Advantages of AGM Batteries Over Flooded Lead-Acid Batteries
AGM Batteries offer several key advantages that can enhance performance and convenience. However, it is crucial to use a charger specifically designed for AGM batteries. Modern automobiles are often equipped with a Battery Management System (BMS) that can handle AGM battery charging.
Similarly, Uninterruptible Power Supplies (UPS), which commonly use AGM batteries, are equipped with chargers specifically designed for AGM technology. Despite proper charging, UPS internal batteries may still need replacement, particularly if the unit is over five years old or has undergone multiple deep discharges. While a larger battery capacity generally leads to a longer lifespan—often allowing car batteries to last 10 years or more—car batteries typically experience fewer deep discharge cycles compared to UPS systems, making AGM batteries the preferred choice for UPS applications.
Construction & Characteristics
AGM batteries are a type of sealed lead-acid (SLA) battery but use a fiberglass mat soaked with electrolyte to absorb and contain the acid, making them spill-proof and highly resistant to vibration. This design not only ensures safety but also allows for flexible mounting options. While AGM batteries perform best when installed upright or in a stable position, they can be mounted in various orientations without compromising performance. This flexibility makes AGM batteries particularly valuable in automotive, emergency backup, and UPS systems, where reliability and space constraints are critical.
AGM batteries are also much less prone to terminal corrosion due to their sealed design. They also excel in high-discharge scenarios and handle moderate temperature fluctuations better than flooded lead-acid batteries. Their robust performance and minimal maintenance requirements make them a superior choice for many applications.
In contrast, flooded lead-acid batteries contain a liquid electrolyte that can spill if the battery is tipped over, requiring an upright installation. They also demand regular maintenance to check and replenish the electrolyte levels, which can be inconvenient and time-consuming. While flooded lead-acid batteries are often more affordable, they do not offer the spill-proof or maintenance-free advantages provided by AGM batteries.
Understanding these advantages can help you choose the right battery for your specific needs, enhancing both safety and efficiency. Please review the datasheet specifications of a battery to ensure compatibility with your application.
Applicable Part Numbers
3164-PS-640F1-ND
5260-PC1.2-12F1-CHP,2059-PC1.2-12F1-ND
2146-BP1.2-12-T1-CHP,522-1007-ND
