Introduction
When a design or system requires converting a lower voltage to a significantly higher one, a boost converter is the go-to solution. Traditionally, a single-phase boost converter has been used. While it is simple and effective, this topology has limitations—particularly at higher power levels.
A better alternative is the phase-shifted multiphase boost converter. This approach offers higher efficiency at high loads and reduces the demands on both output and input capacitors.
Multiphase boost converter
Switch-mode power supplies based on the boost principle can convert a low voltage into a higher voltage. The classic standard boost topology works by passing pulsed currents through an inductor to raise the output voltage. However, because the load demands a fixed output voltage, the output capacitor (C2) must smooth or average these pulses into a fixed DC level.
To perform this task successfully, boost converter output capacitors typically need to be quite large. They require high capacitance, low equivalent series resistance (ESR), and low equivalent series inductance (ESL).
To reduce this high demand on the output capacitor, it is advisable to design a phase-shifted multiphase boost converter. In this design, two or more boost regulators operate in parallel and are connected to a common output capacitor. Each channel is phase-shifted by 180°, meaning the output capacitor receives energy multiple times per cycle—rather than just once as in a standard topology.
Key Benefits:
- Higher efficiency By dividing the power over several paths, the peak currents per component decrease and thus efficiency increases.
- Reduced ripple current at both the input and output.
- Lower capacitor size requirements and better thermal distribution
- Smaller, more cost-effective passive components.
By spreading the current across multiple paths and reducing component stress, multiphase boost converters enable more compact, efficient, and reliable power designs.
Applicable Part Numbers
| AP3012KTR-G1DITR-ND,AP3012KTR-G1DICT-ND,AP3012KTR-G1DIDKR-ND | AP3012KTR-G1 |
| AP3015KTR-G1DITR-ND,AP3015KTR-G1DICT-ND,AP3015KTR-G1DIDKR-ND | AP3015KTR-G1 |
| AP3012KTR-E1DITR-ND,AP3012KTR-E1DICT-ND,AP3012KTR-E1DIDKR-ND | AP3012KTR-E1 |
| MIC2876-AYMT-TR-ND,MIC2876-AYMT-CT-ND,MIC2876-AYMT-DKR-ND | MIC2876-AYMT-TR |
| AP3015AKTR-G1DITR-ND,AP3015AKTR-G1DICT-ND,AP3015AKTR-G1DIDKR-ND | AP3015AKTR-G1 |
| 576-1729-2-ND,576-1729-1-ND,576-1729-6-ND | MIC2288YD5-TR |
| MCP1640T-I/CHYTR-ND,MCP1640T-I/CHYCT-ND,MCP1640T-I/CHYDKR-ND | MCP1640T-I/CHY |
| MCP16251T-I/CHTR-ND,MCP16251T-I/CHCT-ND,MCP16251T-I/CHDKR-ND | MCP16251T-I/CH |
| MCP1640BT-I/CHYTR-ND,MCP1640BT-I/CHYCT-ND,MCP1640BT-I/CHYDKR-ND | MCP1640BT-I/CHY |
| MCP1640BT-I/MCTR-ND,MCP1640BT-I/MCCT-ND,MCP1640BT-I/MCDKR-ND | MCP1640BT-I/MC |
| 296-TPS61023DRLRTR-ND,296-TPS61023DRLRCT-ND,296-TPS61023DRLRDKR-ND | TPS61023DRLR |
| 576-1076-2-ND,576-1076-1-ND,576-1076-6-ND | MIC2290YML-TR |
| PAM2401SCADJDITR-ND,PAM2401SCADJDICT-ND,PAM2401SCADJDIDKR-ND | PAM2401SCADJ |
| PAM2423AECADJRDITR-ND,PAM2423AECADJRDICT-ND,PAM2423AECADJRDIDKR-ND | PAM2423AECADJR |
| 576-3967-2-ND,576-3967-1-ND,576-3967-6-ND | MIC2250-1YD5-TR |
| 296-17227-2-ND,296-17227-1-ND,296-17227-6-ND | TPS61071DDCR |
| 296-TPS61023DRLTTR-ND,296-TPS61023DRLTCT-ND,296-TPS61023DRLTDKR-ND | TPS61023DRLT |
| 296-32505-2-ND,296-32505-1-ND,296-32505-6-ND | TPS61220DCKR |
| 296-44337-2-ND,296-44337-1-ND,296-44337-6-ND | TPS61046YFFR |
| 296-47674-2-ND,296-47674-1-ND,296-47674-6-ND | TLV61046ADBVR |
| 296-39437-2-ND,296-39437-1-ND,296-39437-6-ND | TPS61240DRVR |
| 296-TPS61021ADSGRTR-ND,296-TPS61021ADSGRCT-ND,296-TPS61021ADSGRDKR-ND | TPS61021ADSGR |
| MIC2877-5.0YFT-TR-ND,MIC2877-5.0YFT-CT-ND,MIC2877-5.0YFT-DKR-ND | MIC2877-5.0YFT-TR |
| 296-29824-2-ND,296-29824-1-ND,296-29824-6-ND | TPS61256YFFR |
| MCP1661T-E/OTTR-ND,MCP1661T-E/OTCT-ND,MCP1661T-E/OTDKR-ND | MCP1661T-E/OT |
| 576-2659-2-ND,576-2659-1-ND,576-2659-6-ND | MIC2296YD5-TR |
| 576-1080-2-ND,576-1080-1-ND,576-1080-6-ND | MIC2295YD5-TR |
| 576-3643-2-ND,576-3643-1-ND,576-3643-6-ND | MIC2253-06YML-TR |
| 296-TPS61099DRVRTR-ND,296-TPS61099DRVRCT-ND,296-TPS61099DRVRDKR-ND | TPS61099DRVR |
| 296-47890-2-ND,296-47890-1-ND,296-47890-6-ND | TPS610994YFFR |
| 576-3258-2-ND,576-3258-1-ND,576-3258-6-ND | MIC2605YML-TR |
| MCP1663T-E/OTTR-ND,MCP1663T-E/OTCT-ND,MCP1663T-E/OTDKR-ND | MCP1663T-E/OT |
| 296-14419-2-ND,296-14419-1-ND,296-14419-6-ND,2156-TPS61045DRBR-ND | TPS61045DRBR |
| 296-38771-2-ND,296-38771-1-ND,296-38771-6-ND | LMR64010XMFX/NOPB |
| 296-35164-2-ND,296-35164-1-ND,296-35164-6-ND | LM27313XMFX/NOPB |
| 893-1181-2-ND,893-1181-1-ND,893-1181-6-ND | XC9140A501MR-G |
| 296-47375-2-ND,296-47375-1-ND,296-47375-6-ND | TPS61230ARNSR |
| 1589-1531-2-ND,1589-1531-1-ND,1589-1531-6-ND | MP1542DK-LF-Z |
| 296-38770-2-ND,296-38770-1-ND,296-38770-6-ND | LMR64010XMF/NOPB |
| LM27313XMF/NOPBTR-ND,LM27313XMF/NOPBCT-ND,LM27313XMF/NOPBDKR-ND | LM27313XMF/NOPB |
| LMR64010XMFE/NOPBTR-ND,LMR64010XMFE/NOPBCT-ND,LMR64010XMFE/NOPBDKR-ND | LMR64010XMFE/NOPB |
| 175-MAX17291BANT+TTR-ND,175-MAX17291BANT+TCT-ND,175-MAX17291BANT+TDKR-ND | MAX17291BANT+T |
| 296-28184-2-ND,296-28184-1-ND,296-28184-6-ND | TPS61240IDRVRQ1 |
| 296-39429-2-ND,296-39429-1-ND,296-39429-6-ND | TPS61085DGKR |
| 296-35166-2-ND,296-35166-1-ND,296-35166-6-ND | LM2731YMFX/NOPB |
| 497-6105-2-ND,497-6105-1-ND,497-6105-6-ND | ST8R00WPUR |
| 296-15752-2-ND,296-15752-1-ND,296-15752-6-ND | TPS61020DRCR |
| 296-27012-2-ND,296-27012-1-ND,296-27012-6-ND | TPS61087DRCR |
| 296-15259-2-ND,296-15259-1-ND,296-15259-6-ND | TPS61090RSAR |
| 296-27017-2-ND,296-27017-1-ND,296-27017-6-ND | TPS61200DRCR |
| 296-47295-2-ND,296-47295-1-ND,296-47295-6-ND | TPS61089RNRR |
| 296-37761-2-ND,296-37761-1-ND,296-37761-6-ND | TPS61230DRCR |
| 296-44498-2-ND,296-44498-1-ND,296-44498-6-ND | TPS61232DRCR |
| LM2733XMF/NOPBTR-ND,LM2733XMF/NOPBCT-ND,LM2733XMF/NOPBDKR-ND | LM2733XMF/NOPB |
| NCP1422MNR2GOSTR-ND,NCP1422MNR2GOSCT-ND,NCP1422MNR2GOSDKR-ND | NCP1422MNR2G |
| 296-TPS61299YBHRTR-ND,296-TPS61299YBHRCT-ND,296-TPS61299YBHRDKR-ND | TPS61299YBHR |
| 296-21663-2-ND,296-21663-1-ND,296-21663-6-ND | TPS61200DRCT |
| MAX17220ELT+TTR-ND,MAX17220ELT+TCT-ND,MAX17220ELT+TDKR-ND | MAX17220ELT+T |
| 1589-1648-2-ND,1589-1648-1-ND,1589-1648-6-ND | MP3431GL-Z |
| 296-37990-2-ND,296-37990-1-ND,296-37990-6-ND | TPS61232DRCT |
| 296-44869-2-ND,296-44869-1-ND,296-44869-6-ND | TPS61099YFFT |
| 296-TPS613783QWRTERQ1TR-ND,296-TPS613783QWRTERQ1CT-ND,296-TPS613783QWRTERQ1DKR-ND | TPS613783QWRTERQ1 |
| 1589-MP3438GTL-ZTR-ND,1589-MP3438GTL-ZCT-ND,1589-MP3438GTL-ZDKR-ND | MP3438GTL-Z |
| 296-TPS61032PWPRTR-ND,296-TPS61032PWPRCT-ND,296-TPS61032PWPRDKR-ND,2156-TPS61032PWPR-ND | TPS61032PWPR |
| 1589-1646-2-ND,1589-1646-1-ND,1589-1646-6-ND | MP3429GL-Z |
| 175-MAX17222ENT+TTR-ND,175-MAX17222ENT+TCT-ND,175-MAX17222ENT+TDKR-ND | MAX17222ENT+T |
| 175-MAX17227AATA+TTR-ND,175-MAX17227AATA+TCT-ND,175-MAX17227AATA+TDKR-ND | MAX17227AATA+T |
| 296-43620-2-ND,296-43620-1-ND,296-43620-6-ND | TPS61088RHLR |
| MAX17222ELT+TTR-ND,MAX17222ELT+TCT-ND,MAX17222ELT+TDKR-ND | MAX17222ELT+T |
| MAX17225ELT+TTR-ND,MAX17225ELT+TCT-ND,MAX17225ELT+TDKR-ND | MAX17225ELT+T |
| 1589-MP3429GL-PTR-ND,1589-MP3429GL-PCT-ND,1589-MP3429GL-PDKR-ND | MP3429GL-P |
| 1589-MP3432GL-ZTR-ND,1589-MP3432GL-ZCT-ND,1589-MP3432GL-ZDKR-ND | MP3432GL-Z |
