When looking at the RS20 series switch hubs from Hirschmann on the Digi-Key website you will notice that the last suffix is XX.X. such as in RS20-0800M2M2SDAEHHXX.X. instead of a number such as 05002 as in the RS20-0800M2M2SDAEHH05002, that is because this suffix calls out the software version that comes with it. When we receive them from the manufacturer, they typically have the newest version of the software, whereas the one you are trying to replace would have an older version so if we did put the software version suffix number they would not match anyway. Other than the software version, these part numbers refer to the same part. In most cases using a newer software version will not negatively affect outcomes.
You can also update the software through the manufacturer website: Hirschmann - a Belden Brand
Applicable Part Numbers
| Digi-Key Part Numbers | Manufacturer Part Numbers |
| 1797-1018-ND | RS20-0800M2M2SDAEHHXX.X. |
| 1797-1049-ND | 943434007 |
| 1797-1050-ND | 943434017 |
| 1797-1051-ND | 943434019 |
| 1797-1021-ND | RS20-1600T1T1SDAEHHXX.X.XX |
| 1797-1048-ND | 943434066 |
| RS20-0400-008-ND | RS20-0400-008 |
| 1797-1052-ND | 943434005 |
| 1797-1047-ND | 943434001 |
| 1797-1017-ND | RS20-0800T1T1SDAEHHXX.X.XX |
| 1797-1053-ND | 943434041 |
| HNT000136-ND | HNT000136 |
| RS20-0400-011-ND | RS20-0400-011 |
| 943434999-61-ND | 943434999-61 |
| HNT000647-ND | HNT000647 |
| HNT000137-ND | HNT000137 |
| 943434008-ND | 943434008 |
| HNT000138-ND | HNT000138 |
| HNT000139-ND | HNT000139 |
| HNT000118-ND | HNT000118 |
| 943434009-ND | 943434009 |
| HNT000140-ND | HNT000140 |
| HNT000119-ND | HNT000119 |
| HNT000646-ND | HNT000646 |
| HNT000553-ND | HNT000553 |
| 943434010-ND | 943434010 |
| RS20-0400-007-ND | RS20-0400-007 |
| HNT000113-ND | HNT000113 |
| HNT000114-ND | HNT000114 |
| HNT000742-ND | HNT000742 |
| 943434999-148-ND | 943434999-148 |
| HNT000135-ND | HNT000135 |
| HNT000134-ND | HNT000134 |
| 943434011-ND | 943434011 |
| HNT000447-ND | HNT000447 |
| RS20-0400-009-ND | RS20-0400-009 |
| 943434999-84-ND | 943434999-84 |
| HNT000112-ND | HNT000112 |
| 943434999-64-ND | 943434999-64 |
| 943434012-ND | 943434012 |
| HNT000107-ND | HNT000107 |
| HNT000377-ND | HNT000377 |
| HNT000109-ND | HNT000109 |
| HNT000200-ND | HNT000200 |
| 943434002-ND | 943434002 |
| HNT000111-ND | HNT000111 |
| 943434999-123-ND | 943434999-123 |
| HNT000129-ND | HNT000129 |
| HNT000110-ND | HNT000110 |
| HNT000117-ND | HNT000117 |
| HNT000360-ND | HNT000360 |
| HNT000120-ND | HNT000120 |
| HNT000359-ND | HNT000359 |
| HNT000581-ND | HNT000581 |
| RS20-0400-002-ND | RS20-0400-002 |
| 943434999-85-ND | 943434999-85 |
| 943434022-ND | 943434022 |
| HNT000622-ND | HNT000622 |
| 943434999-72-ND | 943434999-72 |
| HNT000533-ND | HNT000533 |
| HNT000108-ND | HNT000108 |
| HNT000723-ND | HNT000723 |
| HNT000375-ND | HNT000375 |
| HNT000205-ND | HNT000205 |
| HNT000611-ND | HNT000611 |
| HNT000130-ND | HNT000130 |
| 943434999-171-ND | 943434999-171 |
| HNT000161-ND | HNT000161 |
| HNT000179-ND | HNT000179 |
| HNT000479-ND | HNT000479 |
| 943434065-ND | 943434065 |
