I have a A126729-ND connector and would like to find the pins compatible. My goal is to attach a 120ohm resistor to this assembly.
Hi @gerardo1
Thank you for your inquiry.
The compatible terminals for this connector are from the Micro Quadlok series. You can find the applicable terminals and additional details at the following link:
Rectangular Connector Contacts | Connectors, Interconnects | DigiKey
Thank you! I will let you know if I need further assistance.
