2010-1051-ND inventory
When will you have a 100 of 2010-1051-ND?
Hello @drake,
Thank you for your post.
I do not see a lead time listed on our page.
For a lead time update on that you will need to request a quote.
Please go to this link and follow the instructions there.
Not that this meets your 100 piece requirements, but we do have 15 pcs of the PLS-045A-6VAI in stock at the moment.
It is physically identical and electrically, it can handle higher current and the same or higher voltages, so it should be suitable as a direct replacement.
Here’s a comparison of the two, including links to the respective datasheets.
David,
Can we add it to our PO REDACTED and ship together?
sales order number is REDACTED for your REDACTED.
Hi drake,
We’re just technical support here on the TechForum.
For that you need to contact orders@digikey.com or call 800-344-4539.