| 943434999-118-ND | 943434999-118 |
| 943434999-152-ND | 943434999-152 |
| HNT000105-ND | HNT000105 |
| HNT000115-ND | HNT000115 |
| HNT000202-ND | HNT000202 |
| HNT000431-ND | HNT000431 |
| RS20-0400-001-ND | RS20-0400-001 |
| HNT000121-ND | HNT000121 |
| 943434999-185-ND | 943434999-185 |
| HNT000128-ND | HNT000128 |
| 943434999-20-ND | 943434999-20 |
| HNT000180-ND | HNT000180 |
| HNT000387-ND | HNT000387 |
| HNT000426-ND | HNT000426 |
| 943434999-213-ND | 943434999-213 |
| HNT000538-ND | HNT000538 |
| RS20-0400-006-ND | RS20-0400-006 |
| HNT000132-ND | HNT000132 |
| HNT000199-ND | HNT000199 |
| HNT000610-ND | HNT000610 |
| RS20-0400-005-ND | RS20-0400-005 |
| 943434013-ND | 943434013 |
| 943434999-52-ND | 943434999-52 |
| HNT000162-ND | HNT000162 |
| HNT000165-ND | HNT000165 |
| HNT000678-ND | HNT000678 |
| 943434999-165-ND | 943434999-165 |
| HNT000126-ND | HNT000126 |
| RS20-0400-003-ND | RS20-0400-003 |
| HNT000572-ND | HNT000572 |
| HNT000604-ND | HNT000604 |
| 943434014-ND | 943434014 |
| HNT000192-ND | HNT000192 |
| HNT000587-ND | HNT000587 |
| HNT000151-ND | HNT000151 |
| HNT000159-ND | HNT000159 |
| HNT000169-ND | HNT000169 |
| RS20-0800-014-ND | RS20-0800-014 |
| HNT000636-ND | HNT000636 |
| HNT000116-ND | HNT000116 |
| RS20-0400-010-ND | RS20-0400-010 |
| 943434999-3-ND | 943434999-3 |
| HNT000127-ND | HNT000127 |
| HNT000545-ND | HNT000545 |
| 943434015-ND | 943434015 |
| HNT000166-ND | HNT000166 |
| HNT000160-ND | HNT000160 |
| HNT000178-ND | HNT000178 |
| HNT000499-ND | HNT000499 |
| HNT000133-ND | HNT000133 |
| HNT000486-ND | HNT000486 |
| 943434999-141-ND | 943434999-141 |
| HNT000193-ND | HNT000193 |
| 943434018-ND | 943434018 |
| 943434004-ND | 943434004 |
| HNT000152-ND | HNT000152 |
| HNT000362-ND | HNT000362 |
| 943434999-149-ND | 943434999-149 |
| 943434999-J-ND | 943434999-J |
| HNT000175-ND | HNT000175 |
| 943434999-40-ND | 943434999-40 |
| RS20-0800-002-ND | RS20-0800-002 |
| HNT000122-ND | HNT000122 |
| HNT000131-ND | HNT000131 |
| HNT000745-ND | HNT000745 |
| HNT000181-ND | HNT000181 |
| HNT000194-ND | HNT000194 |
| HNT000173-ND | HNT000173 |
| HNT000154-ND | HNT000154 |
| HNT000589-ND | HNT000589 |
| 943434999-39-ND | 943434999-39 |
| HNT000158-ND | HNT000158 |
| 943434016-ND | 943434016 |
| HNT000123-ND | HNT000123 |
| HNT000125-ND | HNT000125 |
| 943434999-71-ND | 943434999-71 |
| HNT000210-ND | HNT000210 |
| HNT000217-ND | HNT000217 |
| HNT000629-ND | HNT000629 |
| 943434999-205-ND | 943434999-205 |
| 943434999-151-ND | 943434999-151 |
| HNT000146-ND | HNT000146 |
| HNT000168-ND | HNT000168 |
| HNT000406-ND | HNT000406 |
| RS20-0800-012-ND | RS20-0800-012 |
| 943434999-126-ND | 943434999-126 |
| 943434999-19-ND | 943434999-19 |
| RS20-0800-011-ND | RS20-0800-011 |
| 943434999-35-ND | 943434999-35 |
| HNT000624-ND | HNT000624 |
| HNT000171-ND | HNT000171 |
| HNT000502-ND | HNT000502 |
| HNT000651-ND | HNT000651 |
| 943434999-170-ND | 943434999-170 |
| RS20-0800-007-ND | RS20-0800-007 |
| HNT000197-ND | HNT000197 |
| HNT000476-ND | HNT000476 |
| 943434999-30-ND | 943434999-30 |
| HNT000258-ND | HNT000258 |
| RS20-0800-010-ND | RS20-0800-010 |
