Below resistors appear identical according to our technical parameters, except for their physical size. Why the size difference?
Click Below:
MFR-25FBF52-200R
MFR25SFBF52-200R
Although identical wattage, the larger package is for higher voltage handling. Maximum working voltage is the maximum amount of voltage the resistor can withstand constantly without arcing. Maximum working voltage is often expressed as “Vrms.” Arcing occurs when the maximum voltage of the part is exceeded, and the voltage “arcs” across the body of the component from lead to lead, bypassing the component. High voltage parts are typically made longer, or have higher rated insulation.
See Also:
Resistor Temperature and Power Rating Relationship
Through hole resistor composition differences
Physical size of a through hole resistor
Physical Size vs Wattage in Chip Resistors
Surface Mount Resistor Part Markings
Summary
RS5X-KIT-ND
RS1X-KIT-ND
RS2X-KIT-ND
RS3X-KIT-ND
RS4X-KIT-ND
RS5X
RS1X
RS2X
RS3X
RS4X
30.1XBK-ND
10.0XBK-ND
37.4XBK-ND
15.0XBK-ND
35.7KXBK-ND
1.40KXBK-ND
66.5KXBK-ND
13.3KXBK-ND
32.4KXBK-ND
61.9KXBK-ND
33.2KXBK-ND
68.1KXBK-ND
31.6KXBK-ND
11.8KXBK-ND
261XBK-ND
909KXBK-ND
19.1KXBK-ND
536XBK-ND
604KXBK-ND
9.09KXBK-ND
69.8KXBK-ND
442XBK-ND
7.50KXBK-ND
28.0KXBK-ND
1.65KXBK-ND
52.3XBK-ND
715KXBK-ND
953XBK-ND
453XBK-ND
182XBK-ND
158XBK-ND
52.3KXBK-ND
200XBK-ND
41.2KXBK-ND
13.0KXBK-ND
806XBK-ND
13.7KXBK-ND
255XBK-ND
71.5XBK-ND
475XBK-ND
118XBK-ND
68.1XBK-ND
4.02KXBK-ND
412XBK-ND
590KXBK-ND
374XBK-ND
604XBK-ND
365XBK-ND
20.5KXBK-ND
590XBK-ND
4.32KXBK-ND
10.5KXBK-ND
15.8KXBK-ND
549XBK-ND
1.69KXBK-ND
2.00KXBK-ND
28.7KXBK-ND
121KXBK-ND
392KXBK-ND
110KXBK-ND
1.05KXBK-ND
2.87KXBK-ND
249KXBK-ND
511KXBK-ND
221KXBK-ND
191KXBK-ND
130XBK-ND
1.74KXBK-ND
2.15KXBK-ND
732XBK-ND
340KXBK-ND
16.2KXBK-ND
1.00KXBK-ND
34.0XBK-ND
348XBK-ND
71.5KXBK-ND
127XBK-ND
1.47KXBK-ND
787XBK-ND
750XBK-ND
5.62KXBK-ND
6.19KXBK-ND
1.87KXBK-ND
60.4XBK-ND
