Zephyr 4.1 Graphics Example
I’ve been following Shawn Hymel’s excellent series on Getting Started with Zephyr.
I tried out the 10_demo_display using Zephyr 3.7 and Zephyr 4.0 and it works properly with both of those. If I try running it under Zephyr 4.1 then I get a mangled display.
I made the following changes:
Changed apps/10_demo_display/boards/esp32s3_devkitc.overlay
    mipi-mode = <MIPI_DBI_MODE_SPI_4WIRE>;
to
    mipi-mode = "MIPI_DBI_MODE_SPI_4WIRE";
Changed the definition of rect_points in src/main.c from lv_point_t to lv_point_precise_t (this eliminated a compiler warning).
Removed CONFIG_LV_MEM_CUSTOM=y from prj.conf (this is a non-existent KConfig option and it complains under 4.1)
Changed CONFIG_LV_Z_MEM_POOL_SIZE=8192 to CONFIG_LV_Z_MEM_POOL_SIZE=58368
I used the same value from the LVGL samples.
Picture of the display using Zephyr 3.7 & 4.0
Google Photos
Picture of the display using Zephyr 4.1
Google Photos
I can’t figure out how (or if) you can edit a post, so my question is does anybody know what it takes to make the example work under Zephyr 4.1?
Hello @dhylands
Welcome to the TechForum
I have reached out to our group to see if anyone might have a solution to this problem.
Hi @dhylands Zephyr is a moving target, please add a note on 4.1.x here: GitHub · Where software is built
This looks like a clock or timing issue. So something changed between 4.0/4.1
Regards,
Thanks - I created Trying to get LCD working with Zephyr 4.1.0 · Issue #13 · ShawnHymel/introduction-to-zephyr · GitHub
