Wire Ferrule vs Pin Terminal
Two similar parts that can be found on the Digi-Key website are Quick Connect Pin Terminals and Crimp Wire Ferrules. As you can see in the picture below the two parts look very similar and can be used for similar applications.
While both items can be used in similar applications there are some differences in the two parts.
Terminal Pins
The Terminal pin also called a Wire Pin Connector is crimped on the insulation and the pin area often has a smaller diameter than the wire. This makes it ideal for wire to board applications in which you will be soldering the pin through a hole on the board. You can also use this in a terminal block application as well, however if there is stress on the wire there is often a weak point that could cause issues in the long run.
Wire Ferrules
Wire Ferrules on the other hand will crimp on the barrel end of the terminal so the diameter of the connection will be the slightly larger than the actual wire itself. This is ideal for using in an industrial cabinet situation as you get a clean connection into any terminal block or other cabinet application. The larger surface area will allow for direct application to a board, however due to the larger size there is additional surface area that would need to be heated in a solder application which makes it not an ideal choice for this situation.
See Also : Using and Crimping Wire Ferrules
[Details= Applicable Part numbers]
288-1008-ND 288-1015-ND 288-1124-ND 288-1007-ND 288-1019-ND 288-1024-ND 298-10036-ND 288-1127-ND 298-10286-ND 277-2188-ND 277-2190-ND 277-2185-ND 288-1014-ND 288-1111-ND 298-10558-ND 288-1005-ND 288-1006-ND 288-1020-ND 288-1027-ND 298-10411-ND 277-2205-ND 277-2155-ND 288-1030-ND 277-2183-ND 277-2160-ND 298-10757-ND 298-10768-ND 298-10747-ND 298-10756-ND 298-11992-ND 298-10746-ND 298-11526-2-ND 298-11526-1-ND 298-10758-ND 288-1077-ND 298-10759-ND 288-1078-ND A114631-ND 288-1080-ND 288-1082-ND 288-1081-ND 288-1079-ND A114630-ND 288-1088-ND 288-1084-ND 288-1090-ND 288-1091-ND 288-1094-ND 288-1093-ND A122006-ND 288-1095-ND 288-1107-ND A114627-ND A114628-ND 277-2171-ND A105263-ND 288-1105-ND A106991-ND 1-966067-2-ND 288-1011-ND 288-1049-ND 288-1102-ND 288-1046-ND 288-1099-ND A107004-ND 277-2175-ND 288-1101-ND 288-1384-ND 277-2207-ND 277-2165-ND 288-1053-ND 277-2162-ND 277-2164-ND 288-1389-ND 288-1125-ND A114632-ND 288-1387-ND 288-1009-ND 288-1047-ND 288-1013-ND 288-1010-ND 288-1048-ND 288-1012-ND 288-1057-ND 277-5453-ND 277-5546-ND 298-10035-ND 298-10559-ND 298-10037-ND 298-10038-ND 298-10560-ND 298-10285-ND 298-10765-ND A114635-ND 288-1016-ND 277-2186-ND 288-1052-ND 288-1041-ND 288-1114-ND 288-1017-ND 277-2208-ND 288-1054-ND 277-2176-ND 277-2178-ND 277-10205-ND 288-1129-ND 288-1023-ND 288-1110-ND 2-966067-2-ND 288-1003-ND 277-2209-ND 298-10034-ND 288-1001-ND 277-2193-ND 298-10033-ND 298-10284-ND 298-10556-ND 298-10557-ND 288-1039-ND 