| 1589-MP3435GL-ZTR-ND,1589-MP3435GL-ZCT-ND,1589-MP3435GL-ZDKR-ND | MP3435GL-Z |
| 296-48313-2-ND,296-48313-1-ND,296-48313-6-ND | TPS611781RNWR |
| MAX1722EZK+TTR-ND,MAX1722EZK+TCT-ND,MAX1722EZK+TDKR-ND | MAX1722EZK+T |
| MAX1724EZK50+TTR-ND,MAX1724EZK50+TCT-ND,MAX1724EZK50+TDKR-ND | MAX1724EZK50+T |
| 296-25778-2-ND,296-25778-1-ND,296-25778-6-ND,2156-TPS61010DGSR-ND | TPS61010DGSR |
| 175-MAX1605EUT+TTR-ND,175-MAX1605EUT+TCT-ND,175-MAX1605EUT+TDKR-ND | MAX1605EUT+T |
| 1589-1643-2-ND,1589-1643-1-ND,1589-1643-6-ND | MP3425DL-LF-Z |
| 296-TPS61288RQQRTR-ND,296-TPS61288RQQRCT-ND,296-TPS61288RQQRDKR-ND | TPS61288RQQR |
| 1589-1644-2-ND,1589-1644-1-ND,1589-1644-6-ND | MP3426DL-LF-Z |
| 505-LT3494AEDDB#TRPBFTR-ND,505-LT3494AEDDB#TRPBFCT-ND,505-LT3494AEDDB#TRPBFDKR-ND | LT3494AEDDB#TRPBF |
| 505-LT3494EDDB#TRMPBFTR-ND,505-LT3494EDDB#TRMPBFCT-ND,505-LT3494EDDB#TRMPBFDKR-ND | LT3494EDDB#TRMPBF |
| 505-LT3494AEDDB#TRMPBFTR-ND,505-LT3494AEDDB#TRMPBFCT-ND,505-LT3494AEDDB#TRMPBFDKR-ND | LT3494AEDDB#TRMPBF |
| MAX1797EUA±ND | MAX1797EUA+ |
| LT3464ETS8#TRPBFTR-ND,LT3464ETS8#TRPBFCT-ND,LT3464ETS8#TRPBFDKR-ND | LT3464ETS8#TRPBF |
| LT3464ETS8#TRMPBFTR-ND,LT3464ETS8#TRMPBFCT-ND,LT3464ETS8#TRMPBFDKR-ND | LT3464ETS8#TRMPBF |
| 505-LT8410EDC-1#TRMPBFTR-ND,505-LT8410EDC-1#TRMPBFCT-ND,505-LT8410EDC-1#TRMPBFDKR-ND | LT8410EDC-1#TRMPBF |
| 505-LT8410EDC#TRMPBFTR-ND,505-LT8410EDC#TRMPBFCT-ND,505-LT8410EDC#TRMPBFDKR-ND | LT8410EDC#TRMPBF |
| LT1618EMS#TRPBFTR-ND,LT1618EMS#TRPBFCT-ND,LT1618EMS#TRPBFDKR-ND | LT1618EMS#TRPBF |
| 505-LT1618EMS#PBF-ND | LT1618EMS#PBF |
| LTC3525ESC6-5#TRPBFTR-ND,LTC3525ESC6-5#TRPBFCT-ND,LTC3525ESC6-5#TRPBFDKR-ND | LTC3525ESC6-5#TRPBF |
| LTC3525ESC6-5#TRMPBFTR-ND,LTC3525ESC6-5#TRMPBFCT-ND,LTC3525ESC6-5#TRMPBFDKR-ND | LTC3525ESC6-5#TRMPBF |
| LTC3525ESC6-3.3#TRMPBFTR-ND,LTC3525ESC6-3.3#TRMPBFCT-ND,LTC3525ESC6-3.3#TRMPBFDKR-ND | LTC3525ESC6-3.3#TRMPBF |
| MAX1676EUB+TR-ND,MAX1676EUB+CT-ND,MAX1676EUB+DKR-ND | MAX1676EUB+T |
| 505-LT1618EDD#TRPBFTR-ND,505-LT1618EDD#TRPBFCT-ND,505-LT1618EDD#TRPBFDKR-ND | LT1618EDD#TRPBF |
| 505-LT3461AES6#TRMPBFTR-ND,505-LT3461AES6#TRMPBFCT-ND,505-LT3461AES6#TRMPBFDKR-ND | LT3461AES6#TRMPBF |
| 505-LT3461ES6#TRMPBFTR-ND,505-LT3461ES6#TRMPBFCT-ND,505-LT3461ES6#TRMPBFDKR-ND | LT3461ES6#TRMPBF |
| 505-LT3461AES6#TRPBFTR-ND,505-LT3461AES6#TRPBFCT-ND,505-LT3461AES6#TRPBFDKR-ND | LT3461AES6#TRPBF |
| LTC3526LBEDC-2#TRMPBFTR-ND,LTC3526LBEDC-2#TRMPBFCT-ND,LTC3526LBEDC-2#TRMPBFDKR-ND | LTC3526LBEDC-2#TRMPBF |
| LTC3526LBEDC#TRPBFTR-ND,LTC3526LBEDC#TRPBFCT-ND,LTC3526LBEDC#TRPBFDKR-ND | LTC3526LBEDC#TRPBF |
| 505-LTC3526LEDC#TRMPBFTR-ND,505-LTC3526LEDC#TRMPBFCT-ND,505-LTC3526LEDC#TRMPBFDKR-ND | LTC3526LEDC#TRMPBF |
| MAX1676EUB±ND | MAX1676EUB+ |
| LTC3528EDDB#TRMPBFTR-ND,LTC3528EDDB#TRMPBFCT-ND,LTC3528EDDB#TRMPBFDKR-ND | LTC3528EDDB#TRMPBF |
| 505-LTC3400ES6#TRMPBFTR-ND,505-LTC3400ES6#TRMPBFCT-ND,505-LTC3400ES6#TRMPBFDKR-ND | LTC3400ES6#TRMPBF |
| 505-LT8410IDC#TRMPBFTR-ND,505-LT8410IDC#TRMPBFCT-ND,505-LT8410IDC#TRMPBFDKR-ND | LT8410IDC#TRMPBF |
| 505-LTC3429BES6#TRMPBFTR-ND,505-LTC3429BES6#TRMPBFCT-ND,505-LTC3429BES6#TRMPBFDKR-ND | LTC3429BES6#TRMPBF |
| LT3473EDD#TRPBFTR-ND,LT3473EDD#TRPBFCT-ND,LT3473EDD#TRPBFDKR-ND | LT3473EDD#TRPBF |
| LTC3125EDCB#TRMPBFTR-ND,LTC3125EDCB#TRMPBFCT-ND,LTC3125EDCB#TRMPBFDKR-ND | LTC3125EDCB#TRMPBF |
| 505-LT8337EV-1#PBF-ND | LT8337EV-1#PBF |
| LTC3122EDE#PBF-ND | LTC3122EDE#PBF |
| 505-LTC3122EDE#TRPBFTR-ND,505-LTC3122EDE#TRPBFCT-ND,505-LTC3122EDE#TRPBFDKR-ND | LTC3122EDE#TRPBF |
| 505-LT8337JV#PBF-ND | LT8337JV#PBF |
| LTC3539EDCB#TRPBFTR-ND,LTC3539EDCB#TRPBFCT-ND,LTC3539EDCB#TRPBFDKR-ND | LTC3539EDCB#TRPBF |
| LTC3539EDCB#TRMPBFTR-ND,LTC3539EDCB#TRMPBFCT-ND,LTC3539EDCB#TRMPBFDKR-ND | LTC3539EDCB#TRMPBF |
| LTC3539EDCB-2#TRMPBFTR-ND,LTC3539EDCB-2#TRMPBFCT-ND,LTC3539EDCB-2#TRMPBFDKR-ND | LTC3539EDCB-2#TRMPBF |
| 505-LT8336EV#PBF-ND | LT8336EV#PBF |
| 505-LT8336JV#PBF-ND | LT8336JV#PBF |
| 505-LTC3122IDE#TRPBFTR-ND,505-LTC3122IDE#TRPBFCT-ND,505-LTC3122IDE#TRPBFDKR-ND | LTC3122IDE#TRPBF |
| 505-LT8336EV#WPBF-ND | LT8336EV#WPBF |
| LT1310EMSE#PBF-ND | LT1310EMSE#PBF |
| 505-LT8336HV#PBF-ND | LT8336HV#PBF |
| 175-MAX1709EUI+TTR-ND,175-MAX1709EUI+TCT-ND,MAX1709EUI+TCT-ND,MAX1709EUI+TDKR-ND,175-MAX1709EUI+TDKR-ND | MAX1709EUI+T |
| LT1303CS8#PBF-ND | LT1303CS8#PBF |
| LTC3124EDHC#TRPBFTR-ND,LTC3124EDHC#TRPBFCT-ND,LTC3124EDHC#TRPBFDKR-ND | LTC3124EDHC#TRPBF |
| 505-LTC3124EFE#TRPBFTR-ND,505-LTC3124EFE#TRPBFCT-ND,505-LTC3124EFE#TRPBFDKR-ND | LTC3124EFE#TRPBF |
| LTC3458LEDE#PBF-ND | LTC3458LEDE#PBF |
| MAX1705EEE±ND | MAX1705EEE+ |
| 505-LTC3458EDE#PBF-ND | LTC3458EDE#PBF |
| 175-MAX1705EEE+TTR-ND,175-MAX1705EEE+TCT-ND,175-MAX1705EEE+TDKR-ND | MAX1705EEE+T |
| LTC3421EUF#TRPBFTR-ND,LTC3421EUF#TRPBFCT-ND,LTC3421EUF#TRPBFDKR-ND | LTC3421EUF#TRPBF |
| LTC3428EDD#TRPBFTR-ND,LTC3428EDD#TRPBFCT-ND,LTC3428EDD#TRPBFDKR-ND | LTC3428EDD#TRPBF |
| 505-LTC3428EDD#PBF-ND | LTC3428EDD#PBF |
| MAX1708EEE±ND | MAX1708EEE+ |
| MAX1709ESE±ND | MAX1709ESE+ |
| 296-52012-2-ND,296-52012-1-ND,296-52012-6-ND | TPS613226ADBVR |
| 296-50503-2-ND,296-50503-1-ND,296-50503-6-ND | TPS613222ADBVR |
| 296-50502-2-ND,296-50502-1-ND,296-50502-6-ND | TPS613221ADBVR |
| 296-TLV61070ADBVRTR-ND,296-TLV61070ADBVRCT-ND,296-TLV61070ADBVRDKR-ND | TLV61070ADBVR |
| 3757-PJ30072S6_R1_00301TR-ND,3757-PJ30072S6_R1_00301CT-ND,3757-PJ30072S6_R1_00301DKR-ND | PJ30072S6_R1_00301 |
| 1028-RT9261B-50GBTR-ND,1028-RT9261B-50GBCT-ND,1028-RT9261B-50GBDKR-ND | RT9261B-50GB |
| 150-MIC2876-5.0YMT-TR-ND,150-MIC2876-5.0YMT-TRCT-ND,150-MIC2876-5.0YMT-TRDKR-ND | MIC2876-5.0YMT-TR |
| 296-TLV61048DBVRTR-ND,296-TLV61048DBVRCT-ND,296-TLV61048DBVRDKR-ND | TLV61048DBVR |
| 576-3655-2-ND,576-3655-1-ND,576-3655-6-ND | MIC2619YD6-TR |
| MCP1640CT-I/CHYTR-ND,MCP1640CT-I/CHYCT-ND,MCP1640CT-I/CHYDKR-ND | MCP1640CT-I/CHY |
| MCP1640DT-I/CHYTR-ND,MCP1640DT-I/CHYCT-ND,MCP1640DT-I/CHYDKR-ND | MCP1640DT-I/CHY |
| PAM2421AECADJRDITR-ND,PAM2421AECADJRDICT-ND,PAM2421AECADJRDIDKR-ND | PAM2421AECADJR |
| MCP1640T-I/MCTR-ND,MCP1640T-I/MCCT-ND,MCP1640T-I/MCDKR-ND | MCP1640T-I/MC |
| 576-1075-2-ND,576-1075-1-ND,576-1075-6-ND | MIC2288YML-TR |
| 296-30547-2-ND,296-30547-1-ND,296-30547-6-ND | TLV61220DBVR |
| 576-3968-2-ND,576-3968-1-ND,576-3968-6-ND | MIC2250-2YD5-TR |
| 296-49468-2-ND,296-49468-1-ND,296-49468-6-ND | TPS613222ADBVT |
| 296-49467-2-ND,296-49467-1-ND,296-49467-6-ND | TPS613221ADBVT |
| 296-36756-2-ND,296-36756-1-ND,296-36756-6-ND | TLV61225DCKR |
| 576-3992-2-ND,576-3992-1-ND,576-3992-6-ND | MIC2251-1YD5-TR |
| 576-3993-2-ND,576-3993-1-ND,576-3993-6-ND | MIC2251-2YD5-TR |
| 296-17151-2-ND,296-17151-1-ND,296-17151-6-ND,2156-TPS61070DDCR-ND | TPS61070DDCR |
| 296-TPS610333DRLRTR-ND,296-TPS610333DRLRCT-ND,296-TPS610333DRLRDKR-ND | TPS610333DRLR |
| 576-3302-2-ND,576-3302-1-ND,576-3302-6-ND | MIC2250YML-TR |
| 296-41854-2-ND,296-41854-1-ND,296-41854-6-ND | TPS61221DCKR |
| 296-39435-2-ND,296-39435-1-ND,296-39435-6-ND | TPS61222DCKR |
| 296-28782-2-ND,296-28782-1-ND,296-28782-6-ND | TPS61260DRVR |
| 296-48314-2-ND,296-48314-1-ND,296-48314-6-ND | TPS61253AYFFR |
| MCP1642D-ADJI/MS-ND | MCP1642D-ADJI/MS |
| MCP1642B-50I/MS-ND | MCP1642B-50I/MS |
| 576-3994-2-ND,576-3994-1-ND,576-3994-6-ND | MIC2251YML-TR |
| MIC2877-AYFT-TR-ND,MIC2877-AYFT-CT-ND,MIC2877-AYFT-DKR-ND | MIC2877-AYFT-TR |