237XBK-ND
17.4XBK-ND
30.1KXBK-ND
147KXBK-ND
215KXBK-ND
301KXBK-ND
124XBK-ND
4.12KXBK-ND
93.1KXBK-ND
26.1KXBK-ND
84.5KXBK-ND
40.2KXBK-ND
16.5KXBK-ND
649XBK-ND
140XBK-ND
11.5KXBK-ND
2.61KXBK-ND
4.22KXBK-ND
24.3KXBK-ND
332XBK-ND
43.2KXBK-ND
475KXBK-ND
7.15KXBK-ND
3.83KXBK-ND
5.49KXBK-ND
1.43KXBK-ND
33.2XBK-ND
392XBK-ND
619XBK-ND
107KXBK-ND
47.5XBK-ND
523XBK-ND
8.66KXBK-ND
6.81KXBK-ND
63.4KXBK-ND
887XBK-ND
14.7KXBK-ND
3.01KXBK-ND
3.92KXBK-ND
18.2KXBK-ND
140KXBK-ND
200KXBK-ND
562XBK-ND
5.23KXBK-ND
1.13KXBK-ND
24.9KXBK-ND
45.3KXBK-ND
56.2XBK-ND
12.1KXBK-ND
316KXBK-ND
1.02KXBK-ND
681KXBK-ND
205XBK-ND
150KXBK-ND
110XBK-ND
11.3KXBK-ND
422KXBK-ND
8.87KXBK-ND
113KXBK-ND
4.42KXBK-ND
806KXBK-ND
42.2KXBK-ND
25.5XBK-ND
3.48KXBK-ND
243XBK-ND
2.37KXBK-ND
6.98KXBK-ND
23.2KXBK-ND
31.6XBK-ND
143XBK-ND
2.21KXBK-ND
34.8XBK-ND
4.53KXBK-ND
7.68KXBK-ND
536KXBK-ND
133KXBK-ND
909XBK-ND
27.4KXBK-ND
12.1XBK-ND
2.67KXBK-ND
165XBK-ND
2.05KXBK-ND
301XBK-ND
432XBK-ND
18.7XBK-ND
787KXBK-ND
49.9XBK-ND
6.65KXBK-ND
165KXBK-ND
931XBK-ND
27.4XBK-ND
332KXBK-ND
4.64KXBK-ND
1.82KXBK-ND
422XBK-ND
143KXBK-ND
32.4XBK-ND
1.78KXBK-ND
196KXBK-ND
221XBK-ND
MFR-25FBF52-2M-ND
MFR-25FBF52-3M3-ND
MFR-25FBF52-4M7-ND
MFR-25FBF52-2M2-ND
294KXBK-ND
107XBK-ND
365KXBK-ND
412KXBK-ND
357KXBK-ND
44.2KXBK-ND
845KXBK-ND
20.0KXBK-ND
78.7XBK-ND
750KXBK-ND
280XBK-ND
46.4XBK-ND
61.9XBK-ND
105XBK-ND
453KXBK-ND
162KXBK-ND
2.55KXBK-ND
10.7KXBK-ND
178KXBK-ND
866KXBK-ND
976KXBK-ND
768XBK-ND
1.58KXBK-ND
MFR-25FBF52-2K4-ND
5.36KXBK-ND
MFR-25FBF52-16K-ND
9.53KXBK-ND
294XBK-ND
715XBK-ND
75.0XBK-ND
158KXBK-ND
MFR-25FBF52-3K6-ND
11.0KXBK-ND
80.6KXBK-ND
9.31KXBK-ND
MFR-25FBF52-300R-ND
174KXBK-ND
21.0KXBK-ND
261KXBK-ND
MFR-25FBF52-82R-ND
6.49KXBK-ND
10.2KXBK-ND
MFR-25FBF52-39K-ND
226KXBK-ND
MFR-25FBF52-180K-ND
80.6XBK-ND
523KXBK-ND
649KXBK-ND
1.33KXBK-ND
14.3XBK-ND
95.3XBK-ND
118KXBK-ND
1.15KXBK-ND
182KXBK-ND
1.07KXBK-ND
237KXBK-ND
249XBK-ND
MFR-25FBF52-270K-ND
34.0KXBK-ND