288-1043-ND 288-1025-ND 298-10287-ND 298-10766-ND 288-1002-ND 288-1042-ND 288-1044-ND 288-1004-ND 288-1040-ND 277-2163-ND 288-1021-ND 277-2184-ND 288-1018-ND 288-1128-ND 277-2189-ND 277-2187-ND 298-10039-ND 288-1028-ND 298-10289-ND 277-2170-ND 298-10041-ND 277-2204-ND 288-1132-ND 288-1131-ND 288-1130-ND 277-2433-ND 277-5637-ND 277-5429-ND 277-2156-ND 298-10042-ND 298-10561-ND 277-2196-ND 277-2191-ND 288-1032-ND 288-1068-ND 288-1070-ND 277-2216-ND 277-2215-ND 298-10565-ND 298-10564-ND 277-9659-ND 277-2181-ND 277-2217-ND 277-2219-ND 277-2152-ND 288-1034-ND 298-10769-ND 298-10290-ND 277-2221-ND 288-1133-ND 277-2218-ND 298-10562-ND 277-2212-ND 288-1134-ND 288-1033-ND 277-7433-ND 288-1135-ND 288-1035-ND 298-10764-ND 288-1121-ND 298-10755-ND 281-3066-ND 298-10410-ND 288-1083-ND 288-1089-ND A122173-ND 288-1092-ND 288-1096-ND 288-1106-ND A106358-ND 277-2173-ND A122123-ND 277-5661-ND 277-2172-ND 288-1097-ND A122682-ND 288-1100-ND 288-1062-ND 277-2177-ND 277-5402-ND 277-5469-ND 288-1050-ND 281-3115-ND 288-1055-ND 288-1126-ND 277-10204-ND 277-5434-ND 277-10202-ND 288-1386-ND 277-10203-ND A109135-ND A113396-ND 277-2179-ND 288-1063-ND 277-2206-ND 288-1058-ND 288-1056-ND 288-1059-ND 277-5460-ND 277-10206-ND 298-10040-ND 288-1065-ND 288-1066-ND 277-2180-ND 288-1390-ND 298-10288-ND 277-5662-ND 277-5476-ND 277-5600-ND 277-2194-ND 298-10412-ND 277-2159-ND 298-10563-ND 277-2214-ND 288-1074-ND 277-5541-ND 277-2158-ND 298-11523-2-ND 298-11523-1-ND 298-10745-ND 298-10748-ND 298-10753-ND 298-10760-ND 298-10750-ND 298-10749-ND 298-10761-ND A123859-ND 298-11527-2-ND 298-11527-1-ND A128328-ND 277-5415-ND 298-10752-ND 277-15265-ND A128329-ND 277-5660-ND 298-10751-ND 277-15262-ND 277-15266-ND 298-10770-ND A112906-ND A119231-ND 298-10763-ND 298-10767-ND 298-11524-2-ND 298-11524-1-ND A110953TR-ND A110953CT-ND A110954TR-ND A110954CT-ND A107151TR-ND A107151CT-ND 1920-1230-ND 1920-1232-ND 1920-1234-ND A114633-ND A114634-ND A109140-ND A112905-ND 298-11528-2-ND 298-11528-1-ND 1920-1233-ND 1920-1231-ND A107991-ND 1920-1226-ND 1920-1229-ND 1920-1225-ND 1920-1224-ND A113397-ND 1920-1227-ND 281-3068-ND 288-1045-ND 277-2161-ND 277-2166-ND 277-2213-ND 288-1036-ND 281-3065-ND 281-3097-ND 281-3070-ND 281-3067-ND 281-3099-ND 281-3085-ND 281-3069-ND 281-3071-ND 281-3073-ND 288-1085-ND 288-1086-ND 277-5619-ND 277-7432-ND 288-1388-ND 277-5558-ND 277-9616-ND 277-2211-ND 288-1029-ND 277-2157-ND 277-5602-ND 277-2182-ND 277-2197-ND 277-5507-ND 277-2168-ND 277-5459-ND 277-2192-ND 277-5559-ND 277-2195-ND 277-2220-ND 277-5584-ND 277-5601-ND 277-2198-ND 277-2222-ND 277-5663-ND 277-2200-ND 277-5480-ND 277-5603-ND 277-5690-ND 277-5664-ND 277-2201-ND 277-2153-ND 277-5516-ND 288-1405-ND 277-2223-ND 277-5606-ND 277-2224-ND 277-2167-ND 277-9612-ND 277-5623-ND 277-5665-ND 277-2203-ND 281-3074-ND 288-1061-ND WM17390-ND 277-12712-ND 277-15263-ND 277-15261-ND 277-12713-ND 298-11525-2-ND 298-11525-1-ND 277-12722-ND 