| 2129-R1207N823B-TR-FETR-ND,2129-R1207N823B-TR-FECT-ND,2129-R1207N823B-TR-FEDKR-ND | R1207N823B-TR-FE |
| 296-27690-2-ND,296-27690-1-ND,296-27690-6-ND | TPS61071TDDCRQ1 |
| 2129-R1218N021A-TR-FETR-ND,2129-R1218N021A-TR-FECT-ND,2129-R1218N021A-TR-FEDKR-ND | R1218N021A-TR-FE |
| 2129-R1218N041A-TR-FETR-ND,2129-R1218N041A-TR-FECT-ND,2129-R1218N041A-TR-FEDKR-ND | R1218N041A-TR-FE |
| MCP1661T-E/MNYTR-ND,MCP1661T-E/MNYCT-ND,MCP1661T-E/MNYDKR-ND | MCP1661T-E/MNY |
| 296-24172-2-ND,296-24172-1-ND,296-24172-6-ND | TPS61222DCKT |
| 296-24170-2-ND,296-24170-1-ND,296-24170-6-ND | TPS61220DCKT |
| 296-46927-2-ND,296-46927-1-ND,296-46927-6-ND | TLV61046ADBVT |
| 296-42070-2-ND,296-42070-1-ND,296-42070-6-ND | TPS61046YFFT |
| 296-TPS61033DRLRTR-ND,296-TPS61033DRLRCT-ND,296-TPS61033DRLRDKR-ND | TPS61033DRLR |
| 296-24519-2-ND,296-24519-1-ND,296-24519-6-ND | TPS61240DRVT |
| 296-47889-2-ND,296-47889-1-ND,296-47889-6-ND | TPS61096ADSSR |
| 296-46241-2-ND,296-46241-1-ND,296-46241-6-ND | TPS61021ADSGT |
| 2129-RP402N501F-TR-FETR-ND,2129-RP402N501F-TR-FECT-ND,2129-RP402N501F-TR-FEDKR-ND | RP402N501F-TR-FE |
| 296-46614-2-ND,296-46614-1-ND,296-46614-6-ND | TPS61253AYFFT |
| 296-49213-2-ND,296-49213-1-ND,296-49213-6-ND | LM4510SDX/NOPB |
| 296-47374-2-ND,296-47374-1-ND,296-47374-6-ND | TPS61099YFFR |
| 296-50423-2-ND,296-50423-1-ND,296-50423-6-ND | TPS610995DRVR |
| 576-3283-2-ND,576-3283-1-ND,576-3283-6-ND | MIC2601YML-TR |
| 296-37571-2-ND,296-37571-1-ND,296-37571-6-ND | LM2623MMX/NOPB |
| 296-44399-2-ND,296-44399-1-ND,296-44399-6-ND | TPS61291DRVR |
| MCP1663T-E/MNYTR-ND,MCP1663T-E/MNYCT-ND,MCP1663T-E/MNYDKR-ND | MCP1663T-E/MNY |
| 296-47891-2-ND,296-47891-1-ND,296-47891-6-ND | TPS610997YFFR |
| 296-TPS610333QDRLRQ1TR-ND,296-TPS610333QDRLRQ1CT-ND,296-TPS610333QDRLRQ1DKR-ND | TPS610333QDRLRQ1 |
| FAN48610UC50XTR-ND,FAN48610UC50XCT-ND,FAN48610UC50XDKR-ND | FAN48610UC50X |
| 296-35167-2-ND,296-35167-1-ND,296-35167-6-ND | LM2733YMFX/NOPB |
| LM4510SD/NOPBTR-ND,LM4510SD/NOPBCT-ND,LM4510SD/NOPBDKR-ND | LM4510SD/NOPB |
| 296-TPS61288LRQQRTR-ND,296-TPS61288LRQQRCT-ND,296-TPS61288LRQQRDKR-ND | TPS61288LRQQR |
| MAX5026EUT+TTR-ND,MAX5026EUT+TCT-ND,MAX5026EUT+TDKR-ND | MAX5026EUT+T |
| 1589-MP3437GRP-ZTR-ND,1589-MP3437GRP-ZCT-ND,1589-MP3437GRP-ZDKR-ND | MP3437GRP-Z |
| 1589-MP3437GJ-ZTR-ND,1589-MP3437GJ-ZCT-ND,1589-MP3437GJ-ZDKR-ND | MP3437GJ-Z |
| 893-1180-2-ND,893-1180-1-ND,893-1180-6-ND | XC9140A331MR-G |
| LM2733XMFX/NOPBTR-ND,LM2733XMFX/NOPBCT-ND,LM2733XMFX/NOPBDKR-ND | LM2733XMFX/NOPB |
| LM2623AMM/NOPBTR-ND,LM2623AMM/NOPBCT-ND,LM2623AMM/NOPBDKR-ND | LM2623AMM/NOPB |
| LM2623MM/NOPBTR-ND,LM2623MM/NOPBCT-ND,LM2623MM/NOPBDKR-ND | LM2623MM/NOPB |
| 296-38435-2-ND,296-38435-1-ND,296-38435-6-ND | TPS61291DRVT |
| 1589-1640-2-ND,1589-1640-1-ND,1589-1640-6-ND | MP3421GG-Z |
| 296-44398-2-ND,296-44398-1-ND,296-44398-6-ND | TPS61097A-33DBVR |
| 296-LM27313XQMFX/NOPBTR-ND,296-LM27313XQMFX/NOPBCT-ND,296-LM27313XQMFX/NOPBDKR-ND | LM27313XQMFX/NOPB |
| 296-23551-2-ND,296-23551-1-ND,296-23551-6-ND | TPS61085PWR |
| 893-1371-2-ND,893-1371-1-ND,893-1371-6-ND | XC9142B33CMR-G |
| 893-1373-2-ND,893-1373-1-ND,893-1373-6-ND | XC9142B50CMR-G |
| 296-TPS61022RWUTTR-ND,296-TPS61022RWUTCT-ND,296-TPS61022RWUTDKR-ND | TPS61022RWUT |
| 296-18078-2-ND,296-18078-1-ND,296-18078-6-ND | TPS61028DRCR |
| 296-37680-2-ND,296-37680-1-ND,296-37680-6-ND | TPS61086DRCR |
| 1589-1641-2-ND,1589-1641-1-ND,1589-1641-6-ND | MP3422GG-Z |
| 296-TPS61240TDRVRQ1TR-ND,296-TPS61240TDRVRQ1CT-ND,296-TPS61240TDRVRQ1DKR-ND | TPS61240TDRVRQ1 |
| 296-TPS61287RZPRTR-ND,296-TPS61287RZPRCT-ND,296-TPS61287RZPRDKR-ND | TPS61287RZPR |
| MCP1665T-E/MRATR-ND,MCP1665T-E/MRACT-ND,MCP1665T-E/MRADKR-ND | MCP1665T-E/MRA |
| 296-47377-2-ND,296-47377-1-ND,296-47377-6-ND | TPS61236PRWLR |
| 296-35404-2-ND,296-35404-1-ND,296-35404-6-ND | LM2622MMX-ADJ/NOPB |
| 296-36998-2-ND,296-36998-1-ND,296-36998-6-ND | TPS61085TDGKR |
| 296-47376-2-ND,296-47376-1-ND,296-47376-6-ND | TPS61235PRWLR |
| 296-27314-2-ND,296-27314-1-ND,296-27314-6-ND | TPS61087DSCR |
| 296-39430-2-ND,296-39430-1-ND,296-39430-6-ND | TPS61093DSKR |
| 296-TPS61033QDRLRQ1TR-ND,296-TPS61033QDRLRQ1CT-ND,296-TPS61033QDRLRQ1DKR-ND | TPS61033QDRLRQ1 |
| 296-15754-2-ND,296-15754-1-ND,296-15754-6-ND | TPS61027DRCR |
| 1589-MP3437GJ-PTR-ND,1589-MP3437GJ-PCT-ND,1589-MP3437GJ-PDKR-ND | MP3437GJ-P |
| LMR61428XMM/NOPBTR-ND,LMR61428XMM/NOPBCT-ND,LMR61428XMM/NOPBDKR-ND | LMR61428XMM/NOPB |
| 296-38998-2-ND,296-38998-1-ND,296-38998-6-ND | LM27313XQMF/NOPB |
| 296-15240-2-ND,296-15240-1-ND,296-15240-6-ND,2156-TPS61092RSAR-ND | TPS61092RSAR |
| ISL9111EH50Z-T7ATR-ND,ISL9111EH50Z-T7ACT-ND,ISL9111EH50Z-T7ADKR-ND | ISL9111EH50Z-T7A |
| 1589-MP3216GJE-ZTR-ND,1589-MP3216GJE-ZCT-ND,1589-MP3216GJE-ZDKR-ND | MP3216GJE-Z |
| 296-23550-2-ND,296-23550-1-ND,296-23550-6-ND | TPS61085DGKT |
| 296-27462-2-ND,296-27462-1-ND,296-27462-6-ND | TPS61202DRCR |
| 296-44338-2-ND,296-44338-1-ND,296-44338-6-ND | TPS61201DRCR |
| 2129-NJW4132U2-B-TE2TR-ND,2129-NJW4132U2-B-TE2CT-ND,2129-NJW4132U2-B-TE2DKR-ND | NJW4132U2-B-TE2 |
| 296-44628-2-ND,296-44628-1-ND,296-44628-6-ND | TPS61235PRWLT |
| LM2622MM-ADJ/NOPBTR-ND,LM2622MM-ADJ/NOPBCT-ND,LM2622MM-ADJ/NOPBDKR-ND | LM2622MM-ADJ/NOPB |
| 296-44629-2-ND,296-44629-1-ND,296-44629-6-ND | TPS61236PRWLT |
| 296-25245-2-ND,296-25245-1-ND,296-25245-6-ND | TPS61093DSKT |
| 175-MAX17291ANT+TTR-ND,175-MAX17291ANT+TCT-ND,175-MAX17291ANT+TDKR-ND | MAX17291ANT+T |
| LM2733YMF/NOPBTR-ND,LM2733YMF/NOPBCT-ND,LM2733YMF/NOPBDKR-ND | LM2733YMF/NOPB |
| 497-5241-2-ND,497-5241-1-ND,497-5241-6-ND | L6920DBTR |
| 175-MAX17220ENT+TTR-ND,175-MAX17220ENT+TCT-ND,175-MAX17220ENT+TDKR-ND | MAX17220ENT+T |
| 175-MAX17227JANT+TTR-ND,175-MAX17227JANT+TCT-ND,175-MAX17227JANT+TDKR-ND | MAX17227JANT+T |
| 1589-1637-2-ND,1589-1637-1-ND,1589-1637-6-ND | MP3414AGJ-Z |
| LM2731YMF/NOPBTR-ND,LM2731YMF/NOPBCT-ND,LM2731YMF/NOPBDKR-ND | LM2731YMF/NOPB |
| 296-TPS612994YBHRTR-ND,296-TPS612994YBHRCT-ND,296-TPS612994YBHRDKR-ND | TPS612994YBHR |
| 296-TPS61299ADRLRTR-ND,296-TPS61299ADRLRCT-ND,296-TPS61299ADRLRDKR-ND | TPS61299ADRLR |
| 497-6106-2-ND,497-6106-1-ND,497-6106-6-ND | L6920DCTR |
| 5503-TPQ80302-QF6R-STR-ND,5503-TPQ80302-QF6R-SCT-ND,5503-TPQ80302-QF6R-SDKR-ND | TPQ80302-QF6R-S |
| 296-21685-2-ND,296-21685-1-ND,296-21685-6-ND | TPS61202DRCT |
| 1589-1858-2-ND,1589-1858-1-ND,1589-1858-6-ND | MP1541DJ-LF-Z |
| 175-MAX17220ALT+TTR-ND,175-MAX17220ALT+TCT-ND,175-MAX17220ALT+TDKR-ND | MAX17220ALT+T |
| 505-MAX20474ATDA/V±ND | MAX20474ATDA/V+ |
| 1589-MP3414EGJ-ZTR-ND,1589-MP3414EGJ-ZCT-ND,1589-MP3414EGJ-ZDKR-ND | MP3414EGJ-Z |
| 1589-1904-2-ND,1589-1904-1-ND,1589-1904-6-ND | MP3120DJ-LF-Z |
| 175-MAX17291ATA+TTR-ND,175-MAX17291ATA+TCT-ND,175-MAX17291ATA+TDKR-ND | MAX17291ATA+T |
| 296-14416-2-ND,296-14416-1-ND,296-14416-6-ND | TPS61030PWPR |
| 1028-1512-2-ND,1028-1512-1-ND,1028-1512-6-ND | RT4812GJ8F |
| 296-49493-2-ND,296-49493-1-ND,296-49493-6-ND | TPS610995DRVT |
| 296-TPS613771RYHRTR-ND,296-TPS613771RYHRCT-ND,296-TPS613771RYHRDKR-ND | TPS613771RYHR |
| 296-TPS61376RYHRTR-ND,296-TPS61376RYHRCT-ND,296-TPS61376RYHRDKR-ND | TPS61376RYHR |
| 296-TPS61377RYHRTR-ND,296-TPS61377RYHRCT-ND,296-TPS61377RYHRDKR-ND | TPS61377RYHR |
| 175-MAX17221ENT+TTR-ND,175-MAX17221ENT+TCT-ND,175-MAX17221ENT+TDKR-ND | MAX17221ENT+T |
| 1589-1916-2-ND,1589-1916-1-ND,1589-1916-6-ND | MP3410DJ-LF-Z |