| HNT000212-ND | HNT000212 |
| 943434999-142-ND | 943434999-142 |
| HNT000392-ND | HNT000392 |
| 943434999-11-ND | 943434999-11 |
| HNT000147-ND | HNT000147 |
| RS20-0800-013-ND | RS20-0800-013 |
| 943434999-22-ND | 943434999-22 |
| HNT000214-ND | HNT000214 |
| HNT000188-ND | HNT000188 |
| RS20-0800-008-ND | RS20-0800-008 |
| HNT000661-ND | HNT000661 |
| HNT000497-ND | HNT000497 |
| HNT000513-ND | HNT000513 |
| 943434020-ND | 943434020 |
| HNT000207-ND | HNT000207 |
| HNT000441-ND | HNT000441 |
| HNT000189-ND | HNT000189 |
| RS20-0800-009-ND | RS20-0800-009 |
| 943434999-86-ND | 943434999-86 |
| HNT000697-ND | HNT000697 |
| 943434025-ND | 943434025 |
| HNT000260-ND | HNT000260 |
| HNT000652-ND | HNT000652 |
| RS20-0900-002-ND | RS20-0900-002 |
| HNT000706-ND | HNT000706 |
| 943434999-26-ND | 943434999-26 |
| HNT000492-ND | HNT000492 |
| HNT000580-ND | HNT000580 |
| HNT000191-ND | HNT000191 |
| RS20-0900-003-ND | RS20-0900-003 |
| HNT000758-ND | HNT000758 |
| HNT000480-ND | HNT000480 |
| HNT000253-ND | HNT000253 |
| HNT000548-ND | HNT000548 |
| 943434024-ND | 943434024 |
| 943434999-63-ND | 943434999-63 |
| HNT000221-ND | HNT000221 |
| HNT000104-ND | HNT000104 |
| HNT000213-ND | HNT000213 |
| HNT000641-ND | HNT000641 |
| HNT000190-ND | HNT000190 |
| HNT000183-ND | HNT000183 |
| HNT000195-ND | HNT000195 |
| 943434999-124-ND | 943434999-124 |
| 943434999-174-ND | 943434999-174 |
| HNT000254-ND | HNT000254 |
| 943434999-55-ND | 943434999-55 |
| HNT000208-ND | HNT000208 |
| HNT000250-ND | HNT000250 |
| 943434999-125-ND | 943434999-125 |
| 943434999-143-ND | 943434999-143 |
| HNT000186-ND | HNT000186 |
| 943434999-136-ND | 943434999-136 |
| HNT000239-ND | HNT000239 |
| HNT000504-ND | HNT000504 |
| HNT000591-ND | HNT000591 |
| 943434999-53-ND | 943434999-53 |
| 943434999-65-ND | 943434999-65 |
| HNT000427-ND | HNT000427 |
| RS20-1600-006-ND | RS20-1600-006 |
| RS20-0900-004-ND | RS20-0900-004 |
| HNT000184-ND | HNT000184 |
| RS20-0800-001-ND | RS20-0800-001 |
| HNT000224-ND | HNT000224 |
| HNT000546-ND | HNT000546 |
| HNT000738-ND | HNT000738 |
| HNT000235-ND | HNT000235 |
| 943434026-ND | 943434026 |
| 943434999-44-ND | 943434999-44 |
| 943434999-45-ND | 943434999-45 |
| 943434999-179-ND | 943434999-179 |
| 943434999-95-ND | 943434999-95 |
| HNT000233-ND | HNT000233 |
| 943434999-67-ND | 943434999-67 |
| 943434999-23-ND | 943434999-23 |
| 943434999-16-ND | 943434999-16 |
| HNT000245-ND | HNT000245 |
| 943434209-ND | 943434209 |
| HNT000450-ND | HNT000450 |
| HNT000230-ND | HNT000230 |
| RS20-0900-001-ND | RS20-0900-001 |
| HNT000255-ND | HNT000255 |
| HNT000650-ND | HNT000650 |
| 943434999-159-ND | 943434999-159 |
| HNT000103-ND | HNT000103 |
| HNT000625-ND | HNT000625 |
| HNT000443-ND | HNT000443 |
| HNT000240-ND | HNT000240 |
| HNT000648-ND | HNT000648 |
| HNT000228-ND | HNT000228 |
| HNT000238-ND | HNT000238 |
| 943434006-ND | 943434006 |
| 943434999-10-ND | 943434999-10 |
| HNT000495-ND | HNT000495 |
| HNT000623-ND | HNT000623 |
| 943434999-229-ND | 943434999-229 |
| RS20-1600-007-ND | RS20-1600-007 |
| HNT000577-ND | HNT000577 |