277-12723-ND 277-15448-ND 298-10762-ND 277-15268-ND 277-15449-ND 277-2210-ND 277-9613-ND 298-10754-ND 277-5692-ND 277-2154-ND 277-15259-ND 277-15257-ND 277-15258-ND 277-12479-ND 281-3305-ND A107990-ND 277-12478-3-ND 277-12478-1-ND 277-5582-3-ND 277-5582-1-ND 298-10047-ND 1920-1228-ND 277-2199-ND 277-5659-ND 277-2202-ND 281-3080-ND 281-3072-ND 277-2174-ND 277-5622-ND 277-2169-ND 277-9614-ND A129216-ND A129213-ND A129214-ND 277-15264-ND A129215-ND A128693-ND 277-15256-ND 277-15260-ND 0936020004-ND 0936020006-ND 0936020007-ND 0936020001-ND 0936020002-ND 0936020003-ND 0936020009-ND 0936020011-ND 0936020012-ND 0936020013-ND 0936020017-ND 0936020018-ND 0936020019-ND 0936020020-ND 0936020008-ND 0936020014-ND 0936020024-ND 0936020025-ND 966900-2-ND 0936020021-ND 966902-2-ND 0936020015-ND 0936020022-ND 0936020023-ND 0936020026-ND 0936020027-ND 0936020028-ND 966903-2-ND 0936020005-ND 966904-2-ND 0936020031-ND 0936020032-ND 966384-3-ND 0936020033-ND 0936020034-ND 72/10VZ-ND 288-1087-ND 0936020029-ND 0936020030-ND A116155TR-ND A116155CT-ND 737814-1-ND 471/8-ND 0936020037-ND 0936020038-ND 288-1098-ND 122010150-ND A114629-ND 2-966292-4-ND 288-1103-ND 288-1104-ND 288-1108-ND 122010250-ND 1241004-1-ND 288-1109-ND 966144-5-ND 122010400-ND 1183050-ND 1183075-ND MC1100-ND MC3100-ND MC2100-ND 0936020035-ND 0936020036-ND 469/8-ND FSD76-8-3K8-ND 1183010-ND F73-7-M-ND F74-5-M-ND F74-7-M-ND 74/12VZ-ND MC1050-ND MC3050-ND MC2050-ND MC1075-ND MC3075-ND MC2075-ND 1213200-ND 0936020039-ND 0936020043-ND 288-1144-ND 288-1139-ND 103100-ND F75-6-M-ND F76-12-M-ND F76-6-M-ND F76-8-M-ND F77-10-M-ND F77-12-M-ND F77-7-M-ND F77-8-M-ND FSD80-8-3K6-ND 288-1137-ND 288-1138-ND 288-1142-ND 288-1143-ND 103050-ND 103075-ND 1163050-ND 11103050-ND 74/15VZ-ND 288-1051-ND 1183025-ND 1163075-ND 11103075-ND 11123075-ND 1183015-ND F78-10-M-ND F78-12-M-ND F78-15-M-ND F78-8-M-ND MC1150-ND MC3150-ND MC2150-ND 737739-1-ND F80-10-M-ND F80-12-M-ND F80-7-M-ND F80-8-M-ND 0936020041-ND 0936020042-ND 0936020044-ND 0936020045-ND 0936020051-ND 169/6-ND 169/OK-ND 469/6-ND 471/6-ND 75/15VZ-ND 288-1112-ND 288-1113-ND 288-1115-ND 13102025-ND 1163010-ND 11103010-ND 11123010-ND 3240663-ND 76/15VZ-ND F78-18-M-ND F78-20-M-ND 474/10-ND 171/GH-ND 469/10-ND 288-1140-ND 288-1141-ND 288-1145-ND 288-1146-ND 1183208-ND 103150-ND 103250-ND MC1250-ND MC3250-ND MC2250-ND 2-966067-5-ND 1163014-ND 1163034-ND 174/12-ND 168/TL-ND 3202928-ND 0936020046-ND 0936020047-ND 0936020048-ND 0936020049-ND 0936020050-ND 288-1116-ND 288-1117-ND 11123025-ND 873/10-ND 171/GL-ND 1183014-ND 11630025-ND 11830025-ND 1183034-ND 1-966067-8-ND 3241129-ND 288-1385-ND F81-10-M-ND F81-12-M-ND F81-9-M-ND 473/12-ND F82-10-M-ND F82-12-M-ND 288-1022-ND 288-1060-ND 1163015-ND 1103015-ND 11123015-ND 11183015-ND 11103040-ND 11123040-ND 474/12-ND 873/13-ND 0936020052-ND 0936020053-ND 0936020054-ND 77/15VZ-ND 288-1118-ND 288-1119-ND 288-1120-ND 737740-1-ND 3240544-ND 