Hi ,
I’m looking for surface mount fuse that has the writing “ TF “ on it .The current measured across was around 10 to 11 mA.
Hi ,
Hi @cebil.eapen
Welcome to the Community!
Please share the pictures with us, as they will help in identifying the part.
Hello cebil.eapen,
It appears that it may be part of the 468 series from Littelfuse. They do provide some specifications on the datasheet that may help identifying which current rating you would require.
@nick_13812 is on the right track with the Littelfuse 468 series.
From the 468 series datasheet:
So, it is the 0.500mA version:
Thank you , Nick.
Can I order them through DigiKey – is there a part no I can look up?
Kind Regards,
Cebil
Thank you , David.
Much appreciated.
Can I order them through Digikey – is there a part no. I can look up ?
Kind Regards,
Cebil
@David_1528 did link the part number at the bottom of the post, it would link to our web-page for that item to order.
Again, the part number is:
