When looking at the TrenchFET Series from Vishay Siliconix you will find similar parts with Similar Suffixes. For this example we will look at parts SI2328DS-T1-E3 and SI2328DS-T1-GE3 If you look into the data sheet you will see all of the specifications for the parts are the same, however the E3 is calling our Lead Free and the GE3 is calling our Lead free and Halogen Free. This is listed under the Ordering Information on the data sheet.
Manufacturer Part Numbers - Transistors - FETs, MOSFETs - Arrays
SI1539CDL-T1-GE3 SI1902DL-T1-E3 SI1922EDH-T1-GE3 SI1024X-T1-GE3 SI1926DL-T1-E3 SI1025X-T1-GE3 SIA527DJ-T1-GE3 SIA906EDJ-T1-GE3 SIA910EDJ-T1-GE3 SI3932DV-T1-GE3 SI3590DV-T1-E3 SI3900DV-T1-E3 SI9933CDY-T1-GE3 SI4936BDY-T1-E3 SI4532ADY-T1-E3 SI9945BDY-T1-GE3 SI9926CDY-T1-GE3 SI4599DY-T1-GE3 SI7232DN-T1-GE3 SI4925DDY-T1-GE3 SI4931DY-T1-E3 SI4931DY-T1-GE3 SI6913DQ-T1-GE3 SI5504BDC-T1-E3 SI6562CDQ-T1-GE3 SI5515DC-T1-E3 SI4925BDY-T1-E3 SI4946BEY-T1-E3 SI4946BEY-T1-GE3 SI5902BDC-T1-GE3 SI4922BDY-T1-E3 SI5908DC-T1-E3 SI7216DN-T1-GE3 SI7288DP-T1-GE3 SI7228DN-T1-GE3 SI7913DN-T1-GE3 SI7949DP-T1-E3 SI7922DN-T1-GE3 SI7220DN-T1-GE3 SI7220DN-T1-E3 SI4204DY-T1-GE3 SI7905DN-T1-GE3 SI7997DP-T1-GE3 SI4904DY-T1-E3 SI7942DP-T1-GE3 SI7234DP-T1-GE3 SI7956DP-T1-GE3 SI1553CDL-T1-GE3 SI1967DH-T1-GE3 SI1034X-T1-GE3 SIA922EDJ-T1-GE3 SI1016X-T1-GE3 SI1029X-T1-GE3 SI3993CDV-T1-GE3 SIA931DJ-T1-GE3 SIA914ADJ-T1-GE3 SI3552DV-T1-E3 SI6968BEDQ-T1-GE3 SI4532CDY-T1-GE3 SI6954ADQ-T1-GE3 SI3993DV-T1-E3 SI7904BDN-T1-GE3 SQ9945BEY-T1_GE3 SI4559ADY-T1-GE3 SI4559ADY-T1-E3 SI5517DU-T1-GE3 SIZ918DT-T1-GE3 SI5908DC-T1-GE3 SI7923DN-T1-E3 SI4904DY-T1-GE3 SI7942DP-T1-E3 SI7236DP-T1-GE3 SI1035X-T1-GE3 SI1965DH-T1-GE3 SI1902DL-T1-GE3 SI6954ADQ-T1-E3 SI7218DN-T1-E3 SI4618DY-T1-E3 SI7998DP-T1-GE3 SI7900AEDN-T1-E3 SI7949DP-T1-GE3 SI8902EDB-T2-E1 SI7922DN-T1-E3 SI4936ADY-T1-E3 SI1034CX-T1-GE3 SISB46DN-T1-GE3 SI3590DV-T1-GE3 SI4590DY-T1-GE3 SIZ342DT-T1-GE3 SI5504BDC-T1-GE3 SIZ730DT-T1-GE3 SI1902CDL-T1-GE3 SI5933CDC-T1-GE3 SIA907EDJT-T1-GE3 SI5513CDC-T1-GE3 SIA913ADJ-T1-GE3 SI9933CDY-T1-E3 SI4501BDY-T1-GE3 SIA923EDJ-T1-GE3 SIA929DJ-T1-GE3 SIA923AEDJ-T1-GE3 SI5997DU-T1-GE3 SI5936DU-T1-GE3 SI4210DY-T1-GE3 SI4554DY-T1-GE3 SI3552DV-T1-GE3 SI3900DV-T1-GE3 SI7904BDN-T1-E3 SI4286DY-T1-GE3 SI7224DN-T1-GE3 SI4948BEY-T1-E3 SI5902BDC-T1-E3 SI9926CDY-T1-E3 SI4948BEY-T1-GE3 SIZ902DT-T1-GE3 SI7980DP-T1-GE3 SI7913DN-T1-E3 SI7214DN-T1-E3 SIZ914DT-T1-GE3 SIZ920DT-T1-GE3 SI4943BDY-T1-E3 SI6913DQ-T1-E3 SI7994DP-T1-GE3 