3240664-ND 3240665-ND 3240666-ND 3240677-ND F80-15-M-ND F80-18-M-ND F80-20-M-ND 288-1026-ND 288-1064-ND 11183025-ND 737739-3-ND FSD76-8-K-ND FSD78-8-K-ND FSD76-10-D-ND 175/12-ND 473/18-ND 1220116-ND 1225116-ND 1232116-ND 3201563-ND 174/18-ND 3201576-ND 3201547-ND 3240542-ND 3240543-ND 3240545-ND 3240572-ND 3241128-ND 77/20VZ-ND 1-966067-1-ND 3240667-ND 3202591-ND 0936020010-ND 966066-4-ND F81-15-M-ND F81-18-M-ND F81-20-M-ND 3202601-ND 288-1067-ND 11183040-ND 3201372-ND 277-5687-ND 175/SL-ND 11123100-ND 11123060-ND 3202902-ND F84-12-TL-ND FSD78-18-D-ND 3240669-ND F82-15-M-ND F82-18-M-ND F82-20-M-ND 0936020016-ND F83-15-D-ND F83-18-D-ND 737740-3-ND 288-1031-ND 288-1069-ND 11183060-ND 477/12-ND 3201550-ND 3240249-ND 3240250-ND 3241126-ND 3202821-ND 288-1072-ND 11123160-ND F84-15-TL-ND F84-18-TL-ND 1-966144-2-ND FSD80-18-D-ND FSDXL78-8-C-ND F83-20-D-ND F83-25-D-ND FSDXL80-8-C-ND 3203134-ND 3203147-ND 3203118-ND 79/15VZ-ND 3201364-ND 177/GRL-ND 3202834-ND 3203163-ND 79/22VZ-ND FTD78-12-D-ND 288-1071-ND 13122040-ND 11183100-ND 1218150-ND F85-12-C-ND FSDXL81-10-C-ND 3241125-ND 1222150-ND FSDXL78-10-C-ND FSDXL80-12-C-ND 1232150-ND 1208869-ND 1208872-ND 13132025-ND F84-20-TL-ND F84-25-TL-ND F84-32-TL-ND 3201916-ND 288-1073-ND 11183160-ND 875/14-ND 277-5689-ND F85-15-C-ND F85-18-C-ND FSD81-18-C-ND 1225110-ND 288-1391-ND 288-1392-ND 13162160-ND 1200281-ND 288-1122-ND 288-1123-ND FSDXL82-12-C-ND 1225125-ND FSD83-18-C-ND 178/18-ND 1232125-ND FTD80-13-TL-ND FSD84-18-C-ND 3200360-ND 2-1567115-6-ND FTD82-14-C-ND 288-1037-ND 288-1075-ND 11163250-ND 11183250-ND 479/16-ND 80/25VZ-ND F85-25-C-ND F85-32-C-ND 1218135-ND FSDXL83-12-C-ND 288-1038-ND 3201987-ND 3200357-ND 1220135-ND 1232170-ND 1225135-ND 1232135-ND FSDXL84-12-C-ND FTD83-14-C-ND 3201974-ND 3201945-ND F86-18-C-ND F86-20-C-ND 1225195-ND 1230195-ND 1232195-ND 3200153-ND 80/30VZ-ND 288-1076-ND 12321120-ND 2-1567115-4-ND 2-1567115-7-ND FSD85-22-L-ND 81/25VZ-ND 2-1567115-5-ND 11253250-ND 11161350-ND 11163350-ND 11162350-ND 11183350-ND 11182350-ND 11251350-ND 11253350-ND 11201500-ND 11202500-ND 3200386-ND 11203500-ND 123211500-ND 288-1136-ND 123811500-ND FTD84-16-C-ND C9043196-ND 11201700-ND 11203700-ND 11202700-ND 180/O-ND 480/20-ND 3201958-ND FSD86-16-L-ND 123211850-ND 3201961-ND 81/30VZ-ND F86-25-C-ND 124011850-ND FSD86-18-L-ND 11253950-ND 11252950-ND 112711200-ND 112731200-ND 112721200-ND F87-18-C-ND 11271700-ND 11273700-ND 11272700-ND FSD86-25-L-ND 113211500-ND 113231500-ND 113221500-ND F86-32-C-ND F87-22-C-ND 3200739-ND 12401120-ND 83/30VZ-ND 11251500-ND 11253500-ND 11252500-ND F87-25-C-ND 83/32VZ-ND 3201495-ND 83/34VZ-ND FSD87-20-L-ND 3201178-ND 83/38VZ-ND 3240678-ND FSD89-20-Q-ND 84/34VZ-ND F89-25-L-ND F87-32-C-ND F89-32-L-ND FSD87-25-Q-ND F90-25-L-ND F91-32-L-ND 9-51713-0-ND F90-30-L-ND 85/40VZ-ND F90-32-L-ND F92-32-L-ND F91-40-L-ND FSD89-27-Q-ND F92-38-L-ND 51713-9-ND F93-32-Q-ND 3201822-ND FSD90-25-Q-ND 51713-2-ND 