| 296-TPS61378QWRTERQ1TR-ND,296-TPS61378QWRTERQ1CT-ND,296-TPS61378QWRTERQ1DKR-ND | TPS61378QWRTERQ1 |
| 296-46242-2-ND,296-46242-1-ND,296-46242-6-ND | TPS61089RNRT |
| 296-TPS61391RTERTR-ND,296-TPS61391RTERCT-ND,296-TPS61391RTERDKR-ND | TPS61391RTER |
| 1589-1642-2-ND,1589-1642-1-ND,1589-1642-6-ND | MP3423GG-Z |
| MAX17223ELT+TTR-ND,MAX17223ELT+TCT-ND,MAX17223ELT+TDKR-ND | MAX17223ELT+T |
| LM3224MM-ADJ/NOPBTR-ND,LM3224MM-ADJ/NOPBCT-ND,LM3224MM-ADJ/NOPBDKR-ND | LM3224MM-ADJ/NOPB |
| 175-MAX17221ELT+TTR-ND,175-MAX17221ELT+TCT-ND,175-MAX17221ELT+TDKR-ND | MAX17221ELT+T |
| 175-MAX17227AANT+TTR-ND,175-MAX17227AANT+TCT-ND,175-MAX17227AANT+TDKR-ND | MAX17227AANT+T |
| 296-TPS61299QDRLRQ1TR-ND,296-TPS61299QDRLRQ1CT-ND,296-TPS61299QDRLRQ1DKR-ND | TPS61299QDRLRQ1 |
| 1589-MP3438GTL-PTR-ND,1589-MP3438GTL-PCT-ND,1589-MP3438GTL-PDKR-ND | MP3438GTL-P |
| 1589-1171-2-ND,1589-1171-1-ND,1589-1171-6-ND | MP3423GG-P |
| MAX8815AETB+TTR-ND,MAX8815AETB+TCT-ND,MAX8815AETB+TDKR-ND | MAX8815AETB+T |
| 296-35267-2-ND,296-35267-1-ND,296-35267-6-ND | LM2700MTX-ADJ/NOPB |
| 296-TPS61372YKBRTR-ND,296-TPS61372YKBRCT-ND,296-TPS61372YKBRDKR-ND | TPS61372YKBR |
| 1589-1625-2-ND,1589-1625-1-ND,1589-1625-6-ND | MP3213DH-LF-P |
| 2156-TL499ACP-ND,296-36042-5-ND | TL499ACP |
| 296-50115-2-ND,296-50115-1-ND,296-50115-6-ND | TPS61178RNWR |
| 1589-1647-2-ND,1589-1647-1-ND,1589-1647-6-ND | MP3430HQ-LF-Z |
| ADP1614ACPZ-1.3-R7TR-ND,ADP1614ACPZ-1.3-R7CT-ND,ADP1614ACPZ-1.3-R7DKR-ND | ADP1614ACPZ-1.3-R7 |
| MAX1724EZK33+TTR-ND,MAX1724EZK33+TCT-ND,MAX1724EZK33+TDKR-ND | MAX1724EZK33+T |
| 296-53052-2-ND,296-53052-1-ND,296-53052-6-ND | TPS61372YKBT |
| MAX1674EUA±ND | MAX1674EUA+ |
| 296-42129-2-ND,296-42129-1-ND,296-42129-6-ND | TPS61088RHLT |
| LT3494EDDB#TRPBFTR-ND,LT3494EDDB#TRPBFCT-ND,LT3494EDDB#TRPBFDKR-ND | LT3494EDDB#TRPBF |
| 2156-TPS61016DGS-ND,296-10975-5-ND | TPS61016DGS |
| 1589-MPQ3425DL-AEC1-LF-ZTR-ND,1589-MPQ3425DL-AEC1-LF-ZCT-ND,1589-MPQ3425DL-AEC1-LF-ZDKR-ND | MPQ3425DL-AEC1-LF-Z |
| MAX1834EUT+TTR-ND,MAX1834EUT+TCT-ND,MAX1834EUT+TDKR-ND | MAX1834EUT+T |
| 175-MAX17250ATD+TTR-ND,175-MAX17250ATD+TCT-ND,175-MAX17250ATD+TDKR-ND | MAX17250ATD+T |
| MAX1674EUA+TR-ND,MAX1674EUA+CT-ND,MAX1674EUA+DKR-ND | MAX1674EUA+T |
| 1589-MPQ3426DL-LF-ZTR-ND,1589-MPQ3426DL-LF-ZCT-ND,1589-MPQ3426DL-LF-ZDKR-ND | MPQ3426DL-LF-Z |
| MAX1797EUA+TTR-ND,MAX1797EUA+TCT-ND,MAX1797EUA+TDKR-ND | MAX1797EUA+T |
| LT1946EMS8#PBF-ND | LT1946EMS8#PBF |
| 1589-1787-2-ND,1589-1787-1-ND,1589-1787-6-ND | MPQ3426DL-AEC1-LF-Z |
| LT1618EDD#PBF-ND | LT1618EDD#PBF |
| LTC3525DESC6-3.3#TRMPBFTR-ND,LTC3525DESC6-3.3#TRMPBFCT-ND,LTC3525DESC6-3.3#TRMPBFDKR-ND | LTC3525DESC6-3.3#TRMPBF |
| 296-3225-2-ND,296-3225-1-ND,296-3225-6-ND | TPS6734IDR |
| LTC3121EDE#PBF-ND | LTC3121EDE#PBF |
| 505-LT8338EMSE#TRPBFTR-ND,505-LT8338EMSE#TRPBFCT-ND,505-LT8338EMSE#TRPBFDKR-ND | LT8338EMSE#TRPBF |
| MAX1675EUA+TR-ND,MAX1675EUA+CT-ND,MAX1675EUA+DKR-ND | MAX1675EUA+T |
| LT3489EMS8E#TRPBFTR-ND,LT3489EMS8E#TRPBFCT-ND,LT3489EMS8E#TRPBFDKR-ND | LT3489EMS8E#TRPBF |
| LTC3426ES6#TRMPBFTR-ND,LTC3426ES6#TRMPBFCT-ND,LTC3426ES6#TRMPBFDKR-ND | LTC3426ES6#TRMPBF |
| 161-LTC3529EDCB#TRPBFTR-ND,161-LTC3529EDCB#TRPBFCT-ND,161-LTC3529EDCB#TRPBFDKR-ND | LTC3529EDCB#TRPBF |
| LTC3529EDCB#TRMPBFTR-ND,LTC3529EDCB#TRMPBFCT-ND,LTC3529EDCB#TRMPBFDKR-ND | LTC3529EDCB#TRMPBF |
| MAX1675EUA±ND | MAX1675EUA+ |
| 505-LTC3499BEMS8#PBF-ND | LTC3499BEMS8#PBF |
| LT1307CS8#PBF-ND | LT1307CS8#PBF |
| LTC3401EMS#PBF-ND | LTC3401EMS#PBF |
| LTC3400BES6#TRMPBFTR-ND,LTC3400BES6#TRMPBFCT-ND,LTC3400BES6#TRMPBFDKR-ND | LTC3400BES6#TRMPBF |
| LTC3459ES6#TRPBFTR-ND,LTC3459ES6#TRPBFCT-ND,LTC3459ES6#TRPBFDKR-ND | LTC3459ES6#TRPBF |
| 505-LTC3459ES6#TRMPBFTR-ND,505-LTC3459ES6#TRMPBFCT-ND,505-LTC3459ES6#TRMPBFDKR-ND | LTC3459ES6#TRMPBF |
| LT3571EUD#TRPBFTR-ND,LT3571EUD#TRPBFCT-ND,LT3571EUD#TRPBFDKR-ND | LT3571EUD#TRPBF |
| 505-LT3571EUD#PBF-ND | LT3571EUD#PBF |
| 505-LTC3125EDCB#TRPBFTR-ND,505-LTC3125EDCB#TRPBFCT-ND,505-LTC3125EDCB#TRPBFDKR-ND | LTC3125EDCB#TRPBF |
| LTC3290EMSE#PBF-ND | LTC3290EMSE#PBF |
| 505-LT8337EV#PBF-ND | LT8337EV#PBF |
| LTC3122EMSE#TRPBFTR-ND,LTC3122EMSE#TRPBFCT-ND,LTC3122EMSE#TRPBFDKR-ND | LTC3122EMSE#TRPBF |
| MAX641ACSA±ND | MAX641ACSA+ |
| LTC3422EDD#PBF-ND | LTC3422EDD#PBF |
| 505-LT8337JV-1#PBF-ND | LT8337JV-1#PBF |
| LT3571IUD#TRPBFTR-ND,LT3571IUD#TRPBFCT-ND,LT3571IUD#TRPBFDKR-ND | LT3571IUD#TRPBF |
| 161-LT3905EUD#TRPBFTR-ND,161-LT3905EUD#TRPBFCT-ND,161-LT3905EUD#TRPBFDKR-ND | LT3905EUD#TRPBF |
| LTC3124EDHC#PBF-ND | LTC3124EDHC#PBF |
| 505-LTC3122IDE#PBF-ND | LTC3122IDE#PBF |
| LTC3122IMSE#PBF-ND | LTC3122IMSE#PBF |
| MAX756ESA±ND | MAX756ESA+ |
| LT1109ACS8-12#PBF-ND | LT1109ACS8-12#PBF |
| 505-LT1301CS8#PBF-ND | LT1301CS8#PBF |
| 505-LTC3124EFE#PBF-ND | LTC3124EFE#PBF |
| 175-MAX1796EUA+TTR-ND,175-MAX1796EUA+TCT-ND,175-MAX1796EUA+TDKR-ND | MAX1796EUA+T |
| LTC3402EMS#TRPBFTR-ND,LTC3402EMS#TRPBFCT-ND,LTC3402EMS#TRPBFDKR-ND | LTC3402EMS#TRPBF |
| LTC3402EMS#PBF-ND | LTC3402EMS#PBF |
| LT1305CS8#PBF-ND | LT1305CS8#PBF |
| MAX618EEE+TTR-ND,MAX618EEE+TCT-ND,MAX618EEE+TDKR-ND | MAX618EEE+T |
| MAX618EEE±ND | MAX618EEE+ |
| MAX643AESA±ND | MAX643AESA+ |
| 505-LT1302CS8#PBF-ND | LT1302CS8#PBF |
| 296-52013-2-ND,296-52013-1-ND,296-52013-6-ND | TPS61322DBZR |
| 1028-RT9266BGETR-ND,1028-RT9266BGECT-ND,1028-RT9266BGEDKR-ND | RT9266BGE |
| 150-MIC2876-5.25YMT-TR-ND,150-MIC2876-5.25YMT-TRCT-ND,150-MIC2876-5.25YMT-TRDKR-ND | MIC2876-5.25YMT-TR |
| AP6714M10GDITR-ND,AP6714M10GDICT-ND,AP6714M10GDIDKR-ND | AP6714M10G-13 |
| 31-AP72250CJ12-7TR-ND,31-AP72250CJ12-7CT-ND,31-AP72250CJ12-7DKR-ND | AP72250CJ12-7 |
| 576-3259-2-ND,576-3259-1-ND,1611-MIC2606YML-CT-ND,576-3259-6-ND | MIC2606YML-TR |
| MCP16252T-I/MNYTR-ND,MCP16252T-I/MNYCT-ND,MCP16252T-I/MNYDKR-ND | MCP16252T-I/MNY |
| MCP1640CT-I/MCTR-ND,MCP1640CT-I/MCCT-ND,MCP1640CT-I/MCDKR-ND | MCP1640CT-I/MC |
| MCP16251T-I/MNYTR-ND,MCP16251T-I/MNYCT-ND,MCP16251T-I/MNYDKR-ND | MCP16251T-I/MNY |
| 150-MCP16417T-I/UNTR-ND,150-MCP16417T-I/UNCT-ND,150-MCP16417T-I/UNDKR-ND | MCP16417T-I/UN |
| PAM2401YPADJDITR-ND,PAM2401YPADJDICT-ND,PAM2401YPADJDIDKR-ND | PAM2401YPADJ |
| 2763-KTC2110AECAA-D-TR-ND,2763-KTC2110AECAA-D-TRCT-ND,2763-KTC2110AECAA-D-TRDKR-ND | KTC2110AECAA-D-TR |
| 296-49469-2-ND,296-49469-1-ND,296-49469-6-ND | TPS613226ADBVT |
| 296-46448-2-ND,296-46448-1-ND,296-46448-6-ND | TLV61224DCKR |
| 296-21898-2-ND,296-21898-1-ND,296-21898-6-ND | TPS61073DDCR |
| 2129-R1202N723A-TR-FETR-ND,2129-R1202N723A-TR-FECT-ND,2129-R1202N723A-TR-FEDKR-ND | R1202N723A-TR-FE |
| 296-28788-2-ND,296-28788-1-ND,296-28788-6-ND | TPS61261DRVR |
| MCP1642D-50I/MS-ND | MCP1642D-50I/MS |
| MCP1642B-33I/MS-ND | MCP1642B-33I/MS |
| 296-24409-2-ND,296-24409-1-ND,296-24409-6-ND | TPS61240YFFR |
| MIC2877-5.25YFT-TR-ND,MIC2877-5.25YFT-CT-ND,MIC2877-5.25YFT-DKR-ND | MIC2877-5.25YFT-TR |
| 296-43576-2-ND,296-43576-1-ND,296-43576-6-ND | TLV61220DBVT |
| 296-32405-2-ND,296-32405-1-ND,296-32405-6-ND | TLV61225DCKT |
| 296-28339-2-ND,296-28339-1-ND,296-28339-6-ND | TLV61224DCKT |
| 893-XC9148G33DER-GTR-ND,893-XC9148G33DER-GCT-ND,893-XC9148G33DER-GDKR-ND | XC9148G33DER-G |
| 296-TPS61256AYFFRTR-ND,296-TPS61256AYFFRCT-ND,296-TPS61256AYFFRDKR-ND | TPS61256AYFFR |
| 296-36818-2-ND,296-36818-1-ND,296-36818-6-ND | TPS61253YFFR |
| 568-12841-2-ND,568-12841-1-ND,568-12841-6-ND | PCA9410AUKZ |
| 2129-R1200N002A-TR-FETR-ND,2129-R1200N002A-TR-FECT-ND,2129-R1200N002A-TR-FEDKR-ND | R1200N002A-TR-FE |
