TEENSY 4.1 WITH COPY PROTECTION
------Question for 28369 Please Put your question below------
This is listed as with copy protection, but I just want to make sure if this one also have ethernet?
PHY is already populated and such
This part number, 28369 is: Teensy 4.1, Lockable
This matches: TEENSY41_LOCK from: Teensy® 4.1 so it has Ethernet..
The other Teensy part numbers from SparkFun explicitly say “without Ethernet” if Ethernet is disabled..
You’ll still need an external adapter to use Ethernet..
18615 SparkFun Electronics | Educational Kits | DigiKey
