072-1 |
| 322335-ND | 322335 |
| A27403-ND | 322363 |
| A122776-ND | 184269-1 |
| 55148-1-ND | 55148-1 |
| 323745-ND | 323745 |
| A27051-ND | 320764 |
| A27050-ND | 320763 |
| A27078-ND | 36808 |
| 320758-ND | 320758 |
| A100504TR-ND,A100504CT-ND | 2-323680-5 |
| 328822-ND | 328822 |
| A100498TR-ND,A100498CT-ND | 2-321598-3 |
| 322338-ND | 322338 |
| A27538-ND | 52044-1 |
| 1-331420-0-ND | 1-331420-0 |
| A128071-ND | 1577624-1 |
| A139241-ND | 726345-1 |
| 17-1-35478-0TR-ND,17-1-35478-0CT-ND | 1-35478-0 |
| A122626-ND | 50832-1 |
| 50836-1-ND | 50836-1 |
| A136188-ND | 50845-2 |
| A139196-ND | 50845-1 |
| A28061-ND | 322727 |
| A122606-ND | 322906 |
| A135052-ND | 134462-1 |
| 322912-ND | 322912 |
| 17-440456-1TR-ND,17-440456-1CT-ND | 440456-1 |
| A29878TR-ND,A29878CT-ND | 42037-1 |
| A29903TR-ND,A29903CT-ND | 61795-1 |
| A100786TR-ND,A100786CT-ND | 63482-1 |
| A29901TR-ND,A29901CT-ND | 61794-1 |
| A29871TR-ND,A29871CT-ND | 41333 |
| A29879TR-ND,A29879CT-ND | 42037-2 |
| A29870TR-ND,A29870CT-ND | 41332 |
| A29873TR-ND,A29873CT-ND | 41580 |
| A29881TR-ND,A29881CT-ND | 42547-2 |
| A29900TR-ND,A29900CT-ND | 61793-1 |
| A100611TR-ND,A100611CT-ND | 41559 |
| A29904TR-ND,A29904CT-ND | 61795-3 |
| A29866TR-ND,A29866CT-ND | 40724 |
| A28256-ND | 322771 |
| A100689TR-ND,A100689CT-ND | 60770-1 |
| A131004TR-ND,A131004CT-ND | 160018-2 |
| A27020-ND | 34119 |
| A116290TR-ND,A116290CT-ND | 626034-2 |
| A111540TR-ND,A111540CT-ND | 63721-1 |
| A29876TR-ND,A29876CT-ND | 42036-2 |
| A131095TR-ND,A131095CT-ND | 42007 |
| A29880TR-ND,A29880CT-ND | 42508-2 |
| A101730TR-ND,A101730CT-ND | 63698-1 |
| A29908TR-ND,A29908CT-ND | 640204-1 |
| A29884TR-ND,A29884CT-ND | 60123-2 |
| A131021TR-ND,A131021CT-ND | 170011-2 |
| A100606TR-ND,A100606CT-ND | 41330 |
| A27148-ND | 31428 |
| A28273-ND | 30692 |
| A100556TR-ND,A100556CT-ND | 350199-1 |
| A29874TR-ND,A29874CT-ND | 41581 |
| A27149-ND | 31430 |
| A28257-ND | 33695 |
| A29902TR-ND,A29902CT-ND | 61794-4 |
| A28260-ND | 32860 |
| A28258-ND | 32858 |
| A135209-ND | 171512-1 |
| A104034TR-ND,A104034CT-ND | 60320-2 |
| A29911TR-ND,A29911CT-ND | 40524 |
| A100595TR-ND,A100595CT-ND | 40723 |
| A29906TR-ND,A29906CT-ND | 640051-1 |
| A105461TR-ND,A105461CT-ND | 485003-1 |
| A28294-ND | 31164 |
| A100608TR-ND,A100608CT-ND | 41456 |
| A107205TR-ND,A107205CT-ND | 880642-2 |
| A0964-ND | 34160 |
