380 vdc to 12 vdc 2w power supply
Hi
I need 12 VDC and 2 W power supply to power to a fiber converter. My supply is 380 VDC. I need it as small as possible to fit into my design. Can you recommend a component?
Hello Ole,
I found a couple items that will accept 380VDC, and output 12VDC.
1102-5403-ND
102-5580-ND
102-PSK-3D-12-DIN-ND
Please check the datasheets to verify compatibility to your application.
Hi Ole,
Couple other options along with David_1768
2725-PV15-27B12R3-ND | 2034-CQB75-300S12N-ND
A few more to throw on the list:
  • RAC05-12SK/277/W
    5W, 1.25" L x 1.05" W x 0.86" H supply, flying leads
  • RAC02E-12SK/277
    2W, 1.33" L x 0.87" W x 0.61" H supply, pc mount through-hole pins
  • PSK-3D-12
    3W, 1.00" L x 1.00" W x 0.69" H supply, pc mount through-hole pins