9-51713-4-ND FSD91-27-Q-ND 3241239-ND FSD92-32-Q-ND 3241240-ND F93-40-Q-ND 3241241-ND 3241242-ND F94-40-Q-ND 9037310000-ND 9021120000-ND 9019210000-ND 9021930000-ND 9021940000-ND 9021970000-ND 9037660000-ND 9004730000-ND 9037530000-ND 9037490000-ND 9037510000-ND 9037520000-ND 9006750000-ND 9037670000-ND 9203620000-ND 9006590000-ND 9021150000-ND 0534200000-ND 9019240000-ND 0533500000-ND 9019220000-ND 9021130000-ND 9006630000-ND 0375200000-ND 9004590000-ND 9018550000-ND 9018560000-ND 565800000-ND 9019250000-ND 9021160000-ND 9019230000-ND 9021140000-ND 9037320000-ND 9037550000-ND 9037540000-ND 9037680000-ND 0565700000-ND 9004930000-ND 9019280000-ND 9021190000-ND 0317000000-ND 9026060000-ND 9018860000-ND 9037610000-ND 9019300000-ND 9021200000-ND 9037560000-ND 317200000-ND 9019260000-ND 9021170000-ND 9202870000-ND 9202880000-ND 9006670000-ND 9006710000-ND 9006790000-ND 9037590000-ND 9019310000-ND 9037360000-ND 317300000-ND 9037370000-ND 9019320000-ND 9019330000-ND 566000000-ND 9019270000-ND 9021180000-ND 0375300000-ND 9004160000-ND 444200000-ND 9004720000-ND 9037330000-ND 9019340000-ND 9028200000-ND 9004430000-ND 9018580000-ND 9004740000-ND 9026010000-ND 9021250000-ND 9021210000-ND 9021220000-ND 9019400000-ND 9019410000-ND 9026050000-ND 0409500000-ND 9019000000-ND 9004560000-ND 9019010000-ND 9025700000-ND 9037420000-ND 9028310000-ND 9018590000-ND 9036240000-ND 9036250000-ND 9004180000-ND 9028210000-ND 9037340000-ND 9006830000-ND 9004150000-ND 9004940000-ND 9037570000-ND 9028280000-ND 565600000-ND 9025790000-ND 9004780000-ND 9026070000-ND 9025960000-ND 9021040000-ND 9004310000-ND 9018520000-ND 9021050000-ND 9019060000-ND 9021060000-ND 9025740000-ND 9021020000-ND 9025750000-ND 9004440000-ND 9025870000-ND 9019020000-ND 9019030000-ND 0409600000-ND 9018510000-ND 9018570000-ND 9025860000-ND 9019050000-ND 9025910000-ND 9026080000-ND 9025970000-ND 9026090000-ND 9019430000-ND 0409700000-ND 9019070000-ND 9019080000-ND 9004330000-ND 9025950000-ND 9025930000-ND 9026100000-ND 9021030000-ND 9019100000-ND 0373100000-ND 9028300000-ND 9204090000-ND 9004280000-ND 9019040000-ND 9037260000-ND 9021960000-ND 9037470000-ND 9037200000-ND 9037380000-ND 9028270000-ND 9037210000-ND 9037390000-ND 9037230000-ND 9037410000-ND 9028580000-ND 9028290000-ND 9046230000-ND 9018910000-ND 9004050000-ND 0282600000-ND 0542500000-ND 0282700000-ND 0282800000-ND 0372600000-ND 0186500000-ND 9004070000-ND 0372700000-ND 9004060000-ND 9028220000-ND 9036260000-ND 9037350000-ND 9018880000-ND 9004190000-ND 368900000-ND 9202820000-ND 9036210000-ND 9025880000-ND 9004210000-ND 9019350000-ND 9028230000-ND 492500000-ND 124700000-ND 9004200000-ND 9021230000-ND 9004770000-ND 9021010000-ND 9025780000-ND 9025770000-ND 9019420000-ND 9018540000-ND 9004760000-ND 9025690000-ND 9004350000-ND 9025240000-ND 9025980000-ND 0124300000-ND 9021950000-ND 9018530000-ND 9019120000-ND 9025720000-ND 0635100000-ND 9019130000-ND 