SIB912DK-T1-GE3 SIB900EDK-T1-GE3 SI4936CDY-T1-GE3 SIA778DJ-T1-GE3 SIA975DJ-T1-GE3 SI4214DDY-T1-GE3 SI5515CDC-T1-GE3 SI5515CDC-T1-E3 SIS990DN-T1-GE3 SI4909DY-T1-GE3 SIZ300DT-T1-GE3 SI4900DY-T1-E3 SI4670DY-T1-E3 SI4288DY-T1-GE3 SI6968BEDQ-T1-E3 SI7216DN-T1-E3 SIZ710DT-T1-GE3 SI7938DP-T1-GE3 SIZ910DT-T1-GE3 SI1016CX-T1-GE3 SI5935CDC-T1-GE3 SIA519EDJ-T1-GE3 SIA533EDJ-T1-GE3 SIA517DJ-T1-GE3 SI5999EDU-T1-GE3 SI4564DY-T1-GE3 SI7272DP-T1-GE3 SI4943CDY-T1-GE3 SI4966DY-T1-E3 SI7252DP-T1-GE3 SI1023X-T1-GE3 SI3585CDV-T1-GE3 SIA921EDJ-T1-GE3 SI4202DY-T1-GE3 SIZ916DT-T1-GE3 SI1900DL-T1-E3 SIA537EDJ-T1-GE3 SI4804CDY-T1-GE3 SI4228DY-T1-GE3 SIZ900DT-T1-GE3 SIZ702DT-T1-GE3 SI1023CX-T1-GE3 SIA918EDJ-T1-GE3 SIA928DJ-T1-GE3 SI5922DU-T1-GE3 SI5513CDC-T1-E3 SI5948DU-T1-GE3 SI7972DP-T1-GE3 SIZ704DT-T1-GE3 SI4532ADY-T1-GE3 SQ4946AEY-T1_GE3 SIRB40DP-T1-GE3 SIZ728DT-T1-GE3 SI7540ADP-T1-GE3 SI1028X-T1-GE3 SI1967DH-T1-E3 SI1926DL-T1-GE3 SI1033X-T1-GE3 SI1965DH-T1-E3 SI5933CDC-T1-E3 SI5935CDC-T1-E3 SIA911ADJ-T1-GE3 SIA777EDJ-T1-GE3 SI4200DY-T1-GE3 SIA915DJ-T1-GE3 SIA920DJ-T1-GE3 SI4936CDY-T1-E3 SIA921EDJ-T4-GE3 SI4214DY-T1-GE3 SI4804CDY-T1-E3 SI3951DV-T1-GE3 SI3993DV-T1-GE3 SI4228DY-T1-E3 SI4214DDY-T1-E3 SI5515DC-T1-GE3 SIZ904DT-T1-GE3 SI4670DY-T1-GE3 SI7900AEDN-T1-GE3 SI3948DV-T1-GE3 SI7224DN-T1-E3 SI4276DY-T1-E3 SI7270DP-T1-GE3 SIR770DP-T1-GE3 SI4834CDY-T1-E3 SI4834CDY-T1-GE3 SI4900DY-T1-GE3 SI4936BDY-T1-GE3 SI4505DY-T1-E3 SI4505DY-T1-GE3 SUD50NP04-77P-T4E3 SI4932DY-T1-GE3 SIZ700DT-T1-GE3 SIZ720DT-T1-GE3 SI7923DN-T1-GE3 SI7214DN-T1-GE3 SI7218DN-T1-GE3 SQ4920EY-T1_GE3 SI4922BDY-T1-GE3 SI4925BDY-T1-GE3 SI4943CDY-T1-E3 SI6975DQ-T1-GE3 SI4936ADY-T1-GE3 SI4943BDY-T1-GE3 SI7905DN-T1-E3 SI4966DY-T1-GE3 SI4618DY-T1-GE3 SI6975DQ-T1-E3 SI8900EDB-T2-E1 SI7236DP-T1-E3 SI7956DP-T1-E3 SI7962DP-T1-E3
Manufacturer Part Numbers - Transistors - FETs, MOSFETs - Single
SI2301CDS-T1-GE3 SI2301CDS-T1-E3 SI2302CDS-T1-E3 SI2371EDS-T1-GE3 SI2347DS-T1-GE3 SI2301BDS-T1-E3 TP0610K-T1-E3 SI2304BDS-T1-GE3 SI1032R-T1-GE3 SI1012R-T1-GE3 SI1317DL-T1-GE3 SI2318CDS-T1-GE3 SI1013X-T1-GE3 SI2315BDS-T1-E3 SI2300DS-T1-GE3 SIA461DJ-T1-GE3 SI2369DS-T1-GE3 SI2312BDS-T1-E3 SI2312BDS-T1-GE3 SI2377EDS-T1-GE3 SI2312CDS-T1-GE3 SI2308BDS-T1-E3 SI3433CDV-T1-GE3 SI2308BDS-T1-GE3 SI2307BDS-T1-E3 SI8800EDB-T2-E1 SIA483DJ-T1-GE3 SI2318DS-T1-E3 SI2338DS-T1-GE3 SI1469DH-T1-E3 SIA427DJ-T1-GE3 SI5419DU-T1-GE3 SI2343CDS-T1-GE3 SIA429DJT-T1-GE3 SIS412DN-T1-GE3 SIS413DN-T1-GE3 SI4431CDY-T1-GE3 SI2333DS-T1-E3 SI2316DS-T1-E3 