| 2129-R1218N062A-TR-FETR-ND,2129-R1218N062A-TR-FECT-ND,2129-R1218N062A-TR-FEDKR-ND | R1218N062A-TR-FE |
| 2129-R1204N213A-TR-FETR-ND,2129-R1204N213A-TR-FECT-ND,2129-R1204N213A-TR-FEDKR-ND | R1204N213A-TR-FE |
| MCP1642DT-ADJI/MCTR-ND,MCP1642DT-ADJI/MCCT-ND,MCP1642DT-ADJI/MCDKR-ND | MCP1642DT-ADJI/MC |
| 296-24487-2-ND,296-24487-1-ND,296-24487-6-ND | TPS61240YFFT |
| FAN48623UC35XTR-ND,FAN48623UC35XCT-ND,FAN48623UC35XDKR-ND | FAN48623UC35X |
| 576-2658-2-ND,576-2658-1-ND,576-2658-6-ND | MIC2295YML-TR |
| 296-50422-2-ND,296-50422-1-ND,296-50422-6-ND | TPS610993YFFR |
| 296-50116-2-ND,296-50116-1-ND,296-50116-6-ND | TPS61256YFFT |
| 2129-RP402K001B-TR-ND,2129-RP402K001B-CT-ND,2129-RP402K001B-DKR-ND | RP402K001B-TR |
| 2129-R1213K001B-TR-ND,2129-R1213K001B-CT-ND,2129-R1213K001B-DKR-ND | R1213K001B-TR |
| LM2623ALD/NOPBTR-ND,LM2623ALD/NOPBCT-ND,LM2623ALD/NOPBDKR-ND | LM2623ALD/NOPB |
| 296-46930-2-ND,296-46930-1-ND,296-46930-6-ND | TPS61096ADSST |
| 296-50825-2-ND,296-50825-1-ND,296-50825-6-ND | TPS61281DYFFT |
| BD8311NUV-E2TR-ND,BD8311NUV-E2CT-ND,BD8311NUV-E2DKR-ND | BD8311NUV-E2 |
| FAN48610BUC50XTR-ND,FAN48610BUC50XCT-ND,FAN48610BUC50XDKR-ND | FAN48610BUC50X |
| 893-XC9145B33CER-GTR-ND,893-XC9145B33CER-GCT-ND,893-XC9145B33CER-GDKR-ND | XC9145B33CER-G |
| MAX8969EWL50+TTR-ND,MAX8969EWL50+TCT-ND,MAX8969EWL50+TDKR-ND | MAX8969EWL50+T |
| 296-32499-2-ND,296-32499-1-ND,296-32499-6-ND,2156-TPS61045DRBT-ND | TPS61045DRBT |
| 1589-1908-2-ND,1589-1908-1-ND,1589-1908-6-ND | MP3217DJ-LF-Z |
| 488-FAN48618BUC53XTR-ND,488-FAN48618BUC53XCT-ND,488-FAN48618BUC53XDKR-ND | FAN48618BUC53X |
| 893-1369-2-ND,893-1369-1-ND,893-1369-6-ND | XC9141B50CMR-G |
| 893-1367-2-ND,893-1367-1-ND,893-1367-6-ND | XC9141B33CMR-G |
| NCP1421DMR2GOSTR-ND,NCP1421DMR2GOSCT-ND,NCP1421DMR2GOSDKR-ND | NCP1421DMR2G |
| 296-15844-2-ND,296-15844-1-ND,296-15844-6-ND | TPS61025DRCR |
| 1589-1042-2-ND,1589-1042-1-ND,1589-1042-6-ND | MP1541DJ-LF-P |
| 296-39431-2-ND,296-39431-1-ND,296-39431-6-ND | TPS61097A-33DBVT |
| 296-25760-2-ND,296-25760-1-ND,296-25760-6-ND | TPS61029DRCR |
| SC120SKTR-ND,SC120SKCT-ND,SC120SKDKR-ND | SC120SKTRT |
| 1589-1907-2-ND,1589-1907-1-ND,1589-1907-6-ND | MP3216DJ-LF-Z |
| ISL9111AEH50Z-T7ATR-ND,ISL9111AEH50Z-T7ACT-ND,ISL9111AEH50Z-T7ADKR-ND | ISL9111AEH50Z-T7A |
| ISL9111EHADJZ-T7ATR-ND,ISL9111EHADJZ-T7ACT-ND,ISL9111EHADJZ-T7ADKR-ND | ISL9111EHADJZ-T7A |
| 296-27011-ND | TPS61085PW |
| 893-1165-2-ND,893-1165-1-ND,893-1165-6-ND | XC9119D10AMR-G |
| 2129-NJW4132U2-C-TE1TR-ND,2129-NJW4132U2-C-TE1CT-ND,2129-NJW4132U2-C-TE1DKR-ND | NJW4132U2-C-TE1 |
| 1589-1906-2-ND,1589-1906-1-ND,1589-1906-6-ND | MP3209DJ-LF-Z |
| 296-19558-2-ND,296-19558-1-ND,296-19558-6-ND | TPS61026DRCT |
| 296-21684-2-ND,296-21684-1-ND,296-21684-6-ND | TPS61201DRCT |
| 1589-1909-2-ND,1589-1909-1-ND,1589-1909-6-ND | MP3221GJ-Z |
| 296-39436-2-ND,296-39436-1-ND,296-39436-6-ND | TPS61230DRCT |
| 296-TPS61085ATDGKTQ1TR-ND,296-TPS61085ATDGKTQ1CT-ND,296-TPS61085ATDGKTQ1DKR-ND | TPS61085ATDGKTQ1 |
| 296-47105-2-ND,296-47105-1-ND,296-47105-6-ND | TPS610993YFFT |
| 296-TPS610997YFFTTR-ND,296-TPS610997YFFTCT-ND,296-TPS610997YFFTDKR-ND | TPS610997YFFT |
| MAX17223ENT+TTR-ND,MAX17223ENT+TCT-ND,MAX17223ENT+TDKR-ND | MAX17223ENT+T |
| 296-TPS613785QWRTERQ1TR-ND,296-TPS613785QWRTERQ1CT-ND,296-TPS613785QWRTERQ1DKR-ND | TPS613785QWRTERQ1 |
| 296-TPS61390RTERTR-ND,296-TPS61390RTERCT-ND,296-TPS61390RTERDKR-ND | TPS61390RTER |
| 296-27006-5-ND | TPS61030PWP |
| MAX15032ATA+TTR-ND,MAX15032ATA+TCT-ND,MAX15032ATA+TDKR-ND | MAX15032ATA+T |
| 1589-1170-2-ND,1589-1170-1-ND,1589-1170-6-ND | MP3422GG-P |
| 175-MAX17224ALT+TTR-ND,175-MAX17224ALT+TCT-ND,175-MAX17224ALT+TDKR-ND | MAX17224ALT+T |
| BD8314NUV-E2TR-ND,BD8314NUV-E2CT-ND,BD8314NUV-E2DKR-ND | BD8314NUV-E2 |
| 1589-1172-2-ND,1589-1172-1-ND,1589-1172-6-ND | MP3425DL-LF-P |
| 1589-1627-2-ND,1589-1627-1-ND,1589-1627-6-ND | MP3213DQ-LF-Z |
| MAX8627ETD+TTR-ND,MAX8627ETD+TCT-ND,MAX8627ETD+TDKR-ND | MAX8627ETD+T |
| 1589-MP3430GQ-ZTR-ND,1589-MP3430GQ-ZCT-ND,1589-MP3430GQ-ZDKR-ND | MP3430GQ-Z |
| 175-MAX17224ELT+TTR-ND,175-MAX17224ELT+TCT-ND,175-MAX17224ELT+TDKR-ND | MAX17224ELT+T |
| 505-ADP1614ACPZ-R7TR-ND,505-ADP1614ACPZ-R7CT-ND,505-ADP1614ACPZ-R7DKR-ND | ADP1614ACPZ-R7 |
| 505-ADP1614ACPZ-650-R7TR-ND,505-ADP1614ACPZ-650-R7CT-ND,505-ADP1614ACPZ-650-R7DKR-ND | ADP1614ACPZ-650-R7 |
| 505-ADP1607ACPZN001-R7TR-ND,505-ADP1607ACPZN001-R7CT-ND,505-ADP1607ACPZN001-R7DKR-ND | ADP1607ACPZN001-R7 |
| 505-ADP1607ACPZN-R7TR-ND,505-ADP1607ACPZN-R7CT-ND,505-ADP1607ACPZN-R7DKR-ND | ADP1607ACPZN-R7 |
| MAX1678EUA±ND | MAX1678EUA+ |
| MAX1606EUA±ND | MAX1606EUA+ |
| 296-45481-2-ND,296-45481-1-ND,296-45481-6-ND | TPS61178RNWT |
| 296-46568-2-ND,296-46568-1-ND,296-46568-6-ND | TPS611781RNWT |
| 2156-TPS61010DGS-ND,296-10969-5-ND | TPS61010DGS |
| 296-24622-2-ND,296-24622-1-ND,296-24622-6-ND | TPS55332QPWPRQ1 |
| ADP1610ARMZ-R7TR-ND,ADP1610ARMZ-R7CT-ND,ADP1610ARMZ-R7DKR-ND | ADP1610ARMZ-R7 |
| 1589-1645-2-ND,1589-1645-1-ND,1589-1645-6-ND | MP3428AGL-Z |
| MAX756CPA±ND | MAX756CPA+ |
| 505-LT8410EDC#TRPBFTR-ND,505-LT8410EDC#TRPBFCT-ND,505-LT8410EDC#TRPBFDKR-ND | LT8410EDC#TRPBF |
| LTC3526BEDC#TRMPBFTR-ND,LTC3526BEDC#TRMPBFCT-ND,LTC3526BEDC#TRMPBFDKR-ND | LTC3526BEDC#TRMPBF |
| LTC3526EDC-2#TRMPBFTR-ND,LTC3526EDC-2#TRMPBFCT-ND,LTC3526EDC-2#TRMPBFDKR-ND | LTC3526EDC-2#TRMPBF |
| LTC3525ESC6-3#TRMPBFTR-ND,LTC3525ESC6-3#TRMPBFCT-ND,LTC3525ESC6-3#TRMPBFDKR-ND | LTC3525ESC6-3#TRMPBF |
| 296-TPS61088QRHLTQ1TR-ND,296-TPS61088QRHLTQ1CT-ND,296-TPS61088QRHLTQ1DKR-ND | TPS61088QRHLTQ1 |
| LTC3526LBEDC#TRMPBFTR-ND,LTC3526LBEDC#TRMPBFCT-ND,LTC3526LBEDC#TRMPBFDKR-ND | LTC3526LBEDC#TRMPBF |
| MAX1763EEE±ND | MAX1763EEE+ |
| 505-LTC3525LESC6-3#TRPBFTR-ND,505-LTC3525LESC6-3#TRPBFCT-ND,505-LTC3525LESC6-3#TRPBFDKR-ND | LTC3525LESC6-3#TRPBF |
| LTC3525LESC6-3#TRMPBFTR-ND,LTC3525LESC6-3#TRMPBFCT-ND,LTC3525LESC6-3#TRMPBFDKR-ND | LTC3525LESC6-3#TRMPBF |
| 505-LT8338EMSE#PBF-ND | LT8338EMSE#PBF |
| 505-LTC3528EDDB#TRPBFTR-ND,505-LTC3528EDDB#TRPBFCT-ND,505-LTC3528EDDB#TRPBFDKR-ND | LTC3528EDDB#TRPBF |
| LTC3528BEDDB#TRPBFTR-ND,LTC3528BEDDB#TRPBFCT-ND,LTC3528BEDDB#TRPBFDKR-ND | LTC3528BEDDB#TRPBF |
| 505-LTC3528EDDB-2#TRPBFTR-ND,505-LTC3528EDDB-2#TRPBFCT-ND,505-LTC3528EDDB-2#TRPBFDKR-ND | LTC3528EDDB-2#TRPBF |
| 505-LTC3528BEDDB#TRMPBFTR-ND,505-LTC3528BEDDB#TRMPBFCT-ND,505-LTC3528BEDDB#TRMPBFDKR-ND | LTC3528BEDDB#TRMPBF |
| LTC3528BEDDB-2#TRMPBFTR-ND,LTC3528BEDDB-2#TRMPBFCT-ND,LTC3528BEDDB-2#TRMPBFDKR-ND | LTC3528BEDDB-2#TRMPBF |
| 505-LT3489EMS8E#PBF-ND | LT3489EMS8E#PBF |
| LTC3426ES6#TRPBFTR-ND,LTC3426ES6#TRPBFCT-ND,LTC3426ES6#TRPBFDKR-ND | LTC3426ES6#TRPBF |
| LTC3525ISC6-3.3#TRMPBFTR-ND,LTC3525ISC6-3.3#TRMPBFCT-ND,LTC3525ISC6-3.3#TRMPBFDKR-ND | LTC3525ISC6-3.3#TRMPBF |
| 505-LT8338JMSE#TRPBFTR-ND,505-LT8338JMSE#TRPBFCT-ND,505-LT8338JMSE#TRPBFDKR-ND | LT8338JMSE#TRPBF |
| MAX1763EUE±ND | MAX1763EUE+ |
| 505-LT8338JMSE#PBF-ND | LT8338JMSE#PBF |
| MAX1760EUB±ND | MAX1760EUB+ |
| 505-LT8410IDC-1#TRMPBFTR-ND,505-LT8410IDC-1#TRMPBFCT-ND,505-LT8410IDC-1#TRMPBFDKR-ND | LT8410IDC-1#TRMPBF |
| MAX757CSA±ND | MAX757CSA+ |
| MAX756CSA±ND | MAX756CSA+ |
| LT3905EUD#PBF-ND | LT3905EUD#PBF |
| LT1307BCS8#PBF-ND | LT1307BCS8#PBF |
| LTC3499BEDD#PBF-ND | LTC3499BEDD#PBF |
| LTC3499EMS8#PBF-ND | LTC3499EMS8#PBF |
| LTC3499EDD#PBF-ND | LTC3499EDD#PBF |
