Good Morning, for phoenix contact part 177293 or Digi-key part no 277-1935-ND.
Do I need to order anything else (contact or terminal)?
How are cables connected to this part?
Thanks you,
Mamdouh Tawadrous
Thanks you,
Mamdouh Tawadrous
Greetings,
Phoenix P/N 177293 is a self-contained terminal block, and does not require separate purchase of contacts for use. Connections to wires are made by means of a screw cage-type clamp, visible in the datasheet or the 360° photo available on the Digi-Key website.
Thanks rick_1976!
Regards,
Mamdouh Tawadrous
ASML
AS stated above, this is a complete connector terminal block for up to 3 wires for wire sizes 12 to 24awg using a screw connection to hold the wires in place. The Digi-Key web link click here