5260-PC7-12F1-CHP,2059-PC7-12F1-ND
2059-PC4.5-6F1-ND
3164-PS-670F1-ND
5260-PC7.2-12F2-CHP,2059-PC7.2-12F2-ND
3164-PS-1220F1-ND
3164-PS-1250F1-ND
2146-HR6-12-T1-CHP,522-1032-ND
5260-PC9-12SF2-CHP,2059-PC9-12SF2-ND
3164-PS-6100F1-ND
3164-PS-1270F2-ND
3164-PS-1270F1-ND
522-1008-ND
842-1000-ND
2059-PC5-12F1-ND
5260-PC12-12F2-CHP,2059-PC12-12F2-ND
3164-PS-1290F2-ND
HR9-6-T2-ND
842-1002-ND
842-1001-ND
3164-PS-12120F2-ND
5260-PC18-12NB-CHP,2059-PC18-12NB-ND
3164-PS-12180F2-ND
522-1013-ND
522-1023-ND
BC18-12-B1-ND
522-1014-ND
3164-PS-12350NB3-ND
2059-PC33-12NB-ND
522-1016-ND
3164-PS-121000U-ND
2146-BP3-6-T1-CHP,522-1001-ND
3164-PS-612F1-ND
5260-PC5-12F2-CHP,2059-PC5-12F2-ND
2146-BP3-12-T1-CHP,522-1009-ND
5260-PC3.4-12F1-CHP,2059-PC3.4-12F1-ND
3164-PS-630F1-ND
2059-PC3.4-6F1-ND
2146-BP5-12-T1-CHP,522-1022-ND
522-1002-ND
3164-PS-1230F1-ND
3164-PS-6100F2-ND
2146-BP10-12-T2-CHP,522-1030-ND
2059-PC6-6F2-ND
522-1005-ND
522-1042-ND
2146-HR22-12-B1-CHP,522-1027-ND
522-1026-ND
842-1003-ND
2146-EB50-12-I2-CHP,522-1028-ND
2146-BP1.2-6-T1-CHP,522-1000-ND
3414-PS-640F1-ND
2717-BW645-ND
2717-BW1213-ND
2912-NP4.5-6-ND
2717-BW650SLANTERN-ND
2717-BWHR12-30WFR-ND
2717-BW1222-ND
2788-BG-612F1-ND
2717-BW1250F2-ND
2717-BW685-ND
2717-BW1250F1-ND
2788-BG-1212F1-ND
2788-BG-640F1-ND
3414-PS-1250F1-ND
2717-BW1234-ND
3414-PS-1223-ND
3414-PS-670F1-ND
2788-BG-610F1-ND
2788-BG-645F1-ND
2788-BG-621F1-ND
2717-BW6120F1-ND
3414-NP7-6-ND
3414-PS-1228-ND
3414-PS-1212F1-ND
2612-PC12-6XBF1-ND
2717-BW1280F1-ND
2717-BW1280F2-ND
2788-BG-1270F1-ND
3414-PS-1270F2-ND
3414-PS-1270F1-ND
2788-BGH-690F2-ND
2717-BWHR12-60WFR-ND
2788-BG-1229F1-ND
2912-NP7-12-ND
3414-PS-6100F1-ND
2912-NPX-25/250FR-ND
3414-PS-1290F2-ND
2717-BW1290NB-ND
2717-BW1290F2-ND
2612-PC12-6TFP-ND
2788-BG-1290F2-ND
3414-NP10-6-ND
2912-GT12080-ND
2912-NPX-L35/250FR-ND
2414-TPBAT12-9-ND,2303-TPBAT12-9-ND
2717-BW12120NB-ND
2717-BW12120F1-ND
3414-PS-12120F2-ND
2912-NP12-12-ND
2788-REPLACEMENTRPL-0922-ND
3414-0809-0012-ND
2717-BW12180F2-ND
2612-PC12-12NB-ND
2612-GA31462001-ND
2912-NP12-12FR-ND
2717-BW12180IT-ND
2717-BW12180-ND
2148-LC-X1220P-CHP,P231-ND
2717-BW12220NB-ND
2717-BW12220IT-ND
2912-NP18-12B-ND
3414-EVH12150-ND
3414-0810-0103-ND
3414-0810-0102-ND
3414-PS-12180NB-ND
2717-BWEVU1NB(GROUPU1)-ND
2717-BWEVU1IT(GROUPU1)-ND
2717-BW12350IT(GROUPU1)-ND
2717-BW12350NB(GROUPU1)-ND
2912-NPX-80RFR-ND
3414-PSH-12180FR-ND
2717-BW12260NB-ND
2717-BW12260IT-ND
2788-BG-12260NB-ND
3414-PDC-12200-ND
2612-PC22-12NB-ND
2788-BG-12350NB-ND
2612-PC20-12M-ND
2717-BW12500NB-ND
2788-BG-2412-ND
2912-NPX-100RFR-ND
3414-PS-12260F2-ND
2717-BW12550IT(GROUP22NF)-ND
2717-BW12550Z(GROUP22NF)-ND
2717-BWEV22Z(GROUP22NF)-ND
2717-BWEV22IT(GROUP22NF)18KGS-ND