| A100900TR-ND,A100900CT-ND | 63640-1 |
| A105246TR-ND,A105246CT-ND | 160101-2 |
| A100686TR-ND,A100686CT-ND | 60700-2 |
| A29864TR-ND,A29864CT-ND | 40697 |
| A29865TR-ND,A29865CT-ND | 40698 |
| A0921-ND | 34120 |
| A29877TR-ND,A29877CT-ND | 42037 |
| A28269-ND | 31264 |
| A27150-ND | 31090 |
| A28267-ND | 31091 |
| A28272-ND | 31265 |
| A28289-ND | 30696 |
| A28290-ND | 322235 |
| A28265-ND | 31089 |
| A144737-ND | 130014 |
| 2266-62613-2TR-ND,A29905TR-ND,A29905CT-ND | 62613-2 |
| A27008-ND | 34110 |
| 51873-1-ND | 51873-1 |
| A29875TR-ND,A29875CT-ND | 41711 |
| A09016-ND | 34142 |
| A100723TR-ND,A100723CT-ND | 61283-1 |
| A28264-ND | 36189 |
| A145085-ND | 35773 |
| A28261-ND | 31087 |
| A28262-ND | 320677 |
| A29869TR-ND,A29869CT-ND | 41124 |
| A28281-ND | 31173 |
| A29883TR-ND,A29883CT-ND | 42752-2 |
| A29897TR-ND,A29897CT-ND | 485029-1 |
| A0965-ND | 34161 |
| 165297-ND | 165297 |
| A27011TR-ND,A27011CT-ND | 2-34108-2 |
| A0916-ND | 34108 |
| A0923TR-ND,A0923CT-ND | 2-34123-1 |
| A0966-ND | 34162 |
| A0922-ND | 34122 |
| A145078-ND | 130106 |
| A27151-ND | 31172 |
| A27009-ND | 34111 |
| A122554-ND | 170720-1 |
| A122968TR-ND,A122968CT-ND | 160108-2 |
| A135493TR-ND,A135493CT-ND | 2-31903-2 |
| A0914-ND | 34104 |
| A136086-ND | 342142-1 |
| A0955-ND | 34141 |
| A27012-ND | 34112 |
| A27045-ND | 35772 |
| A27012TR-ND,A27012CT-ND | 2-34112-2 |
| A113463-ND | 342104-1 |
| A104087TR-ND,A104087CT-ND | 40960 |
| A0956TR-ND,A0956CT-ND | 2-34144-1 |
| A0930-ND | 33459 |
| A111470TR-ND,A111470CT-ND | 63399-1 |
| A1070-ND | 320619 |
| A27152-ND | 30697 |
| A28303-ND | 31113 |
| A0924-ND | 34124 |
| A28300-ND | 34892 |
| A0919-ND | 34114 |
| A27306-ND | 34147 |
| A0925-ND | 34125 |
| 31891-ND | 31891 |
| A28299-ND | 34891 |
| 165301-ND | 165301 |
| A0970-ND | 34854 |
| A0959-ND | 34150 |
| A28107TR-ND,A28107CT-ND | 2-320619-1 |
| A100921TR-ND,A100921CT-ND | 62612-2 |
| A27243TR-ND,A27243CT-ND | 2-320552-1 |
| A27234TR-ND,A27234CT-ND | 2-36151-2 |
| A29868TR-ND,A29868CT-ND | 41013 |
| A0920-ND | 34115 |
| A27003-ND | 36467 |
| A27307TR-ND,A27307CT-ND | 2-32951-1 |
| A27227TR-ND,A27227CT-ND | 2-320553-2 |
| A122971TR-ND,A122971CT-ND | 160337-2 |
| A27241TR-ND,A27241CT-ND | 2-36153-2 |
| A27231TR-ND,A27231CT-ND | 2-36149-2 |
| A27232TR-ND,A27232CT-ND | 2-36150-1 |
| A106341-ND | 170780-1 |
| A116202TR-ND,A116202CT-ND | 160163-2 |
