Where can I get a IC Schematic
------Question for LBAD0XX1SC-151 Please Put your question below------
I want to use this IC instead of the SIM7600E on my development board that I will be sending for assembly. My contractor tells me that he needs an IC Shematic for this chip so that he knows how to wire it up in the PCB design.
Does anyone know where I can get a IC Schematic or the information that he needs in order to do his work?
@Jay_Hox Welcome To DigiKey TechForum
Please refer to its datasheet to check Section 2 [Mechanical Specification]
You can find IC Pin Configuration and Pinout information for your PCB design.
I am not the designer so I don’t know if there is a difference between that and a “reference schematic” but my designer is asking for more.
The ChatGPT pointed to was locked behind a membership login and then later by a code that I guess you get when you buy ine if them?
Jerrad Hoxie
@Jay_Hox Please have your designer review the datasheet first. If still have questions, please provide details of this technical issues.