SI2328DS-T1-E3 SI5442DU-T1-GE3 SI4128DY-T1-GE3 SI5415AEDU-T1-GE3 SI2314EDS-T1-E3 SI4435DDY-T1-GE3 SI4420BDY-T1-E3 SIS427EDN-T1-GE3 SI4410BDY-T1-E3 SQ2310ES-T1_GE3 SI7615ADN-T1-GE3 SI5471DC-T1-GE3 SI2323CDS-T1-GE3 SIB452DK-T1-GE3 SI3410DV-T1-GE3 SI4431BDY-T1-E3 SIS438DN-T1-GE3 SI4056DY-T1-GE3 SI7149ADP-T1-GE3 SI3437DV-T1-E3 SI9407BDY-T1-GE3 SUD09P10-195-GE3 SI4825DDY-T1-GE3 SI3483CDV-T1-GE3 SUD50N04-8M8P-4GE3 SI4156DY-T1-GE3 SIR424DP-T1-GE3 SIS410DN-T1-GE3 SI7123DN-T1-GE3 SUD23N06-31-GE3 SI4116DY-T1-GE3 SI2325DS-T1-E3 SI2337DS-T1-E3 SIS407DN-T1-GE3 SI2325DS-T1-GE3 SI3499DV-T1-GE3 SI7117DN-T1-E3 SI4464DY-T1-E3 SIR426DP-T1-GE3 SIS892ADN-T1-GE3 SI7613DN-T1-GE3 SUD19P06-60-GE3 SI4866BDY-T1-GE3 SI7625DN-T1-GE3 SI7106DN-T1-E3 SIR462DP-T1-GE3 SI7386DP-T1-E3 SI3440DV-T1-E3 SI7101DN-T1-GE3 SI7820DN-T1-GE3 SI7414DN-T1-E3 SI7414DN-T1-GE3 SUD19P06-60L-E3 SIR468DP-T1-GE3 SI7465DP-T1-E3 SI7465DP-T1-GE3 SUD45P03-09-GE3 SI7322DN-T1-GE3 SI4459ADY-T1-GE3 SIR802DP-T1-GE3 SIR464DP-T1-GE3 SI7848BDP-T1-E3 SI7848BDP-T1-GE3 SI4840BDY-T1-GE3 SI4840BDY-T1-E3 SI7421DN-T1-E3 SI4154DY-T1-GE3 SI7336ADP-T1-GE3 SI7336ADP-T1-E3 SI7110DN-T1-E3 SI7139DP-T1-GE3 SIS892DN-T1-GE3 SIS443DN-T1-GE3 SI4401BDY-T1-E3 SI7615DN-T1-GE3 SI7850DP-T1-E3 SI7454DP-T1-E3 SI7113DN-T1-GE3 SI7456DP-T1-E3 SI7456DP-T1-GE3 SI4421DY-T1-E3 SUD15N15-95-E3 SI7460DP-T1-GE3 SI7852ADP-T1-GE3 SIR876ADP-T1-GE3 SI7898DP-T1-E3 SI4122DY-T1-GE3 SI7148DP-T1-E3 SI4497DY-T1-GE3 SIS402DN-T1-GE3 SIR158DP-T1-GE3 SIR404DP-T1-GE3 SUD50P06-15-GE3 SI7190DP-T1-GE3 SI7812DN-T1-GE3 SI4423DY-T1-E3 SIR870ADP-T1-GE3 SIRA00DP-T1-GE3 SI7178DP-T1-GE3 SI4434DY-T1-GE3 SI7135DP-T1-GE3 SI7145DP-T1-GE3 SI7141DP-T1-GE3 SI7164DP-T1-GE3 SI7463DP-T1-GE3 SIR882DP-T1-GE3 SUD40N08-16-E3 SI7489DP-T1-GE3 SUD50P08-25L-E3 SI7489DP-T1-E3 SIR880DP-T1-GE3 SUD19N20-90-E3 SUD50N06-09L-E3 SUD50P04-15-E3 SI7790DP-T1-GE3 SUM60N10-17-E3 SI7174DP-T1-GE3 SI7192DP-T1-GE3 SUM55P06-19L-E3 SUM110P06-07L-E3 SUM110N10-09-E3 SIE818DF-T1-E3 SI7439DP-T1-GE3 SI7439DP-T1-E3 SI7431DP-T1-GE3 SUM110P06-08L-E3 SUM110P08-11L-E3 SUM110P04-04L-E3 SUM110N06-3M9H-E3 SI1442DH-T1-GE3 TP0610K-T1-GE3 SI2304BDS-T1-E3 SI2374DS-T1-GE3 SI1315DL-T1-GE3 SI2303CDS-T1-GE3 SI2304DDS-T1-GE3 SI1012X-T1-GE3 SI1416EDH-T1-GE3 SI1077X-T1-GE3 SI3457CDV-T1-GE3 SI2307CDS-T1-E3 SI1330EDL-T1-E3 SI3443CDV-T1-GE3 SI2367DS-T1-GE3 SI1031R-T1-GE3 SI1414DH-T1-GE3 SI2333DDS-T1-GE3 SI8802DB-T2-E1 SI1302DL-T1-GE3 SI3474DV-T1-GE3 SQ1421EDH-T1_GE3 SI8808DB-T2-E1 SI1422DH-T1-GE3 SIB441EDK-T1-GE3 SIA459EDJ-T1-GE3 