| A27239TR-ND,A27239CT-ND | 2-320554-1 |
| A27259-ND | 320574 |
| A27239-ND | 320554 |
| A27252-ND | 36158 |
| 160294-ND | 160294 |
| A27242-ND | 31887 |
| A27226-ND | 326875 |
| A100745TR-ND,A100745CT-ND | 61867-2 |
| A27231-ND | 36149 |
| A0969-ND | 34853 |
| A27253TR-ND,A27253CT-ND | 2-320561-2 |
| A27253-ND | 320561 |
| A136074-ND | 33459-4 |
| A28224TR-ND,A28224CT-ND | 2-34162-1 |
| 165295-ND | 165295 |
| A27035-ND | 322447 |
| A1087-ND | 31880 |
| A28312-ND | 31123 |
| A28308-ND | 31122 |
| A0958-ND | 34149 |
| A0926-ND | 35476 |
| A27001-ND | 34103 |
| A136430TR-ND,A136430CT-ND | 696047-1 |
| A27010TR-ND,A27010CT-ND | 2-34111-3 |
| A27006TR-ND,A27006CT-ND | 2-34107-2 |
| A0959TR-ND,A0959CT-ND | 2-34150-1 |
| A104021TR-ND,A104021CT-ND | 42864-2 |
| A127626-ND | 321017 |
| A09017TR-ND,A09017CT-ND | 2-34145-1 |
| A0964TR-ND,A0964CT-ND | 2-34160-1 |
| A0152-ND | 34126 |
| A0879-ND | 323912 |
| A27002-ND | 322927 |
| A0889-ND | 321045 |
| A122836-ND | 342183-1 |
| A0885TR-ND,A0885CT-ND | 2-31894-2 |
| A100640TR-ND,A100640CT-ND | 485030-1 |
| A09018-ND | 34146 |
| A113464-ND | 342144-1 |
| A27303-ND | 32945 |
| A27305-ND | 32950 |
| A27304-ND | 32947 |
| A27250-ND | 51864 |
| A28131TR-ND,A28131CT-ND | 2-35108-1 |
| A122611-ND | 342143-1 |
| A27232-ND | 36150 |
| A27227-ND | 320553 |
| 17-160134-2TR-ND,17-160134-2CT-ND | 160134-2 |
| A27255TR-ND,A27255CT-ND | 51864-5 |
| A27250TR-ND,A27250CT-ND | 51864-3 |
| A136083-ND | 342102-1 |
| A100522TR-ND,A100522CT-ND | 2-34158-1 |
| A120808TR-ND,A120808CT-ND | 140731-2 |
| A135199-ND | 170721-2 |
| A28212TR-ND,A28212CT-ND | 2-34146-1 |
| A0889TR-ND,A0889CT-ND | 2-321045-1 |
| A27258-ND | 51864-2 |
| A27275-ND | 35107 |
| A0931-ND | 33220 |
| 8-34105-1-ND | 8-34105-1 |
| A28284-ND | 326854 |
| A0880-ND | 323914 |
| A27043-ND | 35771 |
| A27032-ND | 34484 |
| A0955TR-ND,A0955CT-ND | 2-34141-1 |
| 34487-ND | 34487 |
| A127618-ND | 151730 |
| A27014TR-ND,A27014CT-ND | 2-34109-2 |
| A0918TR-ND,A0918CT-ND | 2-34113-2 |
| A27040-ND | 322455 |
| A127609-ND | 34835 |
| A100876TR-ND,A100876CT-ND | 42947-2 |
| A0967-ND | 34163 |
| A27260-ND | 53942-1 |
| A0960-ND | 34151 |
| A107159TR-ND,A107159CT-ND | 160336-2 |
| A27246-ND | 320571 |
| A28053-ND | 323219 |
| A111015TR-ND,A111015CT-ND | 160467-2 |
| A104020TR-ND,A104020CT-ND | 42863-2 |
| A0968-ND | 34164 |
| 165035-ND | 165035 |
