Acer Chromebook 511 c736 usb c port help
Trying to find a replacement ports for acer chromebook 511 c736. My school has over 900 of them and I’ve already gotten very comfortable replacing C722’s, however the ports aren’t the same style of mounting. I have some pictures if any could help me locate a replacement.
Hello rpowell,
I did not see an exact match, but the closest items, that may work, are:
12401598E4#2ACT-ND
12401826E412ACT-ND
2092-KUSBX-SMT-CS-4-BK-TRCT-ND
2092-KUSBX-SMT-CS-4-BK-30TRCT-ND
Please check the datasheets and drawings to help verify compatibility to your application.
Unfortunately looks the board hole dimensions are not wide enough. Looks like they are about 12mm wide vs 8-9mm widths.
You may be able to bend the support pins, but I wish I had a better option.
Hi @rpowell , Here is a reference link of all similar parts, unfortunately there is no way to sort or filter by the width or other measurements.
Were you ever able to find this port? We have quite a few on deck as well, and I haven’t been able to locate the part stateside.