9025710000-ND 9004370000-ND 9004080000-ND 0186100000-ND 1333100000-ND 9021070000-ND 9004090000-ND 0373000000-ND 9004120000-ND 9019110000-ND 9019150000-ND 0244100000-ND 0191900000-ND 9005180000-ND 9028240000-ND 9028350000-ND 9037290000-ND 9019140000-ND 9028490000-ND 9036230000-ND 9028250000-ND 9028260000-ND 9037240000-ND 9037620000-ND 9202830000-ND 9037630000-ND 9037440000-ND 9018650000-ND 9037270000-ND 9037450000-ND 9037280000-ND 9004220000-ND 124400000-ND 9004230000-ND 9004420000-ND 9004750000-ND 9021240000-ND 9021080000-ND 9019180000-ND 9004410000-ND 9019170000-ND 9004100000-ND 9021110000-ND 9019190000-ND 9021100000-ND 9004920000-ND 9037300000-ND 9037480000-ND 9036220000-ND 9037220000-ND 9037460000-ND 9028360000-ND 9018890000-ND 9004240000-ND 9018870000-ND 124800000-ND 0282900000-ND 9021090000-ND 9004170000-ND 9004130000-ND 9037400000-ND 9037430000-ND 9037500000-ND 9037640000-ND 379300000-ND 9004110000-ND 9203630000-ND 1076990000-ND 9004250000-ND 9451000000-ND 9004260000-ND 9018690000-ND 9037250000-ND 9004900000-ND 9028520000-ND 9005910000-ND 9005850000-ND 9005810000-ND 9005870000-ND 9005820000-ND 9005830000-ND 9005890000-ND 9005880000-ND 9005840000-ND 9005860000-ND 9004390000-ND 9005900000-ND 3009215-ND 3200179-ND 3200852-ND 3200865-ND 3201291-ND FSF72-6-D-ND FSF72-8-D-ND FSF73-6-D-ND FSF73-8-D-ND FSF74-6-D-ND FSF74-8-D-ND FSF75-10-D-ND 298-10043-ND FSF75-8-D-ND FSF76-10-D-ND FSF76-12-D-ND FSF76-6-D-ND FSF76-8-D-ND FSF77-10-D-ND FSF77-12-D-ND 298-10044-ND FSF77-8-D-ND FSF78-10-D-ND FSF78-12-D-ND FSF78-18-D-ND FSF78-6-D-ND 298-10045-ND FSF79-8-D-ND FSF80-12-D-ND FSF80-18-D-ND 298-10046-ND FSF81-10-D-ND FSF81-12-C-ND FSF82-12-C-ND FSF82-18-C-ND FSF83-12-C-ND FSF83-18-C-ND FSF84-12-C-ND FSF84-18-C-ND FSF85-16-L-ND FSF85-18-L-ND FSF85-22-L-ND FSF86-16-L-ND FSF86-18-L-ND FSF86-25-L-ND FSF87-20-L-ND FSF87-25-Q-ND 9129-ND 9130-ND 9131-ND PA9132-ND PA9133-ND PA9135-ND PA9142-ND 9159-ND PA9219-ND PA9225-ND PA9226-ND PA9228-ND PA9241-ND PA9243-ND PA9265-ND PA9293-ND PA12430-ND PA12440-ND PA12470-ND PA12480-ND PA18610-ND 18650-ND 19190-ND 24410-ND 28260-ND PA28270-ND 28280-ND PA28290-ND PA31700-ND PA31710-ND PA31720-ND PA31730-ND PA36890-ND PA37260-ND PA37270-ND PA37300-ND PA37310-ND PA37520-ND PA37530-ND 37930-ND PA40950-ND PA40970-ND PA44420-ND 46290-ND 46300-ND 46310-ND PA49250-ND 53350-ND 53420-ND 54250-ND PA56560-ND PA56570-ND PA56580-ND 56590-ND PA56600-ND PA63510-ND PA69070-ND PA133310-ND PA900405-ND PA900406-ND PA900407-ND PA900408-ND PA900409-ND PA900410-ND PA900411-ND PA900412-ND PA900413-ND PA900415-ND PA900416-ND PA900417-ND PA900418-ND PA900419-ND PA900420-ND PA900421-ND PA900422-ND PA900427-ND PA900428-ND PA900429-ND PA900430-ND PA900431-ND PA900432-ND PA900433-ND PA900434-ND PA900435-ND PA900436-ND PA900437-ND PA900441-ND PA900442-ND PA900443-ND PA900444-ND PA900473-ND PA900474-ND PA900475-ND PA900476-ND PA900477-ND PA900478-ND 900581-ND 