60.4KXBK-ND
18.2XBK-ND
MFR-25FBF52-43K-ND
MFR-25FBF52-22R-ND
2.49KXBK-ND
MFR-25FBF52-9K1-ND
66.5XBK-ND
45.3XBK-ND
976XBK-ND
37.4KXBK-ND
38.3KXBK-ND
MFR-25FBF52-8K2-ND
47.5KXBK-ND
64.9KXBK-ND
MFR-25FBF52-680K-ND
287XBK-ND
MFR-25FBF52-390R-ND
825XBK-ND
4.99KXBK-ND
1.54KXBK-ND
51.1XBK-ND
MFR-25FBF52-91K-ND
9.76KXBK-ND
402KXBK-ND
309KXBK-ND
MFR-25FBF52-56K-ND
267XBK-ND
59.0XBK-ND
MFR-25FBF52-27K-ND
16.2XBK-ND
42.2XBK-ND
147XBK-ND
196XBK-ND
93.1XBK-ND
8.45KXBK-ND
154XBK-ND
464KXBK-ND
46.4KXBK-ND
75.0KXBK-ND
73.2KXBK-ND
MFR-25FBF52-3K9-ND
4.87KXBK-ND
340XBK-ND
34.8KXBK-ND
17.8XBK-ND
40.2XBK-ND
51.1KXBK-ND
97.6XBK-ND
383XBK-ND
MFR-25FBF52-470K-ND
499XBK-ND
1.37KXBK-ND
48.7XBK-ND
1.10KXBK-ND
MFR-25FBF52-30K-ND
MFR-25FBF52-330K-ND
11.0XBK-ND
MFR-25FBF52-18K-ND
866XBK-ND
29.4KXBK-ND
102KXBK-ND
115XBK-ND
324XBK-ND
86.6XBK-ND
12.4KXBK-ND
MFR-25FBF52-270R-ND
3.65KXBK-ND
21.0XBK-ND
14.0XBK-ND
2.10KXBK-ND
113XBK-ND
MFR-25FBF52-820R-ND
3.32KXBK-ND
90.9KXBK-ND
215XBK-ND
54.9XBK-ND
MFR-25FBF52-68K-ND
MFR-25FBF52-560R-ND
69.8XBK-ND
1.30KXBK-ND
115KXBK-ND
5.76KXBK-ND
88.7KXBK-ND
1.24KXBK-ND
210KXBK-ND
12.7XBK-ND
86.6KXBK-ND
210XBK-ND
39.2KXBK-ND
309XBK-ND
3.57KXBK-ND
205KXBK-ND
1.91KXBK-ND
16.9KXBK-ND
8.25KXBK-ND
2.80KXBK-ND
30.9KXBK-ND
619KXBK-ND
90.9XBK-ND
78.7KXBK-ND
280KXBK-ND
255KXBK-ND
24.9XBK-ND
287KXBK-ND
63.4XBK-ND
226XBK-ND
6.34KXBK-ND
562KXBK-ND
MFR-25FBF52-1K2-ND
374KXBK-ND
232XBK-ND
1.27KXBK-ND
698KXBK-ND
442KXBK-ND
MFR-25FBF52-33K-ND
549KXBK-ND
4.75KXBK-ND
357XBK-ND
383KXBK-ND
MFR-25FBF52-12K-ND
MFR-25FBF52-180R-ND
169XBK-ND
MFR-25FBF52-220K-ND
16.9XBK-ND
25.5KXBK-ND
3.16KXBK-ND
MFR-25FBF52-47R-ND
825KXBK-ND
324KXBK-ND
76.8KXBK-ND
10.2XBK-ND
MFR-25FBF52-5K1-ND
402XBK-ND
8.06KXBK-ND
1.62KXBK-ND
3.09KXBK-ND
22.1XBK-ND
53.6KXBK-ND
3.24KXBK-ND
665KXBK-ND
MFR-25FBF52-2K7-ND
137KXBK-ND
178XBK-ND
845XBK-ND
7.32KXBK-ND
2.32KXBK-ND
6.04KXBK-ND
102XBK-ND
1.18KXBK-ND
887KXBK-ND
MFR-25FBF52-510R-ND
487XBK-ND