| 161-LTC3429ES6#TRPBFTR-ND,161-LTC3429ES6#TRPBFCT-ND,161-LTC3429ES6#TRPBFDKR-ND | LTC3429ES6#TRPBF |
| LTC3429ES6#TRMPBFTR-ND,LTC3429ES6#TRMPBFCT-ND,LTC3429ES6#TRMPBFDKR-ND | LTC3429ES6#TRMPBF |
| 505-LT3473EDD#PBF-ND | LT3473EDD#PBF |
| 505-LTC3459EDCB#TRPBFTR-ND,505-LTC3459EDCB#TRPBFCT-ND,505-LTC3459EDCB#TRPBFDKR-ND | LTC3459EDCB#TRPBF |
| MAX642ACPA±ND | MAX642ACPA+ |
| MAX856CSA±ND | MAX856CSA+ |
| LTC3121EDE#TRPBFTR-ND,LTC3121EDE#TRPBFCT-ND,LTC3121EDE#TRPBFDKR-ND | LTC3121EDE#TRPBF |
| 505-LTC3122EMSE#PBF-ND | LTC3122EMSE#PBF |
| 505-LT3571IUD#PBF-ND | LT3571IUD#PBF |
| 161-LT1307CMS8#PBF-ND | LT1307CMS8#PBF |
| LT1307BCMS8#PBF-ND | LT1307BCMS8#PBF |
| LT1109CS8-12#PBF-ND | LT1109CS8-12#PBF |
| LTC3401EMS#TRPBFTR-ND,LTC3401EMS#TRPBFCT-ND,LTC3401EMS#TRPBFDKR-ND | LTC3401EMS#TRPBF |
| 505-LTC3121IDE#TRPBFTR-ND,505-LTC3121IDE#TRPBFCT-ND,505-LTC3121IDE#TRPBFDKR-ND | LTC3121IDE#TRPBF |
| 505-LTC3121IDE#PBF-ND | LTC3121IDE#PBF |
| MAX1701EEE±ND | MAX1701EEE+ |
| LTC3290HMSE#PBF-ND | LTC3290HMSE#PBF |
| LT1109ACS8#PBF-ND | LT1109ACS8#PBF |
| LTC3422EDD#TRPBFTR-ND,LTC3422EDD#TRPBFCT-ND,LTC3422EDD#TRPBFDKR-ND | LTC3422EDD#TRPBF |
| LT1301CN8#PBF-ND | LT1301CN8#PBF |
| LT1303CN8-5#PBF-ND | LT1303CN8-5#PBF |
| LT1303CS8-5#PBF-ND | LT1303CS8-5#PBF |
| MAX1795EUA±ND | MAX1795EUA+ |
| 161-LT8336HV#WPBF-ND | LT8336HV#WPBF |
| MAX642AEPA±ND | MAX642AEPA+ |
| MAX1796EUA±ND | MAX1796EUA+ |
| LTC3124IFE#PBF-ND | LTC3124IFE#PBF |
| MAX643AEPA±ND | MAX643AEPA+ |
| 505-LTC3421EUF#PBF-ND | LTC3421EUF#PBF |
| LT1306ES8#PBF-ND | LT1306ES8#PBF |
| LT1302CN8-5#PBF-ND | LT1302CN8-5#PBF |
| LT1302CN8#PBF-ND | LT1302CN8#PBF |
| LT1302CS8-5#PBF-ND | LT1302CS8-5#PBF |
| 505-MAX15258ATX±ND | MAX15258ATX+ |
| 505-MAX15258ATX+TTR-ND | MAX15258ATX+T |
| LT1308IS8#PBF-ND | LT1308IS8#PBF |
| MAX1709EUI±ND | MAX1709EUI+ |
| LTC3425EUH#PBF-ND | LTC3425EUH#PBF |
| MAX1703ESE±ND | MAX1703ESE+ |
| MAX630EPA±ND | MAX630EPA+ |
| 296-52011-2-ND,296-52011-1-ND,296-52011-6-ND | TPS613223ADBVR |
| 2129-RN5RK331A-TR-FETR-ND,2129-RN5RK331A-TR-FECT-ND,2129-RN5RK331A-TR-FEDKR-ND | RN5RK331A-TR-FE |
| 2129-RN5RK332A-TR-FETR-ND,2129-RN5RK332A-TR-FECT-ND,2129-RN5RK332A-TR-FEDKR-ND | RN5RK332A-TR-FE |
| 2129-RN5RK271A-TR-FETR-ND,2129-RN5RK271A-TR-FECT-ND,2129-RN5RK271A-TR-FEDKR-ND | RN5RK271A-TR-FE |
| 150-MCP16415T-I/MNTR-ND,150-MCP16415T-I/MNCT-ND,150-MCP16415T-I/MNDKR-ND | MCP16415T-I/MN |
| 150-MCP16413T-I/MNTR-ND,150-MCP16413T-I/MNCT-ND,150-MCP16413T-I/MNDKR-ND | MCP16413T-I/MN |
| 150-MCP16414T-I/MNTR-ND,150-MCP16414T-I/MNCT-ND,150-MCP16414T-I/MNDKR-ND | MCP16414T-I/MN |
| BU33DV5G-GTR-ND,BU33DV5G-GCT-ND,BU33DV5G-GDKR-ND | BU33DV5G-GTR |
| 150-MCP16414T-I/UNTR-ND,150-MCP16414T-I/UNCT-ND,150-MCP16414T-I/UNDKR-ND | MCP16414T-I/UN |
| 150-MCP16415T-I/UNTR-ND,150-MCP16415T-I/UNCT-ND,150-MCP16415T-I/UNDKR-ND | MCP16415T-I/UN |
| 150-MCP16411T-I/UNTR-ND,150-MCP16411T-I/UNCT-ND,150-MCP16411T-I/UNDKR-ND | MCP16411T-I/UN |
| 150-MCP16418T-I/UNTR-ND,150-MCP16418T-I/UNCT-ND,150-MCP16418T-I/UNDKR-ND | MCP16418T-I/UN |
| 296-21523-2-ND,296-21523-1-ND,296-21523-6-ND | TPS61072DDCR |
| 2129-R1202L721A-TR-ND,2129-R1202L721A-CT-ND,2129-R1202L721A-DKR-ND | R1202L721A-TR |
| 2129-R1202N523B-TR-FETR-ND,2129-R1202N523B-TR-FECT-ND,2129-R1202N523B-TR-FEDKR-ND | R1202N523B-TR-FE |
| 296-TPS612532AYFFRTR-ND,296-TPS612532AYFFRCT-ND,296-TPS612532AYFFRDKR-ND | TPS612532AYFFR |
| 296-24520-2-ND,296-24520-1-ND,296-24520-6-ND | TPS61241YFFR |
| 296-TPS61241YFFTTR-ND,296-TPS61241YFFTCT-ND,296-TPS61241YFFTDKR-ND | TPS61241YFFT |
| 296-TPS61254YFFRTR-ND,296-TPS61254YFFRCT-ND,296-TPS61254YFFRDKR-ND,2156-TPS61254YFFR-ND | TPS61254YFFR |
| 296-34931-2-ND,296-34931-1-ND,296-34931-6-ND,2156-TPS61259YFFR-ND | TPS61259YFFR |
| 2129-R1210N331D-TR-FETR-ND,2129-R1210N331D-TR-FECT-ND,2129-R1210N331D-TR-FEDKR-ND | R1210N331D-TR-FE |
| 2129-R1210N602D-TR-FETR-ND,2129-R1210N602D-TR-FECT-ND,2129-R1210N602D-TR-FEDKR-ND | R1210N602D-TR-FE |
| 568-14384-2-ND,568-14384-1-ND,568-14384-6-ND | PCA9412AUKZ |
| 2129-R1200N003A-TR-FETR-ND,2129-R1200N003A-TR-FECT-ND,2129-R1200N003A-TR-FEDKR-ND | R1200N003A-TR-FE |
| 2129-R1200N001A-TR-FETR-ND,2129-R1200N001A-TR-FECT-ND,2129-R1200N001A-TR-FEDKR-ND | R1200N001A-TR-FE |
| 296-TPS61261DRVTTR-ND,296-TPS61261DRVTCT-ND,296-TPS61261DRVTDKR-ND | TPS61261DRVT |
| 296-TPS61260DRVTTR-ND,296-TPS61260DRVTCT-ND,296-TPS61260DRVTDKR-ND | TPS61260DRVT |
| 2129-RP401K551B-TR-ND,2129-RP401K551B-CT-ND,2129-RP401K551B-DKR-ND | RP401K551B-TR |
| 2129-RP400N501A-TR-FETR-ND,2129-RP400N501A-TR-FECT-ND,2129-RP400N501A-TR-FEDKR-ND | RP400N501A-TR-FE |
| 2129-R1204N313A-TR-FETR-ND,2129-R1204N313A-TR-FECT-ND,2129-R1204N313A-TR-FEDKR-ND | R1204N313A-TR-FE |
| FAN48685UC08XOSTR-ND,FAN48685UC08XOSCT-ND,FAN48685UC08XOSDKR-ND | FAN48685UC08X |
| 296-TPS61280DYFFRTR-ND,296-TPS61280DYFFRCT-ND,296-TPS61280DYFFRDKR-ND | TPS61280DYFFR |
| 20-ISL9113ERAZ-TTR-ND,20-ISL9113ERAZ-TCT-ND,20-ISL9113ERAZ-TDKR-ND | ISL9113ERAZ-T |
| 2763-KTC2110ECAA-TR-ND,2763-KTC2110ECAA-TRCT-ND,2763-KTC2110ECAA-TRDKR-ND | KTC2110ECAA-TR |
| 20-ISL9113EIAZ-TTR-ND,20-ISL9113EIAZ-TCT-ND,20-ISL9113EIAZ-TDKR-ND | ISL9113EIAZ-T |
| 296-TPS610992YFFRTR-ND,296-TPS610992YFFRCT-ND,296-TPS610992YFFRDKR-ND | TPS610992YFFR |
| 296-TPS612562CYFFTTR-ND,296-TPS612562CYFFTCT-ND,296-TPS612562CYFFTDKR-ND | TPS612562CYFFT |
| 296-TPS612592YFFTTR-ND,296-TPS612592YFFTCT-ND,296-TPS612592YFFTDKR-ND,2156-TPS612592YFFT-ND | TPS612592YFFT |
| 296-TPS61256CYFFTTR-ND,296-TPS61256CYFFTCT-ND,296-TPS61256CYFFTDKR-ND | TPS61256CYFFT |
| 296-TPS61254YFFTTR-ND,296-TPS61254YFFTCT-ND,296-TPS61254YFFTDKR-ND | TPS61254YFFT |
| 2129-RP402K331A-TR-ND,2129-RP402K331A-CT-ND,2129-RP402K331A-DKR-ND | RP402K331A-TR |
| 296-TPS61258YFFTTR-ND,296-TPS61258YFFTCT-ND,296-TPS61258YFFTDKR-ND,2156-TPS61258YFFT-ND | TPS61258YFFT |
| 296-TPS61259YFFTTR-ND,296-TPS61259YFFTCT-ND,296-TPS61259YFFTDKR-ND,2156-TPS61259YFFT-ND | TPS61259YFFT |
| 296-30503-2-ND,296-30503-1-ND,296-30503-6-ND | TPS61253YFFT |
| 296-50826-2-ND,296-50826-1-ND,296-50826-6-ND | TPS61282DYFFT |
| 893-XC9145B50CER-GTR-ND,893-XC9145B50CER-GCT-ND,893-XC9145B50CER-GDKR-ND | XC9145B50CER-G |
| 175-MAX8969EWL37+TTR-ND,175-MAX8969EWL37+TCT-ND,175-MAX8969EWL37+TDKR-ND | MAX8969EWL37+T |
| 296-TPS61045ADRBTTR-ND,296-TPS61045ADRBTCT-ND,296-TPS61045ADRBTDKR-ND,2156-TPS61045ADRBT-ND | TPS61045ADRBT |
| 296-TPS61085TPWRTR-ND,296-TPS61085TPWRCT-ND,296-TPS61085TPWRDKR-ND,2156-TPS61085TPWR-ND | TPS61085TPWR |
| 296-15753-2-ND,296-15753-1-ND,296-15753-6-ND | TPS61024DRCR |
| 296-44808-2-ND,296-44808-1-ND,296-44808-6-ND | TPS61230ARNST |
| FAN48619UC50XTR-ND,FAN48619UC50XCT-ND,FAN48619UC50XDKR-ND | FAN48619UC50X |
| 1028-1184-2-ND,1028-1184-1-ND,1028-1184-6-ND | RT9276GQW |
| 893-XC9145B36CER-GTR-ND,893-XC9145B36CER-GCT-ND,893-XC9145B36CER-GDKR-ND | XC9145B36CER-G |
| 296-23426-2-ND,296-23426-1-ND,296-23426-6-ND | TPS61087DRCT |
| 296-27242-2-ND,296-27242-1-ND,296-27242-6-ND | TPS61087DSCT |
| FAN48623UC50XTR-ND,FAN48623UC50XCT-ND,FAN48623UC50XDKR-ND | FAN48623UC50X |
| FAN48623UC50GXTR-ND,FAN48623UC50GXCT-ND,FAN48623UC50GXDKR-ND | FAN48623UC50GX |
| 1028-1375-2-ND,1028-1375-1-ND,1028-1375-6-ND | RT4803AWSC |
| RT4813AGQUFTR-ND,RT4813AGQUFCT-ND,RT4813AGQUFDKR-ND | RT4813AGQUF |
| 296-19559-2-ND,296-19559-1-ND,296-19559-6-ND | TPS61029DRCT |
| 296-27295-2-ND,296-27295-1-ND,296-27295-6-ND | TPS61029QDRCRQ1 |