900582-ND 900583-ND 900584-ND 900585-ND 900586-ND 900587-ND 900588-ND 900589-ND 900590-ND 900591-ND PAL9107-ND PA9261-ND PA40960-ND 966066-9-ND 69/5VZ-ND 69/7VZ-ND 70/5VZ-ND 70/7VZ-ND 71/15VZ-ND 71/8VZ-ND 71S/8VZ-ND 72/15VZ-ND 72/20VZ-ND 72S/12VZ-ND 72S/15VZ-ND 72S/8VZ-ND 73/15VZ-ND 74/20VZ-ND 75/20VZ-ND 75/25VZ-ND 76/20VZ-ND 76/25VZ-ND 78/12VZ-ND 78/20VZ-ND 78/28VZ-ND 79/30VZ-ND 80/22VZ-ND 71/10VZ-ND 71/6VZ-ND 71S/10VZ-ND 71S/6VZ-ND 72/12VZ-ND 72/18VZ-ND 72/7VZ-ND 72S/10VZ-ND 72S/6VZ-ND 73/10VZ-ND 73/12VZ-ND 73/18VZ-ND 73/7VZ-ND 74/18VZ-ND 74/9VZ-ND 75/10VZ-ND 75/12VZ-ND 75/18VZ-ND 76/12VZ-ND 76/18VZ-ND 77/12VZ-ND 77/18VZ-ND 77/25VZ-ND 78/15VZ-ND 78/25VZ-ND 79/18VZ-ND 79/25VZ-ND 80/18VZ-ND 81/22VZ-ND 82/25VZ-ND 82/30VZ-ND 82/32VZ-ND 82/34VZ-ND 83/40VZ-ND 84/32VZ-ND 84/40VZ-ND 85/32VZ-ND 869/8-ND 870/10-ND 870/8-ND 871/10-ND 871/8-ND 872/12-ND 872/8-ND 874/12-ND 876/14-ND 877/14-ND 166/6-ND 166/8-ND 166/GR-ND 166/GRL-ND 167/6-ND 167/8-ND 167/H-ND 167/HL-ND 168/6-ND 168/8-ND 168/T-ND 169/8-ND 169/O-ND 169/OH-ND 170/6-ND 170/8-ND 170/W-ND 170/WH-ND 170/WK-ND 170/WL-ND 171/6-ND 171/8-ND 171/G-ND 171/GK-ND 172/18-ND 172/6-ND 172/8-ND 172/RH-ND 172/RL-ND 172/RO-ND 173/18-ND 173/8-ND 173/B-ND 173/BH-ND 173/BL-ND 174/GR-ND 174/GRH-ND 174/GRL-ND 175/18-ND 175/S-ND 176/12-ND 176/18-ND 176/E-ND 176/EL-ND 177/12-ND 177/18-ND 177/GR-ND 178/BR-ND 178/BRL-ND 179/B-ND 179/BL-ND 470/10-ND 470/12-ND 470/6-ND 470/8-ND 471/10-ND 471/12-ND 472/10-ND 472/12-ND 472/18-ND 472/8-ND 473/8-ND 474/18-ND 475/12-ND 475/18-ND 476/12-ND 476/18-ND 477/18-ND 478/16-ND 478/22-ND 479/18-ND 479/25-ND 480/25-ND A122898-ND FSD76-8-5K8-ND FSD77-8-5K2-ND 298-11529-2-ND 298-11529-1-ND
165514-1-ND WM18374-ND A121989-ND A108135-ND WM18377-ND WM18378-ND A99257-ND 165075AMP-ND A99256-ND A99255-ND WM18381-ND WM18380-ND 165168-ND 165172-ND 165049-ND A124400-ND WM7023TR-ND WM7023CT-ND WM18375-ND WM18379-ND WM18382-ND WM14266TR-ND WM14266CT-ND 3M157226-ND WM14267TR-ND WM14267CT-ND 298-11485-2-ND 298-11485-1-ND A124507-ND A109364TR-ND A109364CT-ND 165140-ND A112598-ND A114602-ND 131331-ND 131330-ND A112599-ND 165048-ND 160404-2-ND WM18376-ND 277-9653-ND 298-10587-ND 298-10588-ND 277-12084-ND 277-15421-ND WM7027TR-ND WM7027CT-ND 165171-ND 131444-ND 131445-ND 131332-ND 165142-ND WM19894TR-ND WM19894CT-ND 81P-47-P-A-ND 925667-1-ND PC-5.5-ND 0192110006-ND 130861-ND 0192120006-ND 1-1377174-2-ND 0192130036-ND WM7025TR-ND WM7025CT-ND MU14-47PK-A-ND 0192130003-ND 0192130035-ND 165170-ND 165166-ND 4-1377173-2-ND 4-1377173-5-ND 0192130005-ND 1-1377174-0-ND 165085-1-ND 4-1377173-7-ND 4-1377173-1-ND 0192120014-ND 1-1377174-6-ND P18-P47-M-ND P14-P47-M-ND 1-1377174-1-ND 1-1377174-5-ND 19213-0010-ND 1-1377174-3-ND 82P-47-P-A-ND 83P-55-P-A-ND 0192130034-ND 4-1377173-9-ND MVU14-47PK-A-ND MVU18-47PK-A-ND 696375-1-ND 0192130001-ND PV14-P47B-3K-ND 1-1377174-4-ND PV14-P47-M-ND PV18-P47-MY-ND 1377174-9-ND 696116-1-ND 165046-1-ND