| HNT000232-ND | HNT000232 |
| HNT000242-ND | HNT000242 |
| 943434027-ND | 943434027 |
| 943434999-83-ND | 943434999-83 |
| HNT000619-ND | HNT000619 |
| 943434999-66-ND | 943434999-66 |
| HNT000262-ND | HNT000262 |
| HNT000266-ND | HNT000266 |
| HNT000435-ND | HNT000435 |
| HNT000243-ND | HNT000243 |
| 943434999-223-ND | 943434999-223 |
| 943434999-25-ND | 943434999-25 |
| HNT000231-ND | HNT000231 |
| 943434999-101-ND | 943434999-101 |
| 943434999-102-ND | 943434999-102 |
| HNT000223-ND | HNT000223 |
| HNT000286-ND | HNT000286 |
| HNT000264-ND | HNT000264 |
| HNT000265-ND | HNT000265 |
| HNT000526-ND | HNT000526 |
| 943434999-158-ND | 943434999-158 |
| HNT000639-ND | HNT000639 |
| 943434999-128-ND | 943434999-128 |
| HNT000719-ND | HNT000719 |
| HNT000267-ND | HNT000267 |
| 943434999-160-ND | 943434999-160 |
| HNT000246-ND | HNT000246 |
| 943434028-ND | 943434028 |
| HNT000586-ND | HNT000586 |
| HNT000261-ND | HNT000261 |
| HNT000274-ND | HNT000274 |
| HNT000280-ND | HNT000280 |
| HNT000698-ND | HNT000698 |
| HNT000288-ND | HNT000288 |
| RS20-2400-005-ND | RS20-2400-005 |
| HNT000143-ND | HNT000143 |
| 943434999-56-ND | 943434999-56 |
| RS20-2400-002-ND | RS20-2400-002 |
| HNT000517-ND | HNT000517 |
| RS20-1700-001-ND | RS20-1700-001 |
| 943434999-220-ND | 943434999-220 |
| HNT000284-ND | HNT000284 |
| HNT000627-ND | HNT000627 |
| 943434999-32-ND | 943434999-32 |
| HNT000278-ND | HNT000278 |
| 943434043-ND | 943434043 |
| HNT000621-ND | HNT000621 |
| 943434042-ND | 943434042 |
| HNT000272-ND | HNT000272 |
| 943434999-1-ND | 943434999-1 |
| HNT000279-ND | HNT000279 |
| HNT000649-ND | HNT000649 |
| 943434999-51-ND | 943434999-51 |
| HNT000428-ND | HNT000428 |
| HNT000592-ND | HNT000592 |
| HNT000281-ND | HNT000281 |
| HNT000275-ND | HNT000275 |
| HNT000503-ND | HNT000503 |
| HNT000142-ND | HNT000142 |
| HNT000268-ND | HNT000268 |
| HNT000277-ND | HNT000277 |
| 943434999-96-ND | 943434999-96 |
| 943434045-ND | 943434045 |
| HNT000270-ND | HNT000270 |
| HNT000364-ND | HNT000364 |
| HNT000429-ND | HNT000429 |
| 943434044-ND | 943434044 |
| HNT000291-ND | HNT000291 |
| HNT000273-ND | HNT000273 |
| 943434999-107-ND | 943434999-107 |
| 943434999-108-ND | 943434999-108 |
| HNT000282-ND | HNT000282 |
| 943434999-68-ND | 943434999-68 |
| 943434999-137-ND | 943434999-137 |
| HNT000269-ND | HNT000269 |
| RS20-2400-007-ND | RS20-2400-007 |
| HNT000292-ND | HNT000292 |
| HNT000141-ND | HNT000141 |
| HNT000294-ND | HNT000294 |
| HNT000283-ND | HNT000283 |
| 943434999-163-ND | 943434999-163 |
| HNT000227-ND | HNT000227 |
| 943434999-132-ND | 943434999-132 |
| 943434999-15-ND | 943434999-15 |
| 1797-943434047-ND | 943434047 |
| 943434048-ND | 943434048 |
| 943434049-ND | 943434049 |
| 943434051-ND | 943434051 |
| 943434052-ND | 943434052 |
| 943434053-ND | 943434053 |
| 943434054-ND | 943434054 |
| 943434057-ND | 943434057 |
| 943434058-ND | 943434058 |
| 943434059-ND | 943434059 |
| 943434060-ND | 943434060 |
| 943434270-ND | 943434270 |
| 943434271-ND | 943434271 |
| 943434272-ND | 943434272 |
| 943434501-ND | 943434501 |
| 943434502-ND | 943434502 |
| 943434503-ND | 943434503 |
