I wanted to find out if the p/n 127746 extruded heatsink from Wakefield Vette is clear anodized, or black anodized.
Thank you
Dan
Thank you
Dan
Welcome to the forum.
I believe the Wakefield cut to length aluminum extrusion line are all sold as raw aluminum. The assumption is that the buyer will be cutting it to an application specific length so any desired finish should be applied after cutting.
Hello @TimberGrowLights,
Based on my research, I believe @PaulHutch is correct.
The manufacturer states nothing about a finish on the product. Only that it is extruded aluminum.