SI1050X-T1-GE3 SIB456DK-T1-GE3 SI8466EDB-T2-E1 SI2342DS-T1-GE3 SI1480DH-T1-GE3 SI2399DS-T1-GE3 SI3421DV-T1-GE3 SI2318DS-T1-GE3 SI2392ADS-T1-GE3 SI3469DV-T1-E3 SI3443BDV-T1-E3 SI2343DS-T1-E3 SI3442BDV-T1-E3 SI8483DB-T2-E1 SI8472DB-T2-E1 SI2323DDS-T1-GE3 SI2306BDS-T1-GE3 SIA448DJ-T1-GE3 SI8424CDB-T1-E1 SI2306BDS-T1-E3 SIA400EDJ-T1-GE3 SI2316BDS-T1-GE3 SISA18ADN-T1-GE3 SI2329DS-T1-GE3 SI2316BDS-T1-E3 SQ3456BEV-T1_GE3 SI2328DS-T1-GE3 SIRA18DP-T1-GE3 SI4178DY-T1-GE3 SI1499DH-T1-E3 SIA466EDJ-T1-GE3 SI3493BDV-T1-E3 SIA437DJ-T1-GE3 SIA433EDJ-T1-GE3 SIA416DJ-T1-GE3 SI4447DY-T1-E3 SI3477DV-T1-GE3 SI4435DDY-T1-E3 SI4403CDY-T1-GE3 SI4174DY-T1-GE3 SI5406CDC-T1-GE3 SI7619DN-T1-GE3 SIR836DP-T1-GE3 SIS414DN-T1-GE3 SI3460BDV-T1-E3 SI4666DY-T1-GE3 SIS407ADN-T1-GE3 SUD08P06-155L-GE3 SI3458BDV-T1-GE3 SIRA12DP-T1-GE3 SI7716ADN-T1-GE3 SI4835DDY-T1-GE3 SIA421DJ-T1-GE3 SIA430DJ-T1-GE3 SI2337DS-T1-GE3 SI4386DY-T1-E3 SI4464DY-T1-GE3 SI8429DB-T1-E1 SI7309DN-T1-GE3 SIRA10DP-T1-GE3 SI8409DB-T1-E1 SI3438DV-T1-GE3 SI7629DN-T1-GE3 SI7317DN-T1-GE3 SI7308DN-T1-E3 SI4186DY-T1-GE3 SI4483ADY-T1-GE3 SI4427BDY-T1-E3 SI3440DV-T1-GE3 SI4884BDY-T1-E3 SI7820DN-T1-E3 SI5476DU-T1-GE3 SI4164DY-T1-GE3 SIS890DN-T1-GE3 SI7114DN-T1-E3 SI4477DY-T1-GE3 SI4850EY-T1-GE3 SI7423DN-T1-E3 SI4896DY-T1-GE3 SI6415DQ-T1-E3 SI3460DV-T1-E3 SIJ478DP-T1-GE3 SI4455DY-T1-GE3 SI7818DN-T1-E3 SI7818DN-T1-GE3 SI7120ADN-T1-GE3 SUD50N03-09P-E3 SI4062DY-T1-GE3 SI7460DP-T1-E3 SI4488DY-T1-E3 SI7898DP-T1-GE3 SI6423DQ-T1-E3 SUD25N15-52-E3 SIR880ADP-T1-GE3 SI7102DN-T1-GE3 SIR494DP-T1-GE3 SI7858ADP-T1-E3 SI7812DN-T1-E3 SI4866DY-T1-E3 SI4456DY-T1-E3 SIE868DF-T1-GE3 SI7434DP-T1-E3 SI7434DP-T1-GE3 SIR890DP-T1-GE3 SI7113DN-T1-E3 SUM90N10-8M2P-E3 SUM65N20-30-E3 SUM85N15-19-E3 SI1403CDL-T1-GE3 SI5468DC-T1-GE3 SI1403BDL-T1-E3 SIA418DJ-T1-GE3 SI8812DB-T2-E1 SIB417AEDK-T1-GE3 SI1400DL-T1-E3 SI8805EDB-T2-E1 SI1070X-T1-GE3 SIB410DK-T1-GE3 SI3443CDV-T1-E3 SIA431DJ-T1-GE3 SI1471DH-T1-E3 SI5459DU-T1-GE3 SI5411EDU-T1-GE3 SI5415EDU-T1-GE3 SI1499DH-T1-GE3 SIRA14DP-T1-GE3 SI4487DY-T1-GE3 SI3458BDV-T1-E3 SI7114ADN-T1-GE3 SIR484DP-T1-GE3 SIA413DJ-T1-GE3 SI4436DY-T1-GE3 SIS456DN-T1-GE3 SI4102DY-T1-GE3 SI4384DY-T1-E3 SISA10DN-T1-GE3 SI8410DB-T2-E1 SI5410DU-T1-GE3 SI7806ADN-T1-E3 SI7405BDN-T1-GE3 SI5418DU-T1-GE3 SIR416DP-T1-GE3 SI7143DP-T1-GE3 SUD23N06-31L-E3 SIR164DP-T1-GE3 SI7892BDP-T1-E3 SIR812DP-T1-GE3 SI4136DY-T1-GE3 SI7108DN-T1-GE3 SIR492DP-T1-GE3 SI7623DN-T1-GE3 SUD50N03-06AP-E3 SI4842BDY-T1-GE3 SI4465ADY-T1-GE3 SI4434DY-T1-E3 SIR866DP-T1-GE3 