| A0961-ND | 34152 |
| 165302-ND | 165302 |
| A100496TR-ND,A100496CT-ND | 2-320634-1 |
| A135489-ND | 2-31425-3 |
| A100486TR-ND,A100486CT-ND | 2-31090-1 |
| 17-160101-9TR-ND,17-160101-9CT-ND | 160101-9 |
| A27280TR-ND,A27280CT-ND | 2-320568-1 |
| A27288TR-ND,A27288CT-ND | 2-320569-3 |
| A27313-ND | 34852 |
| A0960TR-ND,A0960CT-ND | 2-34151-1 |
| A0971-ND | 34855 |
| A27280-ND | 320568 |
| A0928TR-ND,A0928CT-ND | 2-33457-2 |
| A100506TR-ND,A100506CT-ND | 2-323915-2 |
| A100513TR-ND,A100513CT-ND | 2-328998-1 |
| A122605-ND | 321620 |
| A28199-ND | 34143 |
| A27247-ND | 320572 |
| 330518-ND | 330518 |
| A124505-ND | 130230 |
| A100635TR-ND,A100635CT-ND | 42899-2 |
| A100636TR-ND,A100636CT-ND | 42913-2 |
| A28195-ND | 55678-1 |
| A27228TR-ND,A27228CT-ND | 2-320882-1 |
| A100639TR-ND,A100639CT-ND | 42946-2 |
| A27030TR-ND,A27030CT-ND | 2-34124-1 |
| A135569-ND | 2-34146-4 |
| A27245-ND | 32837 |
| 165303-ND | 165303 |
| A123858-ND | 160300 |
| 17-32837-1TR-ND,17-32837-1CT-ND | 32837-1 |
| A28194TR-ND,A28194CT-ND | 2-34168-1 |
| A136087-ND | 342184-1 |
| A28279-ND | 328970 |
| A27236-ND | 326878 |
| A27500-ND | 320773 |
| A1091-ND | 328996 |
| A100746TR-ND,A100746CT-ND | 61868-1 |
| A0884-ND | 328657 |
| A28102TR-ND,A28102CT-ND | 2-320572-1 |
| A27254-ND | 326882 |
| A1083TR-ND,A1083CT-ND | 2-35110-1 |
| A132500-ND | 130046 |
| A135582TR-ND,A135582CT-ND | 2-342184-1 |
| A100743TR-ND,A100743CT-ND | 61863-2 |
| A122134-ND | 321019 |
| A27340-ND | 51863-3 |
| A27249-ND | 324159 |
| A0973-ND | 34173 |
| A27257TR-ND,A27257CT-ND | 53941-2 |
| A0890-ND | 328998 |
| A27260TR-ND,A27260CT-ND | 53942-2 |
| A100505TR-ND,A100505CT-ND | 2-323914-1 |
| A1087TR-ND,A1087CT-ND | 2-31880-1 |
| A0882TR-ND,A0882CT-ND | 2-323916-1 |
| A1095-ND | 35111 |
| A0882-ND | 323916 |
| A136141TR-ND,A136141CT-ND | 42639-1 |
| A27039TR-ND,A27039CT-ND | 2-32994-1 |
| A32018-ND | 35492 |
| A27230-ND | 330648 |
| A124517-ND | 160293 |
| A27496-ND | 323986 |
| A27157-ND | 35775 |
| A27448-ND | 323011 |
| A28210TR-ND,A28210CT-ND | 2-34148-4 |
| 34488-ND | 34488 |
| A135545TR-ND,A135545CT-ND | 2-326819-1 |
| A27406-ND | 322798 |
| A27338-ND | 52273-1 |
| A0893-ND | 35149 |
| A27346-ND | 2-36153-5 |
| A27290-ND | 320576 |
| A0883-ND | 324075 |
| A0891-ND | 328999 |
| A27512-ND | 31903 |
| A135579TR-ND,A135579CT-ND | 2-342104-1 |
| A27263-ND | 320575 |
