I’m looking for replacement pins for the A31933-ND connector. This is a D type 25 pin male.
Hi The pins are pre-loaded in to this type of connector. It is IDC ( insulation displacement connector) There in not a way to replace the pins in this type of connector . You would need the type that is just a housing that the crimp pins are sold separately, and crimped to a wire. That would be the type you can replace the contacts. Glenda
