If you are experiencing issues with short circuits and leakage current in the 195D solid tantalum capacitors after high-temperature and room-temperature tests, here is some important information from the manufacturer:
Vishay notes that solid tantalum capacitors in this series are sensitive to both ambient temperature and applied voltage. The 195D series solid tantalum capacitors are not designed for high-stress conditions without voltage derating.
Example: For a 35V rated capacitor 195D226X9035R2T, the recommended applied voltage at temperatures below 85°C is 15V. and If the test conditions exceed these recommendations, it may potentially lead to short circuits and leakage current.
Please check below document for detail on Solid tantalum capacitors Voltage Derating
Solid tantalum capacitors Voltage Derating.pdf (206.0 KB)
For applications requiring high reliability and testing, Vishay offers the T95 series, which includes options for reliability testing, such as burn-in at 85°C for 40 hours. Only capacitors that pass rigorous tests—such as capacitance, dissipation factor, DC leakage, and ESR—are approved for shipment in the T95 series.
For further information, check out How to test DC leakage on Tantalum Capacitors
Applicable Part Numbers
| 718-1953-2-ND,718-1953-1-ND,718-1953-6-ND | 195D106X9025Y2T |
| 718-2250-2-ND,718-2250-1-ND,718-2250-6-ND | 195D106X9035Z2T |
| 718-195D226X9035R2TTR-ND,718-195D226X9035R2TCT-ND,718-195D226X9035R2TDKR-ND | 195D226X9035R2T |
| 718-195D475X9050Z2TTR-ND,718-195D475X9050Z2TCT-ND,718-195D475X9050Z2TDKR-ND | 195D475X9050Z2T |
| 718-195D684X9020C4TTR-ND,718-195D684X9020C4TCT-ND,718-195D684X9020C4TDKR-ND | 195D684X9020C4T |
| 718-195D106X0025Y2TTR-ND,718-195D106X0025Y2TCT-ND,718-195D106X0025Y2TDKR-ND | 195D106X0025Y2T |
| 718-195D225X9050Y4TTR-ND,718-195D225X9050Y4TCT-ND,718-195D225X9050Y4TDKR-ND | 195D225X9050Y4T |
| 718-195D156X0025Z2TTR-ND,718-195D156X0025Z2TCT-ND,718-195D156X0025Z2TDKR-ND | 195D156X0025Z2T |
| 718-195D336X9016Z2TTR-ND,718-195D336X9016Z2TCT-ND,718-195D336X9016Z2TDKR-ND | 195D336X9016Z2T |
| 718-195D226X9020Z2TTR-ND,718-195D226X9020Z2TCT-ND,718-195D226X9020Z2TDKR-ND | 195D226X9020Z2T |
| 718-195D106X5016X4TTR-ND,718-195D106X5016X4TCT-ND,718-195D106X5016X4TDKR-ND | 195D106X5016X4T |
| 718-195D475X9010S4TTR-ND,718-195D475X9010S4TCT-ND,718-195D475X9010S4TDKR-ND | 195D475X9010S4T |
| 718-195D106X0050R2TTR-ND,718-195D106X0050R2TCT-ND,718-195D106X0050R2TDKR-ND | 195D106X0050R2T |