| A27273-ND | 320634 |
| 8-36160-1-ND | 8-36160-1 |
| A0929TR-ND,A0929CT-ND | 2-33458-3 |
| A27257-ND | 53941-1 |
| A27405-ND | 322797 |
| A122159-ND | 8-31890-1 |
| A27298-ND | 53417-1 |
| 8-36154-1-ND | 8-36154-1 |
| A27497-ND | 323989 |
| A27408-ND | 322799 |
| 331401-ND | 331401 |
| A121361-ND | 31906 |
| A136085-ND | 342106-1 |
| A27285-ND | 35273 |
| A107350TR-ND,A107350CT-ND | 1-35787-0 |
| A136084-ND | 342105-1 |
| A123857-ND | 160121 |
| A100744TR-ND,A100744CT-ND | 61866-1 |
| A27351-ND | 51864-8 |
| A27158-ND | 35776 |
| A28050-ND | 30928 |
| A0887-ND | 31897 |
| A32017-ND | 35349 |
| A33724-ND | 696422-4 |
| A27337-ND | 2-36153-3 |
| A27282-ND | 324918 |
| A27278-ND | 324915 |
| A0921TR-ND,A0921CT-ND | 2-34120-1 |
| A27308-ND | 32948 |
| A27073-ND | 321598 |
| A135573TR-ND,A135573CT-ND | 2-34151-3 |
| A27074-ND | 33466 |
| A27076-ND | 33467 |
| A27019-ND | 329966 |
| A136711-ND | 8-321045-1 |
| 321632-ND | 321632 |
| 130171-ND | 130171 |
| A135207-ND | 171508-5 |
| A27293-ND | 53407-1 |
| A106345-ND | 171508-2 |
| A122330-ND | 171508-1 |
| A122137-ND | 322694 |
| A135597TR-ND,A135597CT-ND | 2-35775-1 |
| A99254-ND | 2-36149-3 |
| A27350-ND | 51864-7 |
| A27345-ND | 1-320551-4 |
| A27349-ND | 1-51864-0 |
| A27062-ND | 33462 |
| A27352-ND | 1-51864-1 |
| A27229-ND | 323758 |
| A27342-ND | 2-36153-4 |
| A27353-ND | 51864-9 |
| A27343-ND | 2-36149-5 |
| A27335-ND | 51863-2 |
| A27347-ND | 2-320561-3 |
| A27348-ND | 51864-6 |
| A28123TR-ND,A28123CT-ND | 2-328999-1 |
| A130005-ND | 130005 |
| A122052-ND | 160298 |
| A27083-ND | 33469 |
| A27295-ND | 53409-1 |
| A27064-ND | 33463 |
| A100493TR-ND,A100493CT-ND | 2-320573-4 |
| A27054-ND | 32996 |
| A122525-ND | 130446 |
| A27291-ND | 320577 |
| A136329TR-ND,A136329CT-ND | 55936-2 |
| A1084-ND | 35112 |
| A27318-ND | 52263 |
| A27317-ND | 52263-1 |
| A127617-ND | 150492 |
| A27493-ND | 53073 |
| A09023-ND | 34837 |
| A27292-ND | 53406-1 |
| A121991-ND | 160136 |
| A27294-ND | 53408-1 |
| A122556-ND | 170725-2 |
| A135494-ND | 2-320561-4 |
| A99249-ND | 52273-2 |
| A28144TR-ND,A28144CT-ND | 2-320576-1 |
| A100514TR-ND,A100514CT-ND | 2-32961-1 |
| A27070-ND | 321298 |
| A122612-ND | 342185-1 |
| A28236TR-ND,A28236CT-ND | 2-34173-1 |
| A27063-ND | 31808 |
| A122056-ND | 165034 |
| A0894-ND | 35151 |
| A122589-ND | 2-320572-4 |
| A27530-ND | 52041 |
| A27355-ND | 2-320568-2 |