| 1589-1169-2-ND,1589-1169-1-ND,1589-1169-6-ND | MP3418GJ-P |
| 1589-1152-2-ND,1589-1152-1-ND,1589-1152-6-ND | MP3209DJ-LF-P |
| 296-47468-2-ND,296-47468-1-ND,296-47468-6-ND | TPS610995YFFT |
| 296-50113-2-ND,296-50113-1-ND,296-50113-6-ND | TPS610994YFFT |
| 296-47469-2-ND,296-47469-1-ND,296-47469-6-ND | TPS610996YFFT |
| 1589-MP3414EGJ-PTR-ND,1589-MP3414EGJ-PCT-ND,1589-MP3414EGJ-PDKR-ND | MP3414EGJ-P |
| 175-MAX17225ENT+TTR-ND,175-MAX17225ENT+TCT-ND,175-MAX17225ENT+TDKR-ND | MAX17225ENT+T |
| 296-TPS61391RTETTR-ND,296-TPS61391RTETCT-ND,296-TPS61391RTETDKR-ND | TPS61391RTET |
| LM2700MT-ADJ/NOPB-ND | LM2700MT-ADJ/NOPB |
| LM2700LD-ADJ/NOPBTR-ND,LM2700LD-ADJ/NOPBCT-ND,LM2700LD-ADJ/NOPBDKR-ND | LM2700LD-ADJ/NOPB |
| 505-LT1109CN8#PBF-ND | LT1109CN8#PBF |
| 175-MAX17224ENT+TTR-ND,175-MAX17224ENT+TCT-ND,175-MAX17224ENT+TDKR-ND | MAX17224ENT+T |
| 1589-1154-2-ND,1589-1154-1-ND,1589-1154-6-ND | MP3213DQ-LF-P |
| MAX1724EZK30+TTR-ND,MAX1724EZK30+TCT-ND,MAX1724EZK30+TDKR-ND | MAX1724EZK30+T |
| 175-MAX1723EZK+TTR-ND,175-MAX1723EZK+TCT-ND,175-MAX1723EZK+TDKR-ND | MAX1723EZK+T |
| MAX8569AEUT+TTR-ND,MAX8569AEUT+TCT-ND,MAX8569AEUT+TDKR-ND | MAX8569AEUT+T |
| MAX8569AETT+TTR-ND,MAX8569AETT+TCT-ND,MAX8569AETT+TDKR-ND | MAX8569AETT+T |
| 1589-MP3435GL-PTR-ND,1589-MP3435GL-PCT-ND,1589-MP3435GL-PDKR-ND | MP3435GL-P |
| 1589-1175-2-ND,1589-1175-1-ND,1589-1175-6-ND | MP3430GQ-P |
| 1589-MPQ3431AGL-AEC1-ZTR-ND,1589-MPQ3431AGL-AEC1-ZCT-ND,1589-MPQ3431AGL-AEC1-ZDKR-ND | MPQ3431AGL-AEC1-Z |
| 175-MAX1606EUA+TTR-ND,175-MAX1606EUA+TCT-ND,175-MAX1606EUA+TDKR-ND | MAX1606EUA+T |
| 1589-MPQ3431AGL-AEC1-PTR-ND,1589-MPQ3431AGL-AEC1-PCT-ND,1589-MPQ3431AGL-AEC1-PDKR-ND | MPQ3431AGL-AEC1-P |
| 2117-2U-012-010A-QFN32-CTR-ND,2117-2U-012-010A-QFN32-CCT-ND,2117-2U-012-010A-QFN32-CDKR-ND | 2U-012-010A-QFN32-C |
| 2156-TPS61006DGS-ND,296-3223-5-ND | TPS61006DGS |
| 1589-MPQ3452DL-AEC1-LF-PTR-ND,1589-MPQ3452DL-AEC1-LF-PCT-ND,1589-MPQ3452DL-AEC1-LF-PDKR-ND | MPQ3452DL-AEC1-LF-P |
| 2156-TPS61015DGS-ND,296-10974-5-ND | TPS61015DGS |
| 175-MAX1678EUA+TTR-ND,175-MAX1678EUA+TCT-ND,175-MAX1678EUA+TDKR-ND | MAX1678EUA+T |
| 1589-MPQ3425DL-AEC1-LF-PTR-ND,1589-MPQ3425DL-AEC1-LF-PCT-ND,1589-MPQ3425DL-AEC1-LF-PDKR-ND | MPQ3425DL-AEC1-LF-P |
| MAX757CPA±ND | MAX757CPA+ |
| 1589-MPQ3426DL-LF-PTR-ND,1589-MPQ3426DL-LF-PCT-ND,1589-MPQ3426DL-LF-PDKR-ND | MPQ3426DL-LF-P |
| LTC3526BEDC-2#TRMPBFTR-ND,LTC3526BEDC-2#TRMPBFCT-ND,LTC3526BEDC-2#TRMPBFDKR-ND | LTC3526BEDC-2#TRMPBF |
| 505-LTC3427EDC#TRPBFTR-ND,505-LTC3427EDC#TRPBFCT-ND,505-LTC3427EDC#TRPBFDKR-ND | LTC3427EDC#TRPBF |
| LTC3427EDC#TRMPBFTR-ND,LTC3427EDC#TRMPBFCT-ND,LTC3427EDC#TRMPBFDKR-ND | LTC3427EDC#TRMPBF |
| LTC3525ESC6-3.3#TRPBFTR-ND,LTC3525ESC6-3.3#TRPBFCT-ND,LTC3525ESC6-3.3#TRPBFDKR-ND | LTC3525ESC6-3.3#TRPBF |
| LT1946EMS8E#PBF-ND | LT1946EMS8E#PBF |
| 505-LTC3526LEDC-2#TRPBFTR-ND,505-LTC3526LEDC-2#TRPBFCT-ND,505-LTC3526LEDC-2#TRPBFDKR-ND | LTC3526LEDC-2#TRPBF |
| 505-LTC3526LBEDC-2#TRPBFTR-ND,505-LTC3526LBEDC-2#TRPBFCT-ND,505-LTC3526LBEDC-2#TRPBFDKR-ND | LTC3526LBEDC-2#TRPBF |
| 505-LTC3526LEDC-2#TRMPBFTR-ND,505-LTC3526LEDC-2#TRMPBFCT-ND,505-LTC3526LEDC-2#TRMPBFDKR-ND | LTC3526LEDC-2#TRMPBF |
| 1589-MP3428AGL-PTR-ND,1589-MP3428AGL-PCT-ND,1589-MP3428AGL-PDKR-ND | MP3428AGL-P |
| 1589-MPQ3426DL-AEC1-LF-PTR-ND,1589-MPQ3426DL-AEC1-LF-PCT-ND,1589-MPQ3426DL-AEC1-LF-PDKR-ND | MPQ3426DL-AEC1-LF-P |
| 161-LTC3528EDDB-2#TRMPBFTR-ND,161-LTC3528EDDB-2#TRMPBFCT-ND,161-LTC3528EDDB-2#TRMPBFDKR-ND | LTC3528EDDB-2#TRMPBF |
| LTC3525DISC6-3.3#TRMPBFTR-ND,LTC3525DISC6-3.3#TRMPBFCT-ND,LTC3525DISC6-3.3#TRMPBFDKR-ND | LTC3525DISC6-3.3#TRMPBF |
| LTC3525ISC6-3#TRMPBFTR-ND,LTC3525ISC6-3#TRMPBFCT-ND,LTC3525ISC6-3#TRMPBFDKR-ND | LTC3525ISC6-3#TRMPBF |
| LTC3525ISC6-5#TRMPBFTR-ND,LTC3525ISC6-5#TRMPBFCT-ND,LTC3525ISC6-5#TRMPBFDKR-ND | LTC3525ISC6-5#TRMPBF |
| LT1307CN8#PBF-ND | LT1307CN8#PBF |
| MAX857CSA±ND | MAX857CSA+ |
| 505-LTC3400ES6-1#TRMPBFTR-ND,505-LTC3400ES6-1#TRMPBFCT-ND,505-LTC3400ES6-1#TRMPBFDKR-ND | LTC3400ES6-1#TRMPBF |
| 2156-TPS6734IP-ND,296-3226-5-ND | TPS6734IP |
| 505-LTC3459EDCB#TRMPBFTR-ND,505-LTC3459EDCB#TRMPBFCT-ND,505-LTC3459EDCB#TRMPBFDKR-ND | LTC3459EDCB#TRMPBF |
| 505-LTC3459EDC#TRMPBFTR-ND,505-LTC3459EDC#TRMPBFCT-ND,505-LTC3459EDC#TRMPBFDKR-ND | LTC3459EDC#TRMPBF |
| 175-MAX856CSA+TTR-ND,175-MAX856CSA+TCT-ND,175-MAX856CSA+TDKR-ND | MAX856CSA+T |
| 2156-TPS6734ID-ND,296-3225-5-ND | TPS6734ID |
| MAX641ACPA±ND | MAX641ACPA+ |
| MAX643ACSA±ND | MAX643ACSA+ |
| MAX642ACSA±ND | MAX642ACSA+ |
| 505-LT8415EDDB#TRMPBFTR-ND,505-LT8415EDDB#TRMPBFCT-ND,505-LT8415EDDB#TRMPBFDKR-ND | LT8415EDDB#TRMPBF |
| LTC3539EDCB-2#TRPBFTR-ND,LTC3539EDCB-2#TRPBFCT-ND,LTC3539EDCB-2#TRPBFDKR-ND | LTC3539EDCB-2#TRPBF |
| 175-MAX1763EUE+TTR-ND,175-MAX1763EUE+TCT-ND,175-MAX1763EUE+TDKR-ND | MAX1763EUE+T |
| LTC3290IMSE#PBF-ND | LTC3290IMSE#PBF |
| LT1109CS8#PBF-ND | LT1109CS8#PBF |
| LT1307IS8#PBF-ND | LT1307IS8#PBF |
| 505-LT1307BIS8#PBF-ND | LT1307BIS8#PBF |
| MAX1706EEE±ND | MAX1706EEE+ |
| 505-LT3905IUD#TRPBFTR-ND,505-LT3905IUD#TRPBFCT-ND,505-LT3905IUD#TRPBFDKR-ND | LT3905IUD#TRPBF |
| LT3905IUD#PBF-ND | LT3905IUD#PBF |
| MAX856ESA±ND | MAX856ESA+ |
| MAX858ESA±ND | MAX858ESA+ |
| LT8551EUKG#PBF-ND | LT8551EUKG#PBF |
| LTC3122HMSE#PBF-ND | LTC3122HMSE#PBF |
| 505-LTC3124IDHC#PBF-ND | LTC3124IDHC#PBF |
| LT1303CN8#PBF-ND | LT1303CN8#PBF |
| 175-MAX1795EUA+TTR-ND,175-MAX1795EUA+TCT-ND,175-MAX1795EUA+TDKR-ND | MAX1795EUA+T |
| LTC3424EMS#PBF-ND | LTC3424EMS#PBF |
| LTC3124HFE#PBF-ND | LTC3124HFE#PBF |
| MAX641AESA±ND | MAX641AESA+ |
| LT1308CS8#PBF-ND | LT1308CS8#PBF |
| LT1301IS8#PBF-ND | LT1301IS8#PBF |
| MAX630ESA±ND | MAX630ESA+ |
| MAX630CPA±ND | MAX630CPA+ |
| 5503-TPQ051004-DFORTR-ND,5503-TPQ051004-DFORCT-ND,5503-TPQ051004-DFORDKR-ND | TPQ051004-DFOR |
| NCP1423DMR2GOSTR-ND | NCP1423DMR2G |
| FAN48610BUC45XOSTR-ND,FAN48610BUC45XOSCT-ND,FAN48610BUC45XOSDKR-ND | FAN48610BUC45X |
| 5503-TPQ051007-DFORTR-ND,5503-TPQ051007-DFORCT-ND,5503-TPQ051007-DFORDKR-ND | TPQ051007-DFOR |
| 1028-RT4803BP-ATR-ND,1028-RT4803BP-ACT-ND,1028-RT4803BP-ADKR-ND | RT4803BP-A |
| 893-XC9140C361MR-GTR-ND,893-XC9140C361MR-GCT-ND,893-XC9140C361MR-GDKR-ND | XC9140C361MR-G |
| 150-MCP1642BT-ADJI/MSTR-ND,150-MCP1642BT-ADJI/MSCT-ND,150-MCP1642BT-ADJI/MSDKR-ND | MCP1642BT-ADJI/MS |
| MCP1642D-33I/MS-ND | MCP1642D-33I/MS |
| 296-45542-2-ND,296-45542-1-ND,296-45542-6-ND | LM2623AMMX/NOPB |
| 5503-TPQ05100-WS4RTR-ND,5503-TPQ05100-WS4RCT-ND,5503-TPQ05100-WS4RDKR-ND | TPQ05100-WS4R |
| 5503-TPQ051003-DFORTR-ND,5503-TPQ051003-DFORCT-ND,5503-TPQ051003-DFORDKR-ND | TPQ051003-DFOR |
| 5503-TPQ051007-WS4RTR-ND,5503-TPQ051007-WS4RCT-ND,5503-TPQ051007-WS4RDKR-ND | TPQ051007-WS4R |
| 5503-TPQ05100-DFORTR-ND,5503-TPQ05100-DFORCT-ND,5503-TPQ05100-DFORDKR-ND | TPQ05100-DFOR |
| FAN4860UC5XTR-ND,FAN4860UC5XCT-ND,FAN4860UC5XDKR-ND | FAN4860UC5X |
| 505-MAX20471ATCB/V±ND | MAX20471ATCB/V+ |
| 296-36815-2-ND,296-36815-1-ND,296-36815-6-ND | TPS61087QDRCRQ1 |
| 296-44713-2-ND,296-44713-1-ND,296-44713-6-ND | TPS61087QWDRCRQ1 |
| 1028-RT4823WSCTR-ND,1028-RT4823WSCCT-ND,1028-RT4823WSCDKR-ND | RT4823WSC |
| 893-XC9142A50CMR-GTR-ND,893-XC9142A50CMR-GCT-ND,893-XC9142A50CMR-GDKR-ND | XC9142A50CMR-G |
| 893-XC9142D38CMR-GTR-ND,893-XC9142D38CMR-GCT-ND,893-XC9142D38CMR-GDKR-ND | XC9142D38CMR-G |
| 893-XC6372A501PR-GTR-ND,893-XC6372A501PR-GCT-ND,893-XC6372A501PR-GDKR-ND | XC6372A501PR-G |