| 943434504-ND | 943434504 |
| 943434999-119-ND | 943434999-119 |
| 943434999-12-ND | 943434999-12 |
| 943434999-131-ND | 943434999-131 |
| 943434999-14-ND | 943434999-14 |
| 943434999-164-ND | 943434999-164 |
| 943434999-172-ND | 943434999-172 |
| 943434999-173-ND | 943434999-173 |
| 943434999-181-ND | 943434999-181 |
| 943434999-2-ND | 943434999-2 |
| 943434999-228-ND | 943434999-228 |
| 943434999-24-ND | 943434999-24 |
| 943434999-33-ND | 943434999-33 |
| 943434999-58-ND | 943434999-58 |
| 943434999-6-ND | 943434999-6 |
| 943434999-74-ND | 943434999-74 |
| 943434999-76-ND | 943434999-76 |
| HNT000144-ND | HNT000144 |
| HNT000145-ND | HNT000145 |
| HNT000149-ND | HNT000149 |
| HNT000153-ND | HNT000153 |
| HNT000155-ND | HNT000155 |
| HNT000157-ND | HNT000157 |
| HNT000163-ND | HNT000163 |
| HNT000164-ND | HNT000164 |
| HNT000167-ND | HNT000167 |
| HNT000170-ND | HNT000170 |
| HNT000172-ND | HNT000172 |
| HNT000174-ND | HNT000174 |
| HNT000176-ND | HNT000176 |
| HNT000177-ND | HNT000177 |
| HNT000182-ND | HNT000182 |
| HNT000185-ND | HNT000185 |
| HNT000187-ND | HNT000187 |
| HNT000196-ND | HNT000196 |
| HNT000198-ND | HNT000198 |
| HNT000201-ND | HNT000201 |
| HNT000203-ND | HNT000203 |
| HNT000204-ND | HNT000204 |
| HNT000206-ND | HNT000206 |
| HNT000211-ND | HNT000211 |
| HNT000215-ND | HNT000215 |
| HNT000216-ND | HNT000216 |
| HNT000218-ND | HNT000218 |
| HNT000219-ND | HNT000219 |
| HNT000220-ND | HNT000220 |
| HNT000222-ND | HNT000222 |
| HNT000225-ND | HNT000225 |
| HNT000226-ND | HNT000226 |
| HNT000229-ND | HNT000229 |
| HNT000234-ND | HNT000234 |
| HNT000236-ND | HNT000236 |
| HNT000237-ND | HNT000237 |
| HNT000241-ND | HNT000241 |
| HNT000247-ND | HNT000247 |
| HNT000248-ND | HNT000248 |
| HNT000252-ND | HNT000252 |
| HNT000257-ND | HNT000257 |
| HNT000259-ND | HNT000259 |
| HNT000263-ND | HNT000263 |
| HNT000271-ND | HNT000271 |
| HNT000276-ND | HNT000276 |
| HNT000285-ND | HNT000285 |
| HNT000287-ND | HNT000287 |
| HNT000289-ND | HNT000289 |
| HNT000290-ND | HNT000290 |
| HNT000293-ND | HNT000293 |
| HNT000361-ND | HNT000361 |
| HNT000363-ND | HNT000363 |
| HNT000379-ND | HNT000379 |
| HNT000382-ND | HNT000382 |
| HNT000415-ND | HNT000415 |
| HNT000422-ND | HNT000422 |
| HNT000464-ND | HNT000464 |
| HNT000487-ND | HNT000487 |
| HNT000508-ND | HNT000508 |
| HNT000509-ND | HNT000509 |
| HNT000522-ND | HNT000522 |
| HNT000531-ND | HNT000531 |
| HNT000543-ND | HNT000543 |
| HNT000579-ND | HNT000579 |
| HNT000594-ND | HNT000594 |
| HNT000601-ND | HNT000601 |
| HNT000634-ND | HNT000634 |
| HNT000640-ND | HNT000640 |
| HNT000704-ND | HNT000704 |
| HNT000718-ND | HNT000718 |
| HNT000725-ND | HNT000725 |
| HNT000743-ND | HNT000743 |
| HNT000750-ND | HNT000750 |
| HNT000753-ND | HNT000753 |
| HNT000763-ND | HNT000763 |
| RS20-0800-003-ND | RS20-0800-003 |
| RS20-0800-005-ND | RS20-0800-005 |
| RS20-0800-006-ND | RS20-0800-006 |
| RS20-0800-015-ND | RS20-0800-015 |
| RS20-1600-003-ND | RS20-1600-003 |
| RS20-1600-004-ND | RS20-1600-004 |
| RS20-2400S-001-ND | RS20-2400S-001 |
| 1797-943434056-ND | 943434056 |
| 1797-943434055-ND | 943434055 |
