Connector match
Do these pins go with this connector?
Pins: A1441-ND
Connector: A136615-ND
None of the datasheet for the connector are loading for me.
thanks.
Welcome to the DigiKey TechForum. I wasn’t able to verify from the manufacturer website that this contact and housing are compatible. If you going to use contact part A1441-ND you may want to look at DigiKey part A1458-ND for the associated connector housing. These two items are listed as compatible with eachother which is listed here .
thanks, that looks good.