3.74KXBK-ND
16.5XBK-ND
20.0XBK-ND
MFR-25FBF52-5K6-ND
49.9KXBK-ND
267KXBK-ND
43.2XBK-ND
15.0KXBK-ND
36.5KXBK-ND
59.0KXBK-ND
665XBK-ND
MFR-25FBF52-47K-ND
187XBK-ND
84.5XBK-ND
7.87KXBK-ND
12.7KXBK-ND
137XBK-ND
24.3XBK-ND
105KXBK-ND
5.90KXBK-ND
21.5KXBK-ND
634XBK-ND
1.96KXBK-ND
576XBK-ND
MFR-25FBF52-6K8-ND
82.5XBK-ND
511XBK-ND
23.7KXBK-ND
64.9XBK-ND
133XBK-ND
576KXBK-ND
316XBK-ND
698XBK-ND
127KXBK-ND
13.0XBK-ND
124KXBK-ND
130KXBK-ND
191XBK-ND
464XBK-ND
36.5XBK-ND
10.7XBK-ND
11.8XBK-ND
634KXBK-ND
20.5XBK-ND
931KXBK-ND
76.8XBK-ND
487KXBK-ND
88.7XBK-ND
29.4XBK-ND
768KXBK-ND
38.3XBK-ND
15.8XBK-ND
19.6XBK-ND
28.7XBK-ND
26.1XBK-ND
44.2XBK-ND
11.5XBK-ND
23.7XBK-ND
26.7XBK-ND
732KXBK-ND
41.2XBK-ND
57.6XBK-ND
19.1XBK-ND
13.3XBK-ND
12.4XBK-ND
30.9XBK-ND
432KXBK-ND
15.4XBK-ND
10.5XBK-ND
23.2XBK-ND
35.7XBK-ND
11.3XBK-ND
13.7XBK-ND
73.2XBK-ND
14.7XBK-ND
MFR-25FBF52-560K-ND
MFR-25FBF52-360K-ND
MFR-25FBF52-680R-ND
2.43KXBK-ND
14.0KXBK-ND
39.2XBK-ND
22.6XBK-ND
28.0XBK-ND
100XBK-ND
121XBK-ND
150XBK-ND
162XBK-ND
174XBK-ND
274XBK-ND
681XBK-ND
1.21KXBK-ND
1.50KXBK-ND
2.26KXBK-ND
2.74KXBK-ND
2.94KXBK-ND
3.40KXBK-ND
5.11KXBK-ND
10.0KXBK-ND
14.3KXBK-ND
15.4KXBK-ND
17.4KXBK-ND
through hole
through-hole
MFR-25FBF52-30R1
MFR-25FBF52-10R
MFR-25FBF52-37R4
MFR-25FBF52-15R
MFR-25FBF52-35K7
MFR-25FBF52-1K4
MFR-25FBF52-66K5
MFR-25FBF52-13K3
MFR-25FBF52-32K4
MFR-25FBF52-61K9
MFR-25FBF52-33K2
MFR-25FBF52-68K1
MFR-25FBF52-31K6
MFR-25FBF52-11K8
MFR-25FBF52-261R
MFR-25FBF52-909K
MFR-25FBF52-19K1
MFR-25FBF52-536R
MFR-25FBF52-604K
MFR-25FBF52-9K09
MFR-25FBF52-69K8
MFR-25FBF52-442R
MFR-25FBF52-7K5
MFR-25FBF52-28K
MFR-25FBF52-1K65
MFR-25FBF52-52R3
MFR-25FBF52-715K
MFR-25FBF52-953R
MFR-25FBF52-453R
MFR-25FBF52-182R
MFR-25FBF52-158R
MFR-25FBF52-52K3
MFR-25FBF52-200R
MFR-25FBF52-41K2
MFR-25FBF52-13K
MFR-25FBF52-806R
MFR-25FBF52-13K7
MFR-25FBF52-255R
MFR-25FBF52-71R5
MFR-25FBF52-475R
MFR-25FBF52-118R
MFR-25FBF52-68R1
MFR-25FBF52-4K02
MFR-25FBF52-412R