| 718-195D685X9035Z2TTR-ND,718-195D685X9035Z2TCT-ND,718-195D685X9035Z2TDKR-ND | 195D685X9035Z2T |
| 718-195D225X9020S2TTR-ND,718-195D225X9020S2TCT-ND,718-195D225X9020S2TDKR-ND | 195D225X9020S2T |
| 718-195D106X0035Z2TTR-ND,718-195D106X0035Z2TCT-ND,718-195D106X0035Z2TDKR-ND | 195D106X0035Z2T |
| 195D105X9035S2W-ND | 195D105X9035S2W |
| 195D474X0010S2W-ND | 195D474X0010S2W |
| 195D475X0010S2W-ND | 195D475X0010S2W |
| 195D104X9015S2T-ND | 195D104X9015S2T |
| 195D105X0010S2T-ND | 195D105X0010S2T |
| 195D105X0020S2T-ND | 195D105X0020S2T |
| 195D105X0025S2T-ND | 195D105X0025S2T |
| 195D105X0035S2T-ND | 195D105X0035S2T |
| 195D105X9004S2T-ND | 195D105X9004S2T |
| 195D105X9010S2T-ND | 195D105X9010S2T |
| 195D105X9015S2T-ND | 195D105X9015S2T |
| 195D105X9020S2T-ND | 195D105X9020S2T |
| 195D105X9025S2T-ND | 195D105X9025S2T |
| 195D105X9035S2T-ND | 195D105X9035S2T |
| 195D106X0004S2T-ND | 195D106X0004S2T |
| 195D106X9004S2T-ND | 195D106X9004S2T |
| 195D155X0025S2T-ND | 195D155X0025S2T |
| 195D155X9010S2T-ND | 195D155X9010S2T |
| 195D155X9016S2T-ND | 195D155X9016S2T |
| 195D155X9020S2T-ND | 195D155X9020S2T |
| 195D155X9025S2T-ND | 195D155X9025S2T |
| 195D225X0010S2T-ND | 195D225X0010S2T |
| 195D225X0016S2T-ND | 195D225X0016S2T |
| 195D225X0020S2T-ND | 195D225X0020S2T |
| 195D225X9010S2T-ND | 195D225X9010S2T |
| 195D225X9016S2T-ND | 195D225X9016S2T |
| 195D334X0025S2T-ND | 195D334X0025S2T |
| 195D334X9025S2T-ND | 195D334X9025S2T |
| 195D335X0010S2T-ND | 195D335X0010S2T |
| 195D335X0015S2T-ND | 195D335X0015S2T |
| 195D335X0016S2T-ND | 195D335X0016S2T |
| 195D335X06R3S2T-ND | 195D335X06R3S2T |
| 195D335X9004S2T-ND | 195D335X9004S2T |
| 195D335X9010S2T-ND | 195D335X9010S2T |
| 195D335X9016S2T-ND | 195D335X9016S2T |
| 195D474X0020S2T-ND | 195D474X0020S2T |
| 195D474X0035S2T-ND | 195D474X0035S2T |
| 195D474X9020S2T-ND | 195D474X9020S2T |
| 195D474X9035S2T-ND | 195D474X9035S2T |
| 195D475X0002S2T-ND | 195D475X0002S2T |
| 195D475X0004S2T-ND | 195D475X0004S2T |
| 195D475X0010S2T-ND | 195D475X0010S2T |
| 195D475X9004S2T-ND | 195D475X9004S2T |
| 195D475X9010S2T-ND | 195D475X9010S2T |
| 195D684X0025S2T-ND | 195D684X0025S2T |
| 195D684X0035S2T-ND | 195D684X0035S2T |
| 195D684X9025S2T-ND | 195D684X9025S2T |
| 195D685X06R3S2T-ND | 195D685X06R3S2T |
| 195D685X9004S2T-ND | 195D685X9004S2T |
| 195D685X96R3S2T-ND | 195D685X96R3S2T |
| 195D225X0004S2T-ND | 195D225X0004S2T |
| 195D334X9035S2T-ND | 195D334X9035S2T |
| 195D154X0050S2T-ND | 195D154X0050S2T |
| 195D154X9050S2T-ND | 195D154X9050S2T |
| 195D224X0050S2T-ND | 195D224X0050S2T |
| 195D334X0050S2T-ND | 195D334X0050S2T |
| 195D334X9050S2T-ND | 195D334X9050S2T |
| 195D224X9010S2T-ND | 195D224X9010S2T |
| 195D105X9035S8T-ND | 195D105X9035S8T |
| 195D155X0025S8T-ND | 195D155X0025S8T |
| 195D475X0010S8T-ND | 195D475X0010S8T |
| 195D475X9010S8T-ND | 195D475X9010S8T |
| 195D155X06R3A2T-ND | 195D155X06R3A2T |
| 195D155X96R3A2T-ND | 195D155X96R3A2T |
| 195D224X0035A2T-ND | 195D224X0035A2T |
| 195D224X9035A2T-ND | 195D224X9035A2T |
| 195D225X0004A2T-ND | 195D225X0004A2T |
| 195D225X9004A2T-ND | 195D225X9004A2T |
| 195D334X9025A2T-ND | 195D334X9025A2T |
| 195D474X0020A2T-ND | 195D474X0020A2T |
| 195D474X9020A2T-ND | 195D474X9020A2T |
| 195D685X0002A2T-ND | 195D685X0002A2T |
| 195D334X9050S8T-ND | 195D334X9050S8T |
| 195D104X0050A2T-ND | 195D104X0050A2T |
| 195D104X9050A2T-ND | 195D104X9050A2T |
| 195D104X5020S2T-ND | 195D104X5020S2T |
| 195D105X5035S2T-ND | 195D105X5035S2T |
| 195D106X5004S2T-ND | 195D106X5004S2T |
| 195D224X5004S2T-ND | 195D224X5004S2T |
| 195D225X5004S2T-ND | 195D225X5004S2T |
| 195D475X5010S2T-ND | 195D475X5010S2T |
| 195D106X06R3V2T-ND | 195D106X06R3V2T |
| 195D106X96R3V2T-ND | 195D106X96R3V2T |
| 195D155X0035V2T-ND | 195D155X0035V2T |
| 195D155X9035V2T-ND | 195D155X9035V2T |
| 195D156X0004V2T-ND | 195D156X0004V2T |
| 195D156X9004V2T-ND | 195D156X9004V2T |
| 195D225X0020V2T-ND | 195D225X0020V2T |
| 195D225X0025V2T-ND | 195D225X0025V2T |
| 195D225X9025V2T-ND | 195D225X9025V2T |
| 195D335X0020V2T-ND | 195D335X0020V2T |
| 195D335X9020V2T-ND | 195D335X9020V2T |
| 195D475X0016V2T-ND | 195D475X0016V2T |
| 195D475X9015V2T-ND | 195D475X9015V2T |
| 195D475X9016V2T-ND | 195D475X9016V2T |
| 195D685X0010V2T-ND | 195D685X0010V2T |
| 195D685X9010V2T-ND | 195D685X9010V2T |
| 195D474X0035B2T-ND | 195D474X0035B2T |
| 195D155X0015B2T-ND | 195D155X0015B2T |
| 195D105X9020B2T-ND | 195D105X9020B2T |
| 195D474X0050V2T-ND | 195D474X0050V2T |
| 195D684X0050V2T-ND | 195D684X0050V2T |
| 195D684X9050V2T-ND | 195D684X9050V2T |
| 195D106X96R3V8T-ND | 195D106X96R3V8T |
| 195D475X9015V8T-ND | 195D475X9015V8T |
| 195D475X9016V8T-ND | 195D475X9016V8T |
| 195D106X0015X2W-ND | 195D106X0015X2W |
| 195D105X0035D2T-ND | 195D105X0035D2T |
| 195D105X9035D2T-ND | 195D105X9035D2T |
| 195D106X0004D2T-ND | 195D106X0004D2T |
| 195D155X0025D2T-ND | 195D155X0025D2T |
| 195D225X0020D2T-ND | 195D225X0020D2T |
| 195D106X0010X2T-ND | 195D106X0010X2T |
| 195D106X0016X2T-ND | 195D106X0016X2T |