| A27319-ND | 52041-3 |
| A28195TR-ND,A28195CT-ND | 55678-2 |
| A09037-ND | 34806 |
| A0886-ND | 31895 |
| A27318TR-ND,A27318CT-ND | 52263-2 |
| 35363-ND | 35363 |
| A122588-ND | 2-320571-5 |
| A122587-ND | 2-320571-3 |
| A27274-ND,2266-326886-ND | 326886 |
| A27000-ND | 50334 |
| A139213-ND | 54310-1 |
| A124506-ND | 160038 |
| A134962TR-ND,A134962CT-ND | 1-51864-5 |
| A27492-ND | 52189 |
| A121349-ND | 151458 |
| A113462-ND | 342101-1 |
| A27287-ND | 35345 |
| A128745TR-ND,A128745CT-ND | 327905-1 |
| A27495-ND | 329636 |
| A27356-ND | 2-36161-3 |
| A27179-ND | 36271 |
| A27272-ND | 35148 |
| A27357-ND | 2-320568-3 |
| A27061-ND | 35247 |
| A27514-ND | 2-320563-4 |
| A27178-ND | 36270 |
| A27177-ND | 322819 |
| 322733-ND | 322733 |
| A27048TR-ND,A27048CT-ND | 2-33459-6 |
| A135377TR-ND,A135377CT-ND | 2-130008-1 |
| A27358-ND | 2-36161-4 |
| A27414-ND | 323063 |
| 320761-ND | 320761 |
| A124398-ND | 130550 |
| A27087-ND | 33471 |
| A135531-ND | 2-323916-3 |
| A27331-ND | 52266 |
| 2-324061-5-ND | 2-324061-5 |
| 2-320573-2-ND | 2-320573-2 |
| A139214-ND | 54311-1 |
| A112453-ND | 160032 |
| A27301-ND,2266-53425-1-ND | 53425-1 |
| A136278-ND | 53423-1 |
| A27326-ND | 52264 |
| A27354-ND | 2-36161-5 |
| A28196-ND | 55621-1 |
| A27056TR-ND,A27056CT-ND | 2-33460-2 |
| A135502-ND | 2-320575-3 |
| 320762-ND | 320762 |
| A135600-ND | 2-36161-6 |
| A27516-ND | 2-320569-6 |
| A27513-ND | 2-320563-3 |
| A122636-ND | 53401-1 |
| 323165-ND | 323165 |
| A28056-ND | 325069 |
| A27321-ND | 52291 |
| A122592-ND | 2-320577-2 |
| A27325-ND | 52042-1 |
| A136279-ND | 53427-1 |
| A136431-ND | 696049-1 |
| A136075-ND | 33466-1 |
| A135380TR-ND,A135380CT-ND | 2-130171-1 |
| 160075-ND | 160075 |
| A139154-ND | 171507-1 |
| A0888-ND | 328975 |
| A135530-ND | 2-323914-2 |
| 321890-ND | 321890 |
| A134959-ND | 1-36270-1 |
| 322329-ND | 322329 |
| A122051-ND | 160138 |
| 320745-ND | 320745 |
| 54312-1-ND | 54312-1 |
| A27517-ND | 2-320576-3 |
| A113185-ND | 2-326875-4 |
| A136594-ND | 726343-3 |
| 323169-ND | 323169 |
| A27515-ND | 2-320569-5 |
| A135567TR-ND,A135567CT-ND | 2-34126-2 |
| A136440-ND | 696420-3 |
| A28137TR-ND,A28137CT-ND | 2-35364-1 |
| A27086-ND | 33115 |
| 323152-ND | 323152 |
| A128998-ND | 696424-7 |
| A27082-ND | 33114 |
| A136596-ND | 726344-1 |
| 322334-ND | 322334 |
| A27265-ND | 328976 |
| A27534-ND | 52264-1 |