MFR-25FBF52-590K
MFR-25FBF52-374R
MFR-25FBF52-604R
MFR-25FBF52-365R
MFR-25FBF52-20K5
MFR-25FBF52-590R
MFR-25FBF52-4K32
MFR-25FBF52-10K5
MFR-25FBF52-15K8
MFR-25FBF52-549R
MFR-25FBF52-1K69
MFR-25FBF52-2K
MFR-25FBF52-28K7
MFR-25FBF52-121K
MFR-25FBF52-392K
MFR-25FBF52-110K
MFR-25FBF52-1K05
MFR-25FBF52-2K87
MFR-25FBF52-249K
MFR-25FBF52-511K
MFR-25FBF52-221K
MFR-25FBF52-191K
MFR-25FBF52-130R
MFR-25FBF52-1K74
MFR-25FBF52-2K15
MFR-25FBF52-732R
MFR-25FBF52-340K
MFR-25FBF52-16K2
MFR-25FBF52-1K
MFR-25FBF52-34R
MFR-25FBF52-348R
MFR-25FBF52-71K5
MFR-25FBF52-127R
MFR-25FBF52-1K47
MFR-25FBF52-787R
MFR-25FBF52-750R
MFR-25FBF52-5K62
MFR-25FBF52-6K19
MFR-25FBF52-1K87
MFR-25FBF52-60R4
MFR-25FBF52-237R
MFR-25FBF52-17R4
MFR-25FBF52-30K1
MFR-25FBF52-147K
MFR-25FBF52-215K
MFR-25FBF52-301K
MFR-25FBF52-124R
MFR-25FBF52-4K12
MFR-25FBF52-93K1
MFR-25FBF52-26K1
MFR-25FBF52-84K5
MFR-25FBF52-40K2
MFR-25FBF52-16K5
MFR-25FBF52-649R
MFR-25FBF52-140R
MFR-25FBF52-11K5
MFR-25FBF52-2K61
MFR-25FBF52-4K22
MFR-25FBF52-24K3
MFR-25FBF52-332R
MFR-25FBF52-43K2
MFR-25FBF52-475K
MFR-25FBF52-7K15
MFR-25FBF52-3K83
MFR-25FBF52-5K49
MFR-25FBF52-1K43
MFR-25FBF52-33R2
MFR-25FBF52-392R
MFR-25FBF52-619R
MFR-25FBF52-107K
MFR-25FBF52-47R5
MFR-25FBF52-523R
MFR-25FBF52-8K66
MFR-25FBF52-6K81
MFR-25FBF52-63K4
MFR-25FBF52-887R
MFR-25FBF52-14K7
MFR-25FBF52-3K01
MFR-25FBF52-3K92
MFR-25FBF52-18K2
MFR-25FBF52-140K
MFR-25FBF52-200K
MFR-25FBF52-562R
MFR-25FBF52-5K23
MFR-25FBF52-1K13
MFR-25FBF52-24K9
MFR-25FBF52-45K3
MFR-25FBF52-56R2
MFR-25FBF52-12K1
MFR-25FBF52-316K
MFR-25FBF52-1K02
MFR-25FBF52-681K
MFR-25FBF52-205R
MFR-25FBF52-150K
MFR-25FBF52-110R
MFR-25FBF52-11K3
MFR-25FBF52-422K
MFR-25FBF52-8K87
MFR-25FBF52-113K
MFR-25FBF52-4K42
MFR-25FBF52-806K
MFR-25FBF52-42K2
MFR-25FBF52-25R5
MFR-25FBF52-3K48
MFR-25FBF52-243R
MFR-25FBF52-2K37
MFR-25FBF52-6K98
MFR-25FBF52-23K2
MFR-25FBF52-31R6
MFR-25FBF52-143R
MFR-25FBF52-2K21
MFR-25FBF52-34R8
MFR-25FBF52-4K53