SI4890DY-T1-E3 SI7868ADP-T1-E3 SIB408DK-T1-GE3 SI8457DB-T1-E1 SIA467EDJ-T1-GE3 SI8851EDB-T2-E1 SIRA16DP-T1-GE3 SIR472ADP-T1-GE3 SI4420BDY-T1-GE3 SIR460DP-T1-GE3 SI7108DN-T1-E3 SI4378DY-T1-GE3 SI7464DP-T1-E3 SI7464DP-T1-GE3 SIR476DP-T1-GE3 SI7858ADP-T1-GE3 SI7634BDP-T1-GE3 SIE808DF-T1-E3 SIUD412ED-T1-GE3 SI3443DDV-T1-GE3 SI3417DV-T1-GE3 SI3424CDV-T1-GE3 SI2366DS-T1-GE3 SI2303CDS-T1-E3 SI2301BDS-T1-GE3 SI3476DV-T1-GE3 SI5457DC-T1-GE3 SISA16DN-T1-GE3 SIB404DK-T1-GE3 SI7121ADN-T1-GE3 SIS436DN-T1-GE3 SI1411DH-T1-GE3 SI4463CDY-T1-GE3 SI4010DY-T1-GE3 SISS10DN-T1-GE3 SIJA54DP-T1-GE3 SI4410BDY-T1-GE3 SQS460EN-T1_GE3 SIRA58DP-T1-GE3 SI7315DN-T1-GE3 SIR644DP-T1-GE3 SIRA52DP-T1-GE3 SIRA20DP-T1-RE3 SIJ438DP-T1-GE3 SIR640ADP-T1-GE3 SQD50P06-15L_GE3 SQM120N04-1M7L_GE3 SI1443EDH-T1-GE3 SIA462DJ-T1-GE3 SI3442CDV-T1-GE3 SI3476DV-T1-GE3 SI5457DC-T1-GE3 SISA16DN-T1-GE3 SIB404DK-T1-GE3 SI7121ADN-T1-GE3 SIS436DN-T1-GE3 SI1411DH-T1-GE3 SI4463CDY-T1-GE3 SI4010DY-T1-GE3 SISS10DN-T1-GE3 SIJA54DP-T1-GE3 SI4410BDY-T1-GE3 SQS460EN-T1_GE3 SIRA58DP-T1-GE3 SI7315DN-T1-GE3 SIR644DP-T1-GE3 SIRA52DP-T1-GE3 SIRA20DP-T1-RE3 SIJ438DP-T1-GE3 SIR640ADP-T1-GE3 SQD50P06-15L_GE3 SQM120N04-1M7L_GE3 SI1443EDH-T1-GE3 SIA462DJ-T1-GE3 SI3442CDV-T1-GE3 SI8824EDB-T2-E1 SI3456DDV-T1-GE3 SI1427EDH-T1-GE3 SI1032X-T1-GE3 SI1013R-T1-GE3 SI1011X-T1-GE3 SI1489EDH-T1-GE3 SI8806DB-T2-E1 SI8817DB-T2-E1 SI3429EDV-T1-GE3 SI3127DV-T1-GE3 SIR172ADP-T1-GE3 SI3433CDV-T1-E3 SI8469DB-T2-E1 SI1302DL-T1-E3 SI2302CDS-T1-GE3 SI1069X-T1-GE3 SI8816EDB-T2-E1 SI1330EDL-T1-GE3 SIB433EDK-T1-GE3 SIB457EDK-T1-GE3 SI5440DC-T1-GE3 SQ2348ES-T1_GE3 SQ1431EH-T1_GE3 SIB406EDK-T1-GE3 SI8499DB-T2-E1 SI8487DB-T1-E1 SI8497DB-T2-E1 SI8425DB-T1-E1 SIS478DN-T1-GE3 SI4447ADY-T1-GE3 SI8461DB-T2-E1 SIRA36DP-T1-GE3 SIA444DJT-T1-GE3 SI3464DV-T1-GE3 SI2334DS-T1-GE3 SI1473DH-T1-GE3 SI4485DY-T1-GE3 SIA436DJ-T1-GE3 SIA445EDJ-T1-GE3 SI5404BDC-T1-E3 SI3447CDV-T1-E3 SI3457CDV-T1-E3 SI8406DB-T2-E1 SI5424DC-T1-GE3 SI2324DS-T1-GE3 SI8475EDB-T1-E1 SI4778DY-T1-GE3 SI4346DY-T1-E3 SI2315BDS-T1-GE3 SISA14DN-T1-GE3 SI4800BDY-T1-GE3 SI4800BDY-T1-E3 SI3493BDV-T1-GE3 SIR172DP-T1-GE3 SI4048DY-T1-GE3 SI2319DS-T1-GE3 SIR472DP-T1-GE3 SI4134DY-T1-E3 SIS415DNT-T1-GE3 SI4134DY-T1-GE3 SI8439DB-T1-E1 SIS406DN-T1-GE3 SI3459BDV-T1-E3 SI4447DY-T1-GE3 SISS27DN-T1-GE3 SQS401EN-T1_GE3 SQ7414AEN-T1_GE3 SI4172DY-T1-GE3 SISA12ADN-T1-GE3 SQ7415AEN-T1_GE3 SIA408DJ-T1-GE3 SI4835DDY-T1-E3 SI4101DY-T1-GE3 SI7686DP-T1-E3 SI7655ADN-T1-GE3 SI3437DV-T1-GE3 SIA426DJ-T1-GE3 