| 195D106X9010X2T-ND | 195D106X9010X2T |
| 195D106X9015X2T-ND | 195D106X9015X2T |
| 195D106X9016X2T-ND | 195D106X9016X2T |
| 195D107X96R3X2T-ND | 195D107X96R3X2T |
| 195D156X0010X2T-ND | 195D156X0010X2T |
| 195D156X06R3X2T-ND | 195D156X06R3X2T |
| 195D156X9010X2T-ND | 195D156X9010X2T |
| 195D225X0035X2T-ND | 195D225X0035X2T |
| 195D225X9025X2T-ND | 195D225X9025X2T |
| 195D225X9035X2T-ND | 195D225X9035X2T |
| 195D226X0004X2T-ND | 195D226X0004X2T |
| 195D226X06R3X2T-ND | 195D226X06R3X2T |
| 195D226X9004X2T-ND | 195D226X9004X2T |
| 195D226X96R3X2T-ND | 195D226X96R3X2T |
| 195D335X0025X2T-ND | 195D335X0025X2T |
| 195D335X9025X2T-ND | 195D335X9025X2T |
| 195D336X0004X2T-ND | 195D336X0004X2T |
| 195D336X9004X2T-ND | 195D336X9004X2T |
| 195D475X0020X2T-ND | 195D475X0020X2T |
| 195D475X0025X2T-ND | 195D475X0025X2T |
| 195D475X9020X2T-ND | 195D475X9020X2T |
| 195D475X9025X2T-ND | 195D475X9025X2T |
| 195D685X0016X2T-ND | 195D685X0016X2T |
| 195D685X0020X2T-ND | 195D685X0020X2T |
| 195D685X9020X2T-ND | 195D685X9020X2T |
| 195D105X9050X2W-ND | 195D105X9050X2W |
| 195D106X9025Y2W-ND | 195D106X9025Y2W |
| 195D475X0015E2T-ND | 195D475X0015E2T |
| 195D475X9015E2T-ND | 195D475X9015E2T |
| 195D105X0050X2T-ND | 195D105X0050X2T |
| 195D105X9050X2T-ND | 195D105X9050X2T |
| 195D155X0050X2T-ND | 195D155X0050X2T |
| 195D155X9050X2T-ND | 195D155X9050X2T |
| 195D155X9010C2W-ND | 195D155X9010C2W |
| 195D106X0020Y2T-ND | 195D106X0020Y2T |
| 195D106X9020Y2T-ND | 195D106X9020Y2T |
| 195D156X0016Y2T-ND | 195D156X0016Y2T |
| 195D156X9016Y2T-ND | 195D156X9016Y2T |
| 195D156X9025Y2T-ND | 195D156X9025Y2T |
| 195D226X0010Y2T-ND | 195D226X0010Y2T |
| 195D226X0016Y2T-ND | 195D226X0016Y2T |
| 195D226X9010Y2T-ND | 195D226X9010Y2T |
| 195D226X9016Y2T-ND | 195D226X9016Y2T |
| 195D335X0035Y2T-ND | 195D335X0035Y2T |
| 195D335X9035Y2T-ND | 195D335X9035Y2T |
| 195D336X06R3Y2T-ND | 195D336X06R3Y2T |
| 195D336X9010Y2T-ND | 195D336X9010Y2T |
| 195D336X96R3Y2T-ND | 195D336X96R3Y2T |
| 195D476X0004Y2T-ND | 195D476X0004Y2T |
| 195D476X06R3Y2T-ND | 195D476X06R3Y2T |
| 195D476X9004Y2T-ND | 195D476X9004Y2T |
| 195D476X96R3Y2T-ND | 195D476X96R3Y2T |
| 195D685X0025Y2T-ND | 195D685X0025Y2T |
| 195D685X9025Y2T-ND | 195D685X9025Y2T |
| 195D686X0004Y2T-ND | 195D686X0004Y2T |
| 195D686X9004Y2T-ND | 195D686X9004Y2T |
| 195D825X9025Y2T-ND | 195D825X9025Y2T |
| 195D225X9050Y2W-ND | 195D225X9050Y2W |
| 195D104X0002C2T-ND | 195D104X0002C2T |
| 195D105X0015C2T-ND | 195D105X0015C2T |