MFR-25FBF52-7K68
MFR-25FBF52-536K
MFR-25FBF52-133K
MFR-25FBF52-909R
MFR-25FBF52-27K4
MFR-25FBF52-12R1
MFR-25FBF52-2K67
MFR-25FBF52-165R
MFR-25FBF52-2K05
MFR-25FBF52-301R
MFR-25FBF52-432R
MFR-25FBF52-18R7
MFR-25FBF52-787K
MFR-25FBF52-49R9
MFR-25FBF52-6K65
MFR-25FBF52-165K
MFR-25FBF52-931R
MFR-25FBF52-27R4
MFR-25FBF52-332K
MFR-25FBF52-4K64
MFR-25FBF52-1K82
MFR-25FBF52-422R
MFR-25FBF52-143K
MFR-25FBF52-32R4
MFR-25FBF52-1K78
MFR-25FBF52-196K
MFR-25FBF52-221R
MFR-25FBF52-2M
MFR-25FBF52-3M3
MFR-25FBF52-4M7
MFR-25FBF52-2M2
MFR-25FBF52-294K
MFR-25FBF52-107R
MFR-25FBF52-365K
MFR-25FBF52-412K
MFR-25FBF52-357K
MFR-25FBF52-44K2
MFR-25FBF52-845K
MFR-25FBF52-20K
MFR-25FBF52-78R7
MFR-25FBF52-750K
MFR-25FBF52-280R
MFR-25FBF52-46R4
MFR-25FBF52-61R9
MFR-25FBF52-105R
MFR-25FBF52-453K
MFR-25FBF52-162K
MFR-25FBF52-2K55
MFR-25FBF52-10K7
MFR-25FBF52-178K
MFR-25FBF52-866K
MFR-25FBF52-976K
MFR-25FBF52-768R
MFR-25FBF52-1K58
MFR-25FBF52-2K4
MFR-25FBF52-5K36
MFR-25FBF52-16K
MFR-25FBF52-9K53
MFR-25FBF52-294R
MFR-25FBF52-715R
MFR-25FBF52-75R
MFR-25FBF52-158K
MFR-25FBF52-3K6
MFR-25FBF52-11K
MFR-25FBF52-80K6
MFR-25FBF52-9K31
MFR-25FBF52-300R
MFR-25FBF52-174K
MFR-25FBF52-21K
MFR-25FBF52-261K
MFR-25FBF52-82R
MFR-25FBF52-6K49
MFR-25FBF52-10K2
MFR-25FBF52-39K
MFR-25FBF52-226K
MFR-25FBF52-180K
MFR-25FBF52-80R6
MFR-25FBF52-523K
MFR-25FBF52-649K
MFR-25FBF52-1K33
MFR-25FBF52-14R3
MFR-25FBF52-95R3
MFR-25FBF52-118K
MFR-25FBF52-1K15
MFR-25FBF52-182K
MFR-25FBF52-1K07
MFR-25FBF52-237K
MFR-25FBF52-249R
MFR-25FBF52-270K
MFR-25FBF52-34K
MFR-25FBF52-60K4
MFR-25FBF52-18R2
MFR-25FBF52-43K
MFR-25FBF52-22R
MFR-25FBF52-2K49
MFR-25FBF52-9K1
MFR-25FBF52-66R5
MFR-25FBF52-45R3
MFR-25FBF52-976R
MFR-25FBF52-37K4
MFR-25FBF52-38K3
MFR-25FBF52-8K2
MFR-25FBF52-47K5
MFR-25FBF52-64K9
MFR-25FBF52-680K
MFR-25FBF52-287R
MFR-25FBF52-390R
MFR-25FBF52-825R
MFR-25FBF52-4K99
MFR-25FBF52-1K54
MFR-25FBF52-51R1
MFR-25FBF52-91K
MFR-25FBF52-9K76
MFR-25FBF52-402K
MFR-25FBF52-309K