SI9435BDY-T1-GE3 SQD15N06-42L_GE3 SIR474DP-T1-GE3 SI4894BDY-T1-GE3 SIS488DN-T1-GE3 SI7129DN-T1-GE3 SI7119DN-T1-E3 SI7119DN-T1-GE3 SI3483CDV-T1-E3 SIS454DN-T1-GE3 SI5403DC-T1-GE3 SI7309DN-T1-E3 SI3469DV-T1-GE3 SI4431CDY-T1-E3 SIR850DP-T1-GE3 SIA432DJ-T1-GE3 SI4866BDY-T1-E3 SI5441BDC-T1-E3 SI7308DN-T1-GE3 SIRA06DP-T1-GE3 SUD19P06-60-E3 SI7386DP-T1-GE3 SI7635DP-T1-GE3 SIR698DP-T1-GE3 SI7121DN-T1-GE3 SIS468DN-T1-GE3 SIRA04DP-T1-GE3 SI4463BDY-T1-E3 SI4160DY-T1-GE3 SI4848DY-T1-E3 SI7415DN-T1-GE3 SIR818DP-T1-GE3 SI9407BDY-T1-E3 SI4166DY-T1-GE3 SI5432DC-T1-GE3 SI7636DP-T1-E3 SI4850EY-T1-E3 SI4430BDY-T1-E3 SQD40N06-14L_GE3 SI7454DDP-T1-GE3 SI6415DQ-T1-GE3 SI4401BDY-T1-GE3 SI4896DY-T1-E3 SI7655DN-T1-GE3 SIR638DP-T1-GE3 SI7456CDP-T1-GE3 SI6423DQ-T1-GE3 SI4378DY-T1-E3 SIJ482DP-T1-GE3 SI4427BDY-T1-GE3 SI7115DN-T1-GE3 SI7115DN-T1-E3 SI7852DP-T1-E3 SIR402DP-T1-GE3 SI7102DN-T1-E3 SI4465ADY-T1-E3 SIR438DP-T1-GE3 SIR440DP-T1-GE3 SIR878ADP-T1-GE3 SI4408DY-T1-E3 SI4124DY-T1-GE3 SI4455DY-T1-E3 SIR878DP-T1-GE3 SUD35N10-26P-E3 SI7866ADP-T1-E3 SIR846ADP-T1-GE3 SI7469DP-T1-E3 SI7463DP-T1-E3 SI4842BDY-T1-E3 SIR846DP-T1-GE3 SIR882ADP-T1-GE3 SUM40N15-38-E3 SI7172DP-T1-GE3 SIR892DP-T1-GE3 SIR804DP-T1-GE3 SIR872DP-T1-GE3 SI7658ADP-T1-GE3 SI7148DP-T1-GE3 SI7884BDP-T1-E3 SI7852DP-T1-GE3 SQD50P04-13L_GE3 SQD50P04-09L_GE3 SQ4840EY-T1_GE3 SQM120P06-07L_GE3 SUM70040M-GE3 SUM60030E-GE3 SI4442DY-T1-E3 SIE832DF-T1-GE3 SI7431DP-T1-E3 SI7880ADP-T1-E3 SUM60N02-3M9P-E3 SQD50N06-09L_GE3 SUM110P04-05-E3 SUP85N10-10-GE3 SI2305CDS-T1-GE3 SI8465DB-T2-E1 SI8810EDB-T2-E1 SI2302DDS-T1-GE3 SI1441EDH-T1-GE3 SI2343DS-T1-GE3 SIA427ADJ-T1-GE3 SI2307BDS-T1-GE3 SI3459BDV-T1-GE3 SI1400DL-T1-GE3 SI8473EDB-T1-E1 SI3447CDV-T1-GE3 SI2319DS-T1-E3 SIR412DP-T1-GE3 SQ3460EV-T1_GE3 SI7617DN-T1-GE3 SI4436DY-T1-E3 SI4874BDY-T1-E3 SI4686DY-T1-E3 SI7106DN-T1-GE3 SIR466DP-T1-GE3 SISA04DN-T1-GE3 SIS452DN-T1-GE3 SI7112DN-T1-E3 SI7112DN-T1-GE3 SIR166DP-T1-GE3 SI7149DP-T1-GE3 SIR844DP-T1-GE3 SI7850DP-T1-GE3 SI7858BDP-T1-GE3 SIRA02DP-T1-GE3 SI4190ADY-T1-GE3 SIJ420DP-T1-GE3 SUM90N04-3M3P-E3 SI7478DP-T1-E3 SUD35N10-26P-GE3 SUD50N02-06P-E3 SI4126DY-T1-GE3 SIE874DF-T1-GE3 SIR870DP-T1-GE3 SI7738DP-T1-GE3 SQ4401EY-T1_GE3 SUD50P10-43L-E3 SUD50P04-09L-E3 SUM90N03-2M2P-E3 SIE822DF-T1-GE3 2N7002K-T1-E3 2N7002K-T1-GE3 SI2365EDS-T1-GE3 SI2356DS-T1-GE3 SI1308EDL-T1-GE3 SI2307CDS-T1-GE3 SI1021R-T1-GE3 SI2333CDS-T1-E3 SI1022R-T1-GE3 SI2336DS-T1-GE3 SI2309CDS-T1-GE3 SI2319CDS-T1-GE3 SI2323DS-T1-E3 SI3473CDV-T1-GE3 SI4401DDY-T1-GE3 