Hi!
I’m looking to make up some 2-pin LEMO cables with these connectors FGG.0B.302.CLAD42Z
and I’m looking for an appropriate cable to connect two of such connectors together for 12/24V application.
Any advice would be much appreciated!
Hi!
Thank you for your inquiry.
We do not have any cables pre made for this one.
We do have the mating connectors listed in this link.
Selection of an appropriate cable material would be based primarily on number of conductors needed, conductor size supported by the connector contacts, and the cable jacket diameter accommodated by the connector’s strain relief mechanism.
Plugging those criteria plus the usual “in stock” etc. into the filters in the Multiple Conductor Cable family should leave you with this shorter list of options. Use preferences for color/available lengths/shielding/etc. to refine further.
Hey,
Thank you so much for your help. That is much appreciated, just what I was looking for! Very useful info considering there’s thousands of cables to choose from!