P10-P55-D-ND 82P-47-NB-A-ND 83P-55-NB-A-ND 696153-2-ND A112603-ND MNG14-47PK-A-ND 165172-2-ND MVU10-55PK-A-ND PV10-P55-DY-ND 696394-2-ND 696273-2-ND P18-P47-C-ND P14-P47-C-ND 555201-000-ND 1958191-1-ND 1-1377174-7-ND 1958192-1-ND 1-1377174-8-ND A113465-ND 696736-1-ND MNG10-55PK-A-ND 1958193-1-ND 8-165172-1-ND 165133-ND 4-1377173-3-ND 2-696200-2-ND P10-P55-L-ND 696274-2-ND 3241216-ND 8-165168-1-ND PV14-P47-E-ND PV18-P47-E-ND PV10-P55-LY-ND 3241217-ND PV10-P55-E-ND 8-165049-2-ND 4-1377173-8-ND 5-1377173-0-ND 9200460000-ND 9200470000-ND 9200480000-ND MU10-55PX-A-BOTTLE-ND MU14-47PX-A-BOTTLE-ND MU18-47PX-A-BOTTLE-ND 710/60-ND 710/100-ND 711/40-ND MVU10-55PX-A-BOTTLE-ND 711/60-ND 710/07-ND 711/100-ND 710/25-ND MNG10-55PX-A-BOTTLE-ND 711/07-ND MVU14-47PX-A-BOTTLE-ND MVU18-47PX-A-BOTTLE-ND 711/10-ND 711/15-ND 711/25-ND MNG14-47PX-A-BOTTLE-ND MNG18-47PX-A-BOTTLE-ND PV10-P55-L-ND PV10-P55-D-ND PV18-P47-M-ND 736013-ND A114432-ND 736014-ND 710/10-ND PM1-P10-C-ND PM6-P10-L-ND PMV1-P10-CY-ND PMV1-P12B-3K-ND PMV2-P10-C-ND PMV2-P12B-3K-ND PMV6-P10-L-ND A119649-ND 165514-1 0192110003 131443 342126-1 0192120003 0192120005 165167 165075 165143 165085 0192130011 0192130009 165168 165172 165049 180599 0192110002 0192110002 0192110005 19212-0001 19213-0007 0192110004 0192110004 81P-47-NB-A 0192130012 0192130012 PV18-P47B-3K PV18-P47B-3K 342166-1 925667-2 925667-2 165140 165045 9-160402-2 131331 131330 165046 165048 160404-2 0192110001 3240068 PV14-P47-C PV18-P47-CY 3240064 3240066 0192120004 0192120004 165171 131444 131445 131332 165142 0192130008 0192130008 81P-47-P-A 925667-1 PC-5.5 0192110006 130861 0192120006 1-1377174-2 0192130036 0192120002 0192120002 MU14-47PK-A 0192130003 0192130035 165170 165166 4-1377173-2 4-1377173-5 0192130005 1-1377174-0 165085-1 4-1377173-7 4-1377173-1 0192120014 1-1377174-6 P18-P47-M P14-P47-M 1-1377174-1 1-1377174-5 19213-0010 1-1377174-3 82P-47-P-A 83P-55-P-A 0192130034 4-1377173-9 MVU14-47PK-A MVU18-47PK-A 696375-1 0192130001 PV14-P47B-3K 1-1377174-4 PV14-P47-M PV18-P47-MY 1377174-9 696116-1 165046-1 P10-P55-D 82P-47-NB-A 83P-55-NB-A 696153-2 165446 MNG14-47PK-A 165172-2 MVU10-55PK-A PV10-P55-DY 696394-2 696273-2 P18-P47-C P14-P47-C 555201-000 1958191-1 1-1377174-7 1958192-1 1-1377174-8 342196-1 696736-1 MNG10-55PK-A 1958193-1 8-165172-1 165133 4-1377173-3 2-696200-2 P10-P55-L 696274-2 3241216 8-165168-1 PV14-P47-E PV18-P47-E PV10-P55-LY 3241217 PV10-P55-E 8-165049-2 4-1377173-8 5-1377173-0 9200460000 9200470000 9200480000 MU10-55PX-A-BOTTLE MU14-47PX-A-BOTTLE MU18-47PX-A-BOTTLE 710/60 710/100 711/40 MVU10-55PX-A-BOTTLE 711/60 710/07 711/100 710/25 MNG10-55PX-A-BOTTLE 711/07 MVU14-47PX-A-BOTTLE MVU18-47PX-A-BOTTLE 711/10 711/15 711/25 MNG14-47PX-A-BOTTLE MNG18-47PX-A-BOTTLE PV10-P55-L PV10-P55-D PV18-P47-M 736013 790368-1 736014 710/10 PM1-P10-C PM6-P10-L PMV1-P10-CY PMV1-P12B-3K PMV2-P10-C PMV2-P12B-3K PMV6-P10-L 736066
[/details]