MFR-25FBF52-56K
MFR-25FBF52-267R
MFR-25FBF52-59R
MFR-25FBF52-27K
MFR-25FBF52-16R2
MFR-25FBF52-42R2
MFR-25FBF52-147R
MFR-25FBF52-196R
MFR-25FBF52-93R1
MFR-25FBF52-8K45
MFR-25FBF52-154R
MFR-25FBF52-464K
MFR-25FBF52-46K4
MFR-25FBF52-75K
MFR-25FBF52-73K2
MFR-25FBF52-3K9
MFR-25FBF52-4K87
MFR-25FBF52-340R
MFR-25FBF52-34K8
MFR-25FBF52-17R8
MFR-25FBF52-40R2
MFR-25FBF52-51K1
MFR-25FBF52-97R6
MFR-25FBF52-383R
MFR-25FBF52-470K
MFR-25FBF52-499R
MFR-25FBF52-1K37
MFR-25FBF52-48R7
MFR-25FBF52-1K1
MFR-25FBF52-30K
MFR-25FBF52-330K
MFR-25FBF52-11R
MFR-25FBF52-18K
MFR-25FBF52-866R
MFR-25FBF52-29K4
MFR-25FBF52-102K
MFR-25FBF52-115R
MFR-25FBF52-324R
MFR-25FBF52-86R6
MFR-25FBF52-12K4
MFR-25FBF52-270R
MFR-25FBF52-3K65
MFR-25FBF52-21R
MFR-25FBF52-14R
MFR-25FBF52-2K1
MFR-25FBF52-113R
MFR-25FBF52-820R
MFR-25FBF52-3K32
MFR-25FBF52-90K9
MFR-25FBF52-215R
MFR-25FBF52-54R9
MFR-25FBF52-68K
MFR-25FBF52-560R
MFR-25FBF52-69R8
MFR-25FBF52-1K3
MFR-25FBF52-115K
MFR-25FBF52-5K76
MFR-25FBF52-88K7
MFR-25FBF52-1K24
MFR-25FBF52-210K
MFR-25FBF52-12R7
MFR-25FBF52-86K6
MFR-25FBF52-210R
MFR-25FBF52-39K2
MFR-25FBF52-309R
MFR-25FBF52-3K57
MFR-25FBF52-205K
MFR-25FBF52-1K91
MFR-25FBF52-16K9
MFR-25FBF52-8K25
MFR-25FBF52-2K8
MFR-25FBF52-30K9
MFR-25FBF52-619K
MFR-25FBF52-90R9
MFR-25FBF52-78K7
MFR-25FBF52-280K
MFR-25FBF52-255K
MFR-25FBF52-24R9
MFR-25FBF52-287K
MFR-25FBF52-63R4
MFR-25FBF52-226R
MFR-25FBF52-6K34
MFR-25FBF52-562K
MFR-25FBF52-1K2
MFR-25FBF52-374K
MFR-25FBF52-232R
MFR-25FBF52-1K27
MFR-25FBF52-698K
MFR-25FBF52-442K
MFR-25FBF52-33K
MFR-25FBF52-549K
MFR-25FBF52-4K75
MFR-25FBF52-357R
MFR-25FBF52-383K
MFR-25FBF52-12K
MFR-25FBF52-180R
MFR-25FBF52-169R
MFR-25FBF52-220K
MFR-25FBF52-16R9
MFR-25FBF52-25K5
MFR-25FBF52-3K16
MFR-25FBF52-47R
MFR-25FBF52-825K
MFR-25FBF52-324K
MFR-25FBF52-76K8
MFR-25FBF52-10R2
MFR-25FBF52-5K1
MFR-25FBF52-402R
MFR-25FBF52-8K06
MFR-25FBF52-1K62
MFR-25FBF52-3K09
MFR-25FBF52-22R1
MFR-25FBF52-53K6
MFR-25FBF52-3K24