| 195D105X0016C2T-ND | 195D105X0016C2T |
| 195D105X0020C2T-ND | 195D105X0020C2T |
| 195D105X06R3C2T-ND | 195D105X06R3C2T |
| 195D105X9015C2T-ND | 195D105X9015C2T |
| 195D105X9016C2T-ND | 195D105X9016C2T |
| 195D155X0010C2T-ND | 195D155X0010C2T |
| 195D155X9010C2T-ND | 195D155X9010C2T |
| 195D225X0004C2T-ND | 195D225X0004C2T |
| 195D225X06R3C2T-ND | 195D225X06R3C2T |
| 195D225X9010C2T-ND | 195D225X9010C2T |
| 195D225X96R3C2T-ND | 195D225X96R3C2T |
| 195D334X0035C2T-ND | 195D334X0035C2T |
| 195D334X9035C2T-ND | 195D334X9035C2T |
| 195D335X0002C2T-ND | 195D335X0002C2T |
| 195D335X0004C2T-ND | 195D335X0004C2T |
| 195D335X9004C2T-ND | 195D335X9004C2T |
| 195D474X9025C2T-ND | 195D474X9025C2T |
| 195D475X0002C2T-ND | 195D475X0002C2T |
| 195D475X9002C2T-ND | 195D475X9002C2T |
| 195D684X0020C2T-ND | 195D684X0020C2T |
| 195D684X9020C2T-ND | 195D684X9020C2T |
| 195D105X0035S7T-ND | 195D105X0035S7T |
| 195D106X9025Y2B-ND | 195D106X9025Y2B |
| 195D225X0050Y2T-ND | 195D225X0050Y2T |
| 195D225X9050Y2T-ND | 195D225X9050Y2T |
| 195D475X9050Y2T-ND | 195D475X9050Y2T |
| 195D106X9025Y8T-ND | 195D106X9025Y8T |
| 195D335X9035Y8T-ND | 195D335X9035Y8T |
| 195D476X96R3Y8T-ND | 195D476X96R3Y8T |
| 195D685X9025Y8T-ND | 195D685X9025Y8T |
| 195D105X9016C8T-ND | 195D105X9016C8T |
| 195D104X0050C2T-ND | 195D104X0050C2T |
| 195D104X9050C2T-ND | 195D104X9050C2T |
| 195D154X0050C2T-ND | 195D154X0050C2T |
| 195D154X9050C2T-ND | 195D154X9050C2T |
| 195D224X0050C2T-ND | 195D224X0050C2T |
| 195D106X0035Z2W-ND | 195D106X0035Z2W |
| 195D156X0025Z2W-ND | 195D156X0025Z2W |
| 195D226X0016Z2W-ND | 195D226X0016Z2W |
| 195D226X9020Z2W-ND | 195D226X9020Z2W |
| 195D336X9015Z2W-ND | 195D336X9015Z2W |
| 195D336X9016Z2W-ND | 195D336X9016Z2W |
| 195D476X0010Z2W-ND | 195D476X0010Z2W |
| 195D225X5035X2T-ND | 195D225X5035X2T |
| 195D475X5020X2T-ND | 195D475X5020X2T |
| 195D225X9050Y8T-ND | 195D225X9050Y8T |
| 195D336X0016Z2T-ND | 195D336X0016Z2T |
| 195D475X0050Z2W-ND | 195D475X0050Z2W |
| 195D107X0004Z2T-ND | 195D107X0004Z2T |
| 195D107X06R3Z2T-ND | 195D107X06R3Z2T |
| 195D107X9004Z2T-ND | 195D107X9004Z2T |
| 195D107X96R3Z2T-ND | 195D107X96R3Z2T |
| 195D156X0020Z2T-ND | 195D156X0020Z2T |
| 195D156X9020Z2T-ND | 195D156X9020Z2T |
| 195D156X9025Z2T-ND | 195D156X9025Z2T |
| 195D226X0016Z2T-ND | 195D226X0016Z2T |
| 195D226X0020Z2T-ND | 195D226X0020Z2T |
| 195D226X9015Z2T-ND | 195D226X9015Z2T |
| 195D226X9016Z2T-ND | 195D226X9016Z2T |
| 195D336X0010Z2T-ND | 195D336X0010Z2T |
