If you are looking for the Evaluation Kit for the IWR6843 of Texas Instruments, you may see there are three different models available. Namely, IWR6843AOPEVM, IWR6843ISK-ODS and IWR6843ISK. All are associated with IWR6843, but they have difference characteristics.
IWR6843ISK is based on pairing the IWR6843 device with a long-range antenna. The IWR6843ISK may be used to evaluate the IWR6843 and IWR6443 devices.
IWR6843ISK-ODS is based on pairing the IWR6843 device with a wide field-of-view antenna. The IWR6843ISK-ODS may be used to evaluate the IWR6843 and IWR6443 devices.
IWR6843AOPEVM is used to evaluate the IWR6843 antenna-on-package (AOP) product, which integrates a wide field-of-view (FoV) antenna.
We summarize to the following table.
| MPN of EVM Kit | IWR6843ISK | IWR6843ISK-ODS | IWR6843AOPEVM |
| Digi-Key Part # | 296-IWR6843ISK-ND | 296-IWR6843ISK-ODS-ND | 296-IWR6843AOPEVM-ND |
| Description | Based on IWR6843 device with long-range antenna | Based on the IWR6843 device with wide field-of-view antenna | Used to evaluate the IWR6843 antenna-on-package (AOP) product, which integrates a wide field-of-view (FoV) antenna |
Applicable part numbers
IWR6843ABGABLR
IWR6843ABGABL
IWR6843AQGABLR
IWR6843ARQGALP
IWR6843AQGABL
IWR6843ARQGALPR
296-IWR6843ABGABLRTR-ND
296-IWR6843ABGABLTR-ND
296-IWR6843AQGABLRTR-ND
296-IWR6843ARQGALP-ND
296-IWR6843AQGABL-ND
296-IWR6843ARQGALPRTR-ND