| 893-1374-2-ND,893-1374-1-ND,893-1374-6-ND | XC9142B50DMR-G |
| 893-XC9142B50CER-GTR-ND,893-XC9142B50CER-GCT-ND,893-XC9142B50CER-GDKR-ND | XC9142B50CER-G |
| 893-XC9141A50DMR-GTR-ND,893-XC9141A50DMR-GCT-ND,893-XC9141A50DMR-GDKR-ND | XC9141A50DMR-G |
| 1589-MP3437GRP-PTR-ND,1589-MP3437GRP-PCT-ND,1589-MP3437GRP-PDKR-ND | MP3437GRP-P |
| 893-XC9142A50C0R-GTR-ND,893-XC9142A50C0R-GCT-ND,893-XC9142A50C0R-GDKR-ND | XC9142A50C0R-G |
| SC121ULTRTTR-ND,SC121ULTRTCT-ND,SC121ULTRTDKR-ND | SC121ULTRT |
| 296-TPS612997YBHRTR-ND,296-TPS612997YBHRCT-ND,296-TPS612997YBHRDKR-ND | TPS612997YBHR |
| 505-MAX20471ATCA/VY±ND | MAX20471ATCA/VY+ |
| MAX17290ETCC±ND | MAX17290ETCC+ |
| 175-MAX18002AWT+TTR-ND,175-MAX18002AWT+TCT-ND,175-MAX18002AWT+TDKR-ND | MAX18002AWT+T |
| MAX17290ETCD±ND | MAX17290ETCD+ |
| 296-TPS61202DSCTTR-ND,296-TPS61202DSCT-ND,296-TPS61202DSCTDKR-ND,2156-TPS61202DSCT-ND | TPS61202DSCT |
| 1589-1043-2-ND,1589-1043-1-ND,1589-1043-6-ND | MP1542DK-LF-P |
| 1589-1626-2-ND,1589-1626-1-ND,1589-1626-6-ND | MP3213DH-LF-Z |
| 296-34978-2-ND,296-34978-1-ND,296-34978-6-ND | TPS61222MDCKTEP |
| MAX858CSA±ND | MAX858CSA+ |
| MAX1947ETA33+TTR-ND,MAX1947ETA33+TCT-ND,MAX1947ETA33+TDKR-ND | MAX1947ETA33+T |
| 1589-MPQ3431CGLE-AEC1-ZTR-ND,1589-MPQ3431CGLE-AEC1-ZCT-ND,1589-MPQ3431CGLE-AEC1-ZDKR-ND | MPQ3431CGLE-AEC1-Z |
| 1589-MPQ3432GLE-AEC1-ZTR-ND,1589-MPQ3432GLE-AEC1-ZCT-ND,1589-MPQ3432GLE-AEC1-ZDKR-ND | MPQ3432GLE-AEC1-Z |
| MAX1947ETA30+TTR-ND,MAX1947ETA30+TCT-ND,MAX1947ETA30+TDKR-ND | MAX1947ETA30+T |
| 505-LT8349ACBZ-R7TR-ND,505-LT8349ACBZ-R7CT-ND,505-LT8349ACBZ-R7DKR-ND | LT8349ACBZ-R7 |
| 1589-MPQ3431CGLE-AEC1-PTR-ND,1589-MPQ3431CGLE-AEC1-PCT-ND,1589-MPQ3431CGLE-AEC1-PDKR-ND | MPQ3431CGLE-AEC1-P |
| 1589-MPQ3432GLE-AEC1-PTR-ND,1589-MPQ3432GLE-AEC1-PCT-ND,1589-MPQ3432GLE-AEC1-PDKR-ND | MPQ3432GLE-AEC1-P |
| MAX1700EEE±ND | MAX1700EEE+ |
| 175-MAX1832EUT+TTR-ND,175-MAX1832EUT+TCT-ND,175-MAX1832EUT+TDKR-ND | MAX1832EUT+T |
| 175-MAX1833EUT+TTR-ND,175-MAX1833EUT+TCT-ND,175-MAX1833EUT+TDKR-ND | MAX1833EUT+T |
| LT1109CZ-12#PBF-ND | LT1109CZ-12#PBF |
| 175-MAX858CSA+TTR-ND,175-MAX858CSA+TCT-ND,175-MAX858CSA+TDKR-ND | MAX858CSA+T |
| 175-MAX756CSA+TTR-ND,175-MAX756CSA+TCT-ND,175-MAX756CSA+TDKR-ND | MAX756CSA+T |
| MAX630CSA±ND | MAX630CSA+ |
| 505-LT8336EV#TRPBFTR-ND,505-LT8336EV#TRPBFCT-ND,505-LT8336EV#TRPBFDKR-ND | LT8336EV#TRPBF |
| 505-LT8336JV#TRPBFTR-ND,505-LT8336JV#TRPBFCT-ND,505-LT8336JV#TRPBFDKR-ND | LT8336JV#TRPBF |
| 505-LT8336EV#WTRPBFTR-ND,505-LT8336EV#WTRPBFCT-ND,505-LT8336EV#WTRPBFDKR-ND | LT8336EV#WTRPBF |
| 505-LT8336JV#WTRPBFTR-ND,505-LT8336JV#WTRPBFCT-ND,505-LT8336JV#WTRPBFDKR-ND | LT8336JV#WTRPBF |
| 505-LT8551IUKG#PBF-ND | LT8551IUKG#PBF |
| 505-LT8336HV#WTRPBFTR-ND,505-LT8336HV#WTRPBFCT-ND,505-LT8336HV#WTRPBFDKR-ND | LT8336HV#WTRPBF |
| 505-MAX641AEPA±ND | MAX641AEPA+ |
| 2156-FAN48617UC50X-ND | FAN48617UC50X |
| 3565-RS6651YTHTR-ND,3565-RS6651YTHCT-ND,3565-RS6651YTHDKR-ND | RS6651YTH |
| 2156-ADP1109AN-12-ND | ADP1109AN-12 |
| 2156-ADP1109AN-ND | ADP1109AN |
| 2156-ADP1109AN-5-ND | ADP1109AN-5 |
| 2156-ADP1109AN-3.3-ND | ADP1109AN-3.3 |
| 2156-ADP1109AAN-ND | ADP1109AAN |
| 2156-ADP1109AAN-5-ND | ADP1109AAN-5 |
| 2156-ADP1109AAN-12-ND | ADP1109AAN-12 |
| 2156-ADP1109AAN-3.3-ND | ADP1109AAN-3.3 |
| 3351-UM1660STR-ND | UM1660S |
| 2156-ADP1109AR-5-REEL-ND | ADP1109AR-5-REEL |
| 2156-ADP1109AR-ND | ADP1109AR |
| 2156-ADP1109AAR-5-ND | ADP1109AAR-5 |
| 2156-ADP1109AAR-ND | ADP1109AAR |
| 2156-ADP1109AR-3.3-ND | ADP1109AR-3.3 |
| 2156-ADP1109AAR-3.3-ND | ADP1109AAR-3.3 |
| 2156-FAN48619UC50X-ND | FAN48619UC50X |
| 2156-ILC6370AP52X-ND | ILC6370AP52X |
| 2156-FAN48630UC33X-ND | FAN48630UC33X |
| 2156-ML4950CS-ND | ML4950CS |
| 3351-UM3429STR-ND | UM3429S |
| 2156-FAN48623UC35X-ND | FAN48623UC35X |
| 2156-ML4872CS5X-ND | ML4872CS5X |
| 2156-ML4872CS5-ND | ML4872CS5 |
| 2156-LM2623AMMX/NOPB-296-ND | LM2623AMMX/NOPB |
| 2156-MIC2296YML-ND | MIC2296YML |
| TPS61045ADRBR-ND,2156-TPS61045ADRBR-ND | TPS61045ADRBR |
| 2156-FAN48623UC33X-ND | FAN48623UC33X |
| 893-XC9148G50CER-GTR-ND,893-XC9148G50CER-GCT-ND,893-XC9148G50CER-GDKR-ND | XC9148G50CER-G |
| 893-XC9148G50DER-GTR-ND,893-XC9148G50DER-GCT-ND,893-XC9148G50DER-GDKR-ND | XC9148G50DER-G |
| 2156-ML4871CS3-ND | ML4871CS3 |
| 296-51245-2-ND,296-51245-1-ND,296-51245-6-ND,2156-LM2623QNHLRQ1-ND | LM2623QNHLRQ1 |
| 2156-ML4872CS3X-ND | ML4872CS3X |
| 2156-ML4872CS3-ND | ML4872CS3 |
| 2156-ILC6380CP-33-ND | ILC6380CP-33 |
| 2156-ILC6380BP-50-ND | ILC6380BP-50 |
| 2156-ILC6380CP-50-ND | ILC6380CP-50 |
| 2156-ILC6380CP-25-ND | ILC6380CP-25 |
| 2156-ILC6380AP-50-ND | ILC6380AP-50 |
| 2156-ML4861CS6-ND | ML4861CS6 |
| MCP1642BT-30I/MSTR-ND,MCP1642BT-30I/MSCT-ND,MCP1642BT-30I/MSDKR-ND | MCP1642BT-30I/MS |
| 2156-ML4870CS3-ND | ML4870CS3 |
| 2156-ML4872ES5-ND | ML4872ES5 |
| 2156-ML4769ES-ND | ML4769ES |
| 2156-ML4769ESX-ND | ML4769ESX |
| 2156-ML4775CS8-ND | ML4775CS8 |
| 2156-ILC6390CM-33-ND | ILC6390CM-33 |
| 893-XC9148G33CER-GTR-ND,893-XC9148G33CER-GCT-ND,893-XC9148G33CER-GDKR-ND | XC9148G33CER-G |
| 893-XC9148H33CER-GTR-ND,893-XC9148H33CER-GCT-ND,893-XC9148H33CER-GDKR-ND | XC9148H33CER-G |
| 2156-ILC6391CM-50-ND | ILC6391CM-50 |
| 2156-ILC6390CP-33-ND | ILC6390CP-33 |
| 2156-ILC6390CP-50-ND | ILC6390CP-50 |
| 2156-ML4890CST-ND | ML4890CST |
| 2156-ILC6381BP-50-ND | ILC6381BP-50 |
| 2156-ILC6381AP-33-ND | ILC6381AP-33 |
| 2156-ILC6381AP-50-ND | ILC6381AP-50 |
| 2156-ADP1109AR-5-ND | ADP1109AR-5 |
| 2156-ADP1109AR-12-ND | ADP1109AR-12 |
| 2156-ML4865CS2-ND | ML4865CS2 |
| 2156-ML4961ES-ND | ML4961ES |
| 2156-ML4890CSTX-ND | ML4890CSTX |
| 2156-MAX5026EUT-T-ND | MAX5026EUT-T |
| MCP1642B-33I/MC-ND | MCP1642B-33I/MC |
| 1028-1077-2-ND,1028-1077-1-ND | RT9261A-50GB |
| MCP1642B-ADJI/MC-ND | MCP1642B-ADJI/MC |
| MCP1642B-50I/MC-ND | MCP1642B-50I/MC |
| MCP1642D-50I/MC-ND | MCP1642D-50I/MC |
| 2156-LM2622MM-ADJ-ND | LM2622MM-ADJ |
| 2156-LM3310SQ-ND | LM3310SQ |
| 2156-TL499ACPS-ND | TL499ACPS |
| 2156-MAX8569BETT30-T-ND | MAX8569BETT30-T |
| 2156-MAX1643ESA-ND | MAX1643ESA |
| 2156-MAX654CSD-T-ND | MAX654CSD-T |
| 2156-MAX8569BETT30-ND | MAX8569BETT30 |
| 2156-MAX656EPD-ND | MAX656EPD |
| 2156-MAX658CPD-ND | MAX658CPD |
| 2156-MAX4193CTV-ND | MAX4193CTV |
| 2156-MAX658EPD-ND | MAX658EPD |
| 2156-MAX4193CJA-ND | MAX4193CJA |
| 2156-MAX654ESD-ND | MAX654ESD |
| 2156-MAX658ESD-ND | MAX658ESD |
| 296-LM8850URE/NOPBTR-ND,296-LM8850URE/NOPBCT-ND,296-LM8850URE/NOPBDKR-ND | LM8850URE/NOPB |
| 2156-TPS61011DGSR-ND | TPS61011DGSR |
| ISL78113AARAZ-TTR-ND,ISL78113AARAZ-TCT-ND,ISL78113AARAZ-TDKR-ND | ISL78113AARAZ-T |
| 1028-RT9277CGFTR-ND,1028-RT9277CGFCT-ND,1028-RT9277CGFDKR-ND | RT9277CGF |
| 2156-TPS61003DGSR-ND | TPS61003DGSR |
| 2156-TPS61004DGSR-ND | TPS61004DGSR |
| 2156-TPS61007DGSR-ND | TPS61007DGSR |
| 2156-TPS61001DGSR-ND | TPS61001DGSR |
| 296-16662-2-ND,296-16662-1-ND,296-16662-6-ND,2156-TPS61032RSAR-ND | TPS61032RSAR |
| 296-TPS61281YFFTTR-ND,296-TPS61281YFFTCT-ND,296-TPS61281YFFTDKR-ND,2156-TPS61281YFFT-ND | TPS61281YFFT |
| 893-XC9148H36CER-GTR-ND,893-XC9148H36CER-GCT-ND,893-XC9148H36CER-GDKR-ND | XC9148H36CER-G |
| 893-XC9148G36DER-GTR-ND,893-XC9148G36DER-GCT-ND,893-XC9148G36DER-GDKR-ND | XC9148G36DER-G |
| 893-XC9148H50DER-GTR-ND,893-XC9148H50DER-GCT-ND,893-XC9148H50DER-GDKR-ND | XC9148H50DER-G |
| 893-XC9148H36DER-GTR-ND,893-XC9148H36DER-GCT-ND,893-XC9148H36DER-GDKR-ND | XC9148H36DER-G |