| 195D336X0015Z2T-ND | 195D336X0015Z2T |
| 195D336X9010Z2T-ND | 195D336X9010Z2T |
| 195D336X9015Z2T-ND | 195D336X9015Z2T |
| 195D475X0035Z2T-ND | 195D475X0035Z2T |
| 195D475X9035Z2T-ND | 195D475X9035Z2T |
| 195D476X0010Z2T-ND | 195D476X0010Z2T |
| 195D476X9010Z2T-ND | 195D476X9010Z2T |
| 195D685X0035Z2T-ND | 195D685X0035Z2T |
| 195D686X06R3Z2T-ND | 195D686X06R3Z2T |
| 195D106X0035Z8T-ND | 195D106X0035Z8T |
| 195D106X9035Z8T-ND | 195D106X9035Z8T |
| 195D156X9025Z8T-ND | 195D156X9025Z8T |
| 195D226X9020Z8T-ND | 195D226X9020Z8T |
| 195D336X0016Z8T-ND | 195D336X0016Z8T |
| 195D475X0035Z8T-ND | 195D475X0035Z8T |
| 195D475X9035Z8T-ND | 195D475X9035Z8T |
| 195D476X0010Z8T-ND | 195D476X0010Z8T |
| 195D476X9010Z8T-ND | 195D476X9010Z8T |
| 195D685X9035Z8T-ND | 195D685X9035Z8T |
| 195D335X0050Z2T-ND | 195D335X0050Z2T |
| 195D335X9050Z2T-ND | 195D335X9050Z2T |
| 195D475X0050Z2T-ND | 195D475X0050Z2T |
| 195D474X5025C2T-ND | 195D474X5025C2T |
| 195D106X0015F2T-ND | 195D106X0015F2T |
| 195D106X0025G2T-ND | 195D106X0025G2T |
| 195D106X9025G2T-ND | 195D106X9025G2T |
| 195D226X9015G2T-ND | 195D226X9015G2T |
| 195D335X9050Z8T-ND | 195D335X9050Z8T |
| 195D475X9050Z8T-ND | 195D475X9050Z8T |
| 195D105X0035D4T-ND | 195D105X0035D4T |
| 195D105X9035D4T-ND | 195D105X9035D4T |
| 195D106X5035Z2T-ND | 195D106X5035Z2T |
| 195D226X5020Z2T-ND | 195D226X5020Z2T |
| 195D476X5010Z2T-ND | 195D476X5010Z2T |
| 195D685X5035Z2T-ND | 195D685X5035Z2T |
| 195D225X06R3C4T-ND | 195D225X06R3C4T |
| 195D105X0015C4T-ND | 195D105X0015C4T |
| 195D155X9010C4T-ND | 195D155X9010C4T |
| 195D225X96R3C4T-ND | 195D225X96R3C4T |
| 195D334X0035C4T-ND | 195D334X0035C4T |
| 195D106X5035Z8T-ND | 195D106X5035Z8T |
| 195D476X5010Z8T-ND | 195D476X5010Z8T |
| 195D685X5035Z8T-ND | 195D685X5035Z8T |
| 195D475X5050Z2T-ND | 195D475X5050Z2T |
| 195D475X5050Z8T-ND | 195D475X5050Z8T |
| 195D105X9016C4T-ND | 195D105X9016C4T |
| 195D106X9010X4T-ND | 195D106X9010X4T |
| 195D106X9015X4T-ND | 195D106X9015X4T |
| 195D106X9016X4T-ND | 195D106X9016X4T |
| 195D475X9025X4T-ND | 195D475X9025X4T |
| 195D156X0020G4T-ND | 195D156X0020G4T |
| 195D105X0050X4T-ND | 195D105X0050X4T |
| 195D106X9025Y4T-ND | 195D106X9025Y4T |
| 195D335X9035Y4T-ND | 195D335X9035Y4T |
| 195D105X5016C4T-ND | 195D105X5016C4T |
| 195D336X9016Z4T-ND | 195D336X9016Z4T |
| 195D685X06R3S4T-ND | 195D685X06R3S4T |
| 195D105X0020S4T-ND | 195D105X0020S4T |
| 195D105X0035S4T-ND | 195D105X0035S4T |
| 195D105X9020S4T-ND | 195D105X9020S4T |
| 195D105X9035S4T-ND | 195D105X9035S4T |