SI4425DDY-T1-GE3 SIA415DJ-T1-GE3 SIA414DJ-T1-GE3 SIA456DJ-T1-GE3 SI4425BDY-T1-E3 SIS434DN-T1-GE3 SI4114DY-T1-GE3 SI7810DN-T1-E3 SIS862DN-T1-GE3 SIS476DN-T1-GE3 SIR422DP-T1-GE3 SI7463ADP-T1-GE3 SI7415DN-T1-E3 SUD50P04-08-GE3 SI7157DP-T1-GE3 SI4838BDY-T1-GE3 SI7884BDP-T1-GE3 SIR414DP-T1-GE3 SIR800DP-T1-GE3 SI7611DN-T1-GE3 SI7461DP-T1-E3 SI7461DP-T1-GE3 SIR872ADP-T1-GE3 SI7370DP-T1-E3 SI7846DP-T1-E3 SIR662DP-T1-GE3 SI7116DN-T1-E3 SI7116DN-T1-GE3 SI7478DP-T1-GE3 SI7450DP-T1-E3 SI7450DP-T1-GE3 SI7137DP-T1-GE3 SI7469DP-T1-GE3 SIR826ADP-T1-GE3 SUD50P06-15L-E3 SIR470DP-T1-GE3 SIR826DP-T1-GE3 SUM90P10-19L-E3 SI1062X-T1-GE3 SI1012CR-T1-GE3 SI8821EDB-T2-E1 SI1401EDH-T1-GE3 SI3460DDV-T1-GE3 SI2333CDS-T1-GE3 SIA449DJ-T1-GE3 SI8489EDB-T2-E1 SIA440DJ-T1-GE3 SIA447DJ-T1-GE3 SI3407DV-T1-GE3 SI2309CDS-T1-E3 SIA453EDJ-T1-GE3 SI5475DDC-T1-GE3 SI9435BDY-T1-E3 SIS435DNT-T1-GE3 SISS23DN-T1-GE3 SIR410DP-T1-GE3 SI4100DY-T1-E3 SI4848DY-T1-GE3 SI4090DY-T1-GE3 SI4630DY-T1-E3 SI4490DY-T1-E3 SI7633DP-T1-GE3 SI7456DDP-T1-GE3 SI4838DY-T1-E3 SI7852ADP-T1-E3 SUD40N10-25-E3 SUM50020EL-GE3 SUM45N25-58-E3 SIA406DJ-T1-GE3 SIRA34DP-T1-GE3 SIB422EDK-T1-GE3 SI1471DH-T1-GE3 SI4162DY-T1-GE3 SI4100DY-T1-GE3 SI4490DY-T1-GE3 SI4413ADY-T1-E3 SI4488DY-T1-GE3 SIA425EDJ-T1-GE3 SI1467DH-T1-GE3 SIS430DN-T1-GE3 SIR436DP-T1-GE3 SI1013CX-T1-GE3 SI2372DS-T1-GE3 SI1078X-T1-GE3 SI3493DDV-T1-GE3 SI1424EDH-T1-GE3 SI5448DU-T1-GE3 SIA441DJ-T1-GE3 SI3473CDV-T1-E3 SI4143DY-T1-GE3 SIR401DP-T1-GE3 SIJA52DP-T1-GE3 SIR606DP-T1-GE3 SIR642DP-T1-GE3 SI7370DP-T1-GE3 SUM70040E-GE3 SUM110N04-2M1P-E3 SI3456DDV-T1-E3 SI8809EDB-T2-E1 SIB488DK-T1-GE3 SI1031X-T1-GE3 SIA477EDJ-T1-GE3 SI3467DV-T1-E3 SI3467DV-T1-GE3 SIB437EDKT-T1-GE3 SI3424BDV-T1-GE3 SIA438EDJ-T1-GE3 SIS612EDNT-T1-GE3 SIA439EDJ-T1-GE3 SI3465DV-T1-E3 SI5458DU-T1-GE3 SI1404BDH-T1-GE3 SI1431DH-T1-E3 SI1431DH-T1-GE3 SI3442BDV-T1-GE3 SI3465DV-T1-GE3 SQ3469EV-T1_GE3 SI1473DH-T1-E3 SI1469DH-T1-GE3 SI4128DY-T1-E3 SQ7002K-T1-GE3 SIS322DNT-T1-GE3 SQ3410EV-T1_GE3 SI5424DC-T1-E3 SI4178DY-T1-E3 SI1467DH-T1-E3 SI3443BDV-T1-GE3 SI1404BDH-T1-E3 SI2316DS-T1-GE3 SI4176DY-T1-E3 SI8416DB-T2-E1 SIS472DN-T1-GE3 SIS439DNT-T1-GE3 SI4196DY-T1-GE3 SI4778DY-T1-E3 SI5414DC-T1-GE3 SI2314EDS-T1-GE3 SUD20N10-66L-GE3 SI3460BDV-T1-GE3 SI7326DN-T1-E3 SI7326DN-T1-GE3 SQS420EN-T1_GE3 SQS482EN-T1_GE3 SI2333DS-T1-GE3 SIR403EDP-T1-GE3 SIB417EDK-T1-GE3 SI4346DY-T1-GE3 SI4491EDY-T1-GE3 SUD23N06-31L-T4-E3 SIR168DP-T1-GE3 SIS424DN-T1-GE3 SI4386DY-T1-GE3 SI5404BDC-T1-GE3 SIJ800DP-T1-GE3 SIR864DP-T1-GE3 