223-1746-ND was out of stock, do you have a replacement part# recommend?
------Question for M5251-000005-03KPG Please Put your question below------
Hello andyl,
We have a couple that may work for you, but they are not a direct replacement.
223-1252-ND is the same vented gauge type, but has an operating pressure of 5000PSI, with a ±1% tolerance.
So this would need some refiguring, so the 4mA~20mA output, would relate to the correct pressure reading.
The other option is part number P51-3000-A-A-I12-20MA-000-000-ND, which is the same 3000PSI operating pressure, and 4mA~20mA output. However, this one is an Absolute pressure type, with a ±0.5% tolerance.
Please check the datasheets to help verify compatibility to your application.