| A113902-ND | 53403-1 |
| A27327-ND | 52043-2 |
| A28248TR-ND,A28248CT-ND | 55680-2 |
| A122544-ND | 152871 |
| 152873-ND | 152873 |
| A27329-ND | 52043-1 |
| A28141TR-ND,A28141CT-ND | 2-35345-1 |
| 320765-ND | 320765 |
| A27097-ND | 322870 |
| A27077-ND | 320344 |
| A27510-ND | 35150 |
| A27065-ND | 35664 |
| A136277-ND | 53422-1 |
| A27079-ND | 36809 |
| A100515TR-ND,A100515CT-ND | 2-33461-3 |
| A27088-ND | 31812 |
| 322339-ND | 322339 |
| A27098-ND | 321600 |
| 54753-1-ND | 54753-1 |
| A122088-ND | 321895 |
| A100650TR-ND,A100650CT-ND | 52197-1 |
| A27563-ND | 55654-1 |
| A121363-ND | 33115-1 |
| A27397-ND | 31518 |
| 322340-ND | 322340 |
| A27328-ND | 52043-3 |
| A27564-ND | 54754-1 |
| A27332-ND | 52267-1 |
| A27379-ND | 324043 |
| A27180-ND | 323196 |
| A27099-ND | 35184 |
| A27094-ND | 320383 |
| 1-331417-1-ND | 1-331417-1 |
| A27378-ND | 53041 |
| A27409-ND | 322375 |
| A27184-ND | 321275 |
| 323171-ND | 323171 |
| 52267-ND | 52267 |
| A27380-ND | 324082 |
| A27382-ND | 324045 |
| 130554-ND | 130554 |
| A135501-ND | 2-320573-3 |
| A136308-ND | 54593-1 |
| A135130-ND | 1577619-1 |
| A128070-ND | 1577621-1 |
| A136429-ND | 696020-1 |
| A09069-ND | 8-55850-2 |
| A107602-ND | 1577616-1 |
| 322870-1-ND | 322870-1 |
| A27072TR-ND,A27072CT-ND | 2-33465-1 |
| A124401-ND | 35625 |
| 152895-ND | 152895 |
| A27385-ND | 324047 |
| 320759-ND | 320759 |
| A135133-ND | 1577626-1 |
| A124528-ND | 54725-1 |
| A27095-ND | 320138 |
| A113818-ND | 52044-5 |
| 323683-ND | 323683 |
| 35678-ND | 35678 |
| A113444-ND | 321897 |
| A27108-ND | 36917 |
| A160000-ND | 160000 |
| A27096-ND | 35183 |
| A27111-ND | 36919 |
| A27109-ND | 321868 |
| A27105-ND | 321866 |
| PB1282-ND | 35277 |
| A135039-ND | 132072-2 |
| A122625-ND | 50334-2 |
| A27537-ND | 52044-4 |
| A33736-ND | 54748-1 |
| A135137-ND | 1577631-1 |
| 50830-ND | 50830 |
| A27093-ND | 330301 |
| A27387-ND | 331456 |
| A27092-ND | 35670 |
| A27391-ND | 324052 |
| A27188-ND | 321064 |
| 323174-ND | 323174 |
| A27121-ND | 36925 |
| A27119-ND | 36923 |
| A135144-ND | 1577639-1 |
| A135143-ND | 1577638-1 |
| A27101-ND | 35185 |
| 50832-ND | 50832 |
| A135522-ND | 2-322870-2 |
| A136055-ND,2266-321867-1-ND | 321867-1 |
| A135131-ND | 1577622-1 |
| 323068-ND | 323068 |
| 50840-ND | 50840 |
| A27117-ND | 36922 |
| A134953-ND | 1-332433-0 |
| A27396-ND | 324057 |
| A27132-ND | 321878 |