SIR664DP-T1-GE3 SI3438DV-T1-E3 SI4431BDY-T1-GE3 SI7810DN-T1-GE3 SI8401DB-T1-E1 SI4668DY-T1-GE3 SI4668DY-T1-E3 SI5441BDC-T1-GE3 SI4168DY-T1-GE3 SI7804DN-T1-E3 SI4116DY-T1-E3 SI7405BDN-T1-E3 SI7804DN-T1-GE3 SUD50N024-09P-E3 SIR670DP-T1-GE3 SI7634BDP-T1-E3 SI4894BDY-T1-E3 SI4890BDY-T1-GE3 SI4890BDY-T1-E3 SI7117DN-T1-GE3 SI4463BDY-T1-GE3 SI5443DC-T1-E3 SI5443DC-T1-GE3 SI8413DB-T1-E1 SI8441DB-T2-E1 SQ4410EY-T1_GE3 SUD23N06-31-T4-GE3 SIR862DP-T1-GE3 SI7114DN-T1-GE3 SI7703EDN-T1-E3 SI6469DQ-T1-GE3 SI7230DN-T1-E3 SI7230DN-T1-GE3 SI7421DN-T1-GE3 SI7806ADN-T1-GE3 SQ4470EY-T1_GE3 SIJ462DP-T1-GE3 SI4426DY-T1-E3 SI4426DY-T1-GE3 SI4430BDY-T1-GE3 SQD25N06-22L_GE3 SI7892BDP-T1-GE3 SI7423DN-T1-GE3 SI3460DV-T1-GE3 SI4158DY-T1-GE3 SI7159DP-T1-GE3 SI4630DY-T1-GE3 SI4384DY-T1-GE3 SUD50N03-09P-GE3 SQD23N06-31L_GE3 SI7686DP-T1-GE3 SI7322DN-T1-E3 SIE878DF-T1-GE3 SQD50N05-11L_GE3 SI4114DY-T1-E3 SI4634DY-T1-GE3 SI4634DY-T1-E3 SIE864DF-T1-GE3 SI4884BDY-T1-GE3 SI4368DY-T1-E3 SI4425BDY-T1-GE3 SIJ458DP-T1-GE3 SI7384DP-T1-GE3 SIR688DP-T1-GE3 SI4124DY-T1-E3 SI4874BDY-T1-GE3 SI7840BDP-T1-GE3 SI4348DY-T1-E3 SI6413DQ-T1-GE3 SI7328DN-T1-GE3 SI7110DN-T1-GE3 SI4626ADY-T1-E3 SI4626ADY-T1-GE3 SI7104DN-T1-E3 SI7328DN-T1-E3 SI7370ADP-T1-GE3 SQR40N10-25_GE3 SUD35N10-26P-T4GE3 SI4866DY-T1-GE3 SI7170DP-T1-GE3 SI7104DN-T1-GE3 SI8401DB-T1-E3 SI7384DP-T1-E3 SI7454DP-T1-GE3 SUD50N04-09H-E3 SI4421DY-T1-GE3 SIE882DF-T1-GE3 SI7636DP-T1-GE3 SQM40N10-30_GE3 SUD50P10-43L-GE3 SI4413ADY-T1-GE3 SI4423DY-T1-GE3 SI7390DP-T1-E3 SI7390DP-T1-GE3 SI4456DY-T1-GE3 SQM47N10-24L_GE3 SI4451DY-T1-E3 SI4451DY-T1-GE3 SI7788DP-T1-GE3 SI4390DY-T1-E3 SI4390DY-T1-GE3 SI7302DN-T1-E3 SIE822DF-T1-E3 SI7194DP-T1-GE3 SI4890DY-T1-GE3 SI7455DP-T1-E3 SI7455DP-T1-GE3 SI7846DP-T1-GE3 SI7342DP-T1-GE3 SUD19N20-90-T4-E3 SQM60N06-15-GE3 SQM50N04-4M1-GE3 SUD50P06-15L-T4-E3 SQM40N15-38_GE3 SI4838DY-T1-GE3 SUD40N10-25-T4-E3 SI4442DY-T1-GE3 SI7374DP-T1-E3 SIE832DF-T1-E3 SI7374DP-T1-GE3 SI7738DP-T1-E3 SUD25N15-52-T4-E3 SI4368DY-T1-GE3 SQM110N05-06L_GE3 SI4408DY-T1-GE3 SI4862DY-T1-E3 SI4862DY-T1-GE3 SIE810DF-T1-E3 SIE812DF-T1-E3 SIE810DF-T1-GE3 SIE812DF-T1-GE3 SQM120N04-1M9_GE3 SQM200N04-1M7L_GE3 SQD40N06-25L-GE3 SQD45N05-20L-GE3 SUD50N06-08H-E3 SUM110N04-04-E3 SIE802DF-T1-E3 SIE802DF-T1-GE3 SQM85N15-19_GE3 SQM120N03-1M5L_GE3 SIE818DF-T1-GE3 SIE808DF-T1-GE3 SI7880ADP-T1-GE3 SI7866ADP-T1-GE3 SI4864DY-T1-E3 SI4864DY-T1-GE3 SQM200N04-1M1L_GE3 SI7868ADP-T1-GE3 SI7862ADP-T1-E3 SI7862ADP-T1-GE3 SUM52N20-39P-E3 SUM110N04-03P-E3 SQD40N10-25_GE3
