Didn’t see this one mentioned on the forum posts. Does DigiKey have a substitute? Thank you in advance.
Hello a45jones,
I did not find a perfect match. Looking for ones that can handle higher voltages or currents, I found one with the collector pin in the center. Click here for KSC1815YTACT-ND.
Please check the datasheet to verify compatibility to your application.
Thank you, David 1768. I’ll research and I’ll let you know what I find.