MFR-25FBF52-665K
MFR-25FBF52-2K7
MFR-25FBF52-137K
MFR-25FBF52-178R
MFR-25FBF52-845R
MFR-25FBF52-7K32
MFR-25FBF52-2K32
MFR-25FBF52-6K04
MFR-25FBF52-102R
MFR-25FBF52-1K18
MFR-25FBF52-887K
MFR-25FBF52-510R
MFR-25FBF52-487R
MFR-25FBF52-3K74
MFR-25FBF52-16R5
MFR-25FBF52-20R
MFR-25FBF52-5K6
MFR-25FBF52-49K9
MFR-25FBF52-267K
MFR-25FBF52-43R2
MFR-25FBF52-15K
MFR-25FBF52-36K5
MFR-25FBF52-59K
MFR-25FBF52-665R
MFR-25FBF52-47K
MFR-25FBF52-187R
MFR-25FBF52-84R5
MFR-25FBF52-7K87
MFR-25FBF52-12K7
MFR-25FBF52-137R
MFR-25FBF52-24R3
MFR-25FBF52-105K
MFR-25FBF52-5K9
MFR-25FBF52-21K5
MFR-25FBF52-634R
MFR-25FBF52-1K96
MFR-25FBF52-576R
MFR-25FBF52-6K8
MFR-25FBF52-82R5
MFR-25FBF52-511R
MFR-25FBF52-23K7
MFR-25FBF52-64R9
MFR-25FBF52-133R
MFR-25FBF52-576K
MFR-25FBF52-316R
MFR-25FBF52-698R
MFR-25FBF52-127K
MFR-25FBF52-13R
MFR-25FBF52-124K
MFR-25FBF52-130K
MFR-25FBF52-191R
MFR-25FBF52-464R
MFR-25FBF52-36R5
MFR-25FBF52-10R7
MFR-25FBF52-11R8
MFR-25FBF52-634K
MFR-25FBF52-20R5
MFR-25FBF52-931K
MFR-25FBF52-76R8
MFR-25FBF52-487K
MFR-25FBF52-88R7
MFR-25FBF52-29R4
MFR-25FBF52-768K
MFR-25FBF52-38R3
MFR-25FBF52-15R8
MFR-25FBF52-19R6
MFR-25FBF52-28R7
MFR-25FBF52-26R1
MFR-25FBF52-44R2
MFR-25FBF52-11R5
MFR-25FBF52-23R7
MFR-25FBF-52-26R7
MFR-25FBF52-732K
MFR-25FBF52-41R2
MFR-25FBF52-57R6
MFR-25FBF52-19R1
MFR-25FBF52-13R3
MFR-25FBF52-12R4
MFR-25FBF52-30R9
MFR-25FBF52-432K
MFR-25FBF52-15R4
MFR-25FBF52-10R5
MFR-25FBF52-23R2
MFR-25FBF52-35R7
MFR-25FBF52-11R3
MFR-25FBF52-13R7
MFR-25FBF52-73R2
MFR-25FBF52-14R7
MFR-25FBF52-560K
MFR-25FBF52-360K
MFR-25FBF52-680R
MFR-25FBF52-2K43
MFR-25FBF52-14K
MFR-25FBF52-39R2
MFR-25FBF52-22R6
MFR-25FBF52-28R
MFR-25FBF52-100R
MFR-25FBF52-121R
MFR-25FBF52-150R
MFR-25FBF52-162R
MFR-25FBF52-174R
MFR-25FBF52-274R
MFR-25FBF52-681R
MFR-25FBF52-1K21
MFR-25FBF52-1K5
MFR-25FBF52-2K26
MFR-25FBF52-2K74
MFR-25FBF52-2K94
MFR-25FBF52-3K4
MFR-25FBF52-5K11
MFR-25FBF52-10K
MFR-25FBF52-14K3
MFR-25FBF52-15K4
MFR-25FBF52-17K4