| 195D225X0010S4T-ND | 195D225X0010S4T |
| 195D225X0020S4T-ND | 195D225X0020S4T |
| 195D225X9020S4T-ND | 195D225X9020S4T |
| 195D335X0016S4T-ND | 195D335X0016S4T |
| 195D335X9015S4T-ND | 195D335X9015S4T |
| 195D475X0010S4T-ND | 195D475X0010S4T |
| 195D105X9035S4B-ND | 195D105X9035S4B |
| 195D225X0010S4B-ND | 195D225X0010S4B |
| 195D225X0020S4B-ND | 195D225X0020S4B |
| 195D156X0020Z4T-ND | 195D156X0020Z4T |
| 195D156X0025Z4T-ND | 195D156X0025Z4T |
| 195D105X5035S4T-ND | 195D105X5035S4T |
| 195D155X9035V4T-ND | 195D155X9035V4T |
| 195D225X0025V4T-ND | 195D225X0025V4T |
| 195D685X0010V4T-ND | 195D685X0010V4T |
| 195D685X9010V4T-ND | 195D685X9010V4T |
| 195D107X0010R2T-ND | 195D107X0010R2T |
| 195D107X9010R2T-ND | 195D107X9010R2T |
| 195D127X0010R2T-ND | 195D127X0010R2T |
| 195D127X9010R2T-ND | 195D127X9010R2T |
| 195D156X0035R2T-ND | 195D156X0035R2T |
| 195D156X9035R2T-ND | 195D156X9035R2T |
| 195D157X0010R2T-ND | 195D157X0010R2T |
| 195D157X9010R2T-ND | 195D157X9010R2T |
| 195D187X96R3R2T-ND | 195D187X96R3R2T |
| 195D226X0020R2T-ND | 195D226X0020R2T |
| 195D226X0025R2T-ND | 195D226X0025R2T |
| 195D226X0035R2T-ND | 195D226X0035R2T |
| 195D227X06R3R2T-ND | 195D227X06R3R2T |
| 195D227X96R3R2T-ND | 195D227X96R3R2T |
| 195D336X0020R2T-ND | 195D336X0020R2T |
| 195D336X0025R2T-ND | 195D336X0025R2T |
| 195D336X9020R2T-ND | 195D336X9020R2T |
| 195D336X9025R2T-ND | 195D336X9025R2T |
| 195D337X9004R2T-ND | 195D337X9004R2T |
| 195D476X0016R2T-ND | 195D476X0016R2T |
| 195D476X0020R2T-ND | 195D476X0020R2T |
| 195D476X9016R2T-ND | 195D476X9016R2T |
| 195D476X9020R2T-ND | 195D476X9020R2T |
| 195D686X0016R2T-ND | 195D686X0016R2T |
| 195D686X9010R2T-ND | 195D686X9010R2T |
| 195D686X9016R2T-ND | 195D686X9016R2T |
| 195D226X9035R8T-ND | 195D226X9035R8T |
| 195D336X9025R8T-ND | 195D336X9025R8T |
| 195D476X9020R8T-ND | 195D476X9020R8T |
| 195D686X9016R8T-ND | 195D686X9016R8T |
| 195D106X9050R2T-ND | 195D106X9050R2T |
| 195D685X0050R2T-ND | 195D685X0050R2T |
| 195D685X9050R2T-ND | 195D685X9050R2T |
| 195D106X9050R8T-ND | 195D106X9050R8T |
| 195D157X5010R2T-ND | 195D157X5010R2T |
| 195D226X5035R2T-ND | 195D226X5035R2T |
| 195D336X5025R2T-ND | 195D336X5025R2T |
| 195D686X5010R2T-ND | 195D686X5010R2T |
| 195D686X5016R2T-ND | 195D686X5016R2T |
| 195D476X9020R4T-ND | 195D476X9020R4T |
| 195D157X5010R8T-ND | 195D157X5010R8T |
| 195D226X5035R8T-ND | 195D226X5035R8T |
| 195D476X0020H2T-ND | 195D476X0020H2T |
| 195D107X9010H2T-ND | 195D107X9010H2T |
