Tripp Lite offers a diverse array of communication and power equipment, such as their U360-007-INT USB mini hub. A frequent question we field for this product concerns its power supply. When ordering this product, customers are frequently surprised that it comes with an international power adapter with no U.S. blades. Can this be changed?
This “-INT” version of the product is the International version, intended for sale overseas. The U.S. version with a standard U.S. power supply is U360-007, without the -INT suffix. Beyond included power supply, these two part numbers are interchangeable. If all you’re looking for is a compatible U.S. power supply for this -INT device, you can check out PSAW36I-12-B2; this device matches the specifications given for the un-numbered power supply listed in Tripp Lite’s documentation for the USB hub.