2717-BWEV22IT(GROUP22NF)-ND
2788-BG-1224B-ND
2612-PC40-12NB-ND
2146-BP65-12-B5-CHP,522-1018-ND
2717-BWEV24Z(GROUP24)-ND
2717-BWEV24IT(GROUP24)-ND
2717-BW22000-ND
2912-NP38-12BFR-ND
2788-BG-12550NB-ND
2912-NPX-150RFR-ND
2717-BWEV34(GROUP34)-ND
2717-BW121000Z(GROUP27)-ND
2717-BW121000IT(GROUP27)-ND
2717-BW12750IT(GROUP24)-ND
2717-BW12750Z(GROUP24)-ND
2912-SWU210-12FR-ND
2717-BW121000DT(GROUP27)-ND
3414-PS-12400NB-ND
2717-BW121100IT(GROUP30H)-ND
2717-BW121100Z(GROUP30H)-ND
2612-PC75-12M-ND
2612-PC75-12NB-ND
2717-BW121100DT(GROUP30H)-ND
2717-BW23000-ND
2717-BWEVGC6-220A-ND
2788-BG-121000NB-ND
2717-BWEVGC8-170A-ND
4149-BAT412101104-ND
2912-NP65-12FR-ND
2717-BW62000(GROUP27)-ND
2612-PC200-6M-ND
2717-BWEV12-155A-ND
2717-BW-8D-ND
2912-NPY5-6-ND
2912-NPY7-6-ND
3414-PS-628F1-ND
2912-NPY4.5-12-ND
2912-NP7.5-12FR-ND
3414-PS-260-ND
3414-0819-0010-ND
2912-NPY12-12-250-ND
3414-NP7-12F1-ND
3414-NP7-12F2FR-ND
3414-NP5-12T-ND
3414-NP7-12F1FR-ND
2912-NPY18-12-ND
3414-PS-6200NB-ND
2912-NP24-12T250-ND
3414-NP12-12F2FR-ND
3414-NP18-12NBFR-ND
3414-NP18-12NB-ND
2612-PC26-12F2-ND
3414-PHR-12100-ND
2612-PC110-12MFR-ND
2414-TPBAT12-180-ND
2146-BP5-12-T2-CHP,522-1010-ND
2146-BP7-12-T2-CHP,522-1012-ND
522-1011-ND
3164-PS-12180NB2-ND
3164-PS-12550U-ND
2059-PC1.2-6F1-ND
3164-PS-1250F2-ND
2059-PC7-6F1-ND
522-BC7-12-T2-ND
2059-PC9-12SF1-ND
2146-EB20-12-B1-CHP,522-1031-ND
842-1008-ND
3164-PS-12260F2-ND
3164-PS-12350M6-ND
842-1004-ND
3164-PHR-12350M6FR-ND
3164-PHR-1236F2FR-ND
HR6-12-T2-ND
3164-PS-12260NB2-ND
522-1025-ND
522-1040-ND
3164-PHR-12200M6FR-ND
522-1041-ND
3164-PHR-12500M6FR-ND
2059-PC12-6F1-ND
2059-PC55-12NB-ND
2059-PCPL150-12FT-ND
2059-PCPL210-12FT-ND
3414-PS-612-ND
2717-BW445-ND
2717-BW634-ND
3414-PS-832F1-ND
2717-BW670-ND
2146-BC8-12-T2-CHP,522-BC8-12-T2-ND
3414-PS-1230-ND
3414-PS-1250F2-ND
2912-NP1.2-12-ND
2717-BW1270F2-ND
2717-BW1270F1-ND
3414-PSH-1255FR-ND
3414-PS-632F1-ND
2912-NP7-12/250FR-ND
3414-HR1224WF2F1-ND
2717-BW6140F2/F1-ND
5326-HR1234WF2-ND
2717-BW12120F2-ND
5326-HRL1234WF2FR-ND
2717-BW2470-ND
2717-BWHR12-105WFR-ND
2717-BW12140-F2-ND
3167-RBC45-PWH-ND
2283-A7966-ND
3167-APCRBC114-PWH-ND
3167-APCRBC154-PWH-ND
5326-GP12120F2-ND
3167-RBC17-PWH-ND
3414-PS-6360F2-ND
3167-APCRBC110-PWH-ND
3167-APCRBC161-PWH-ND
2912-NPX-80BFR-ND
3414-PS-12260NB-ND
2146-BP40-12-B2-CHP,522-1017-ND
2912-NP24-12BFR-ND
3167-RBC18-PWH-ND
2717-BW12500IT-ND
3414-PS-12280NB-ND
2612-PC26-12NB-ND
2912-NP38-12B-ND
2717-BW12750DT(GROUP24)-ND
3167-APCRBC141-PWH-ND
3167-RBC11-PWH-ND
3414-PS-12750U-ND
3167-RBC55-PWH-ND
2717-BW-4DNARROW-ND
2717-BW-4DAGM-ND
3167-APCRBC152-PWH-ND
2717-BWEV8D-330A-ND
3414-PS-630F1-ND
3414-NP1.2-12-ND
3414-PS-6120FP-ND
3414-NP5-12F1-ND
3414-NP2-12-ND
5326-GP1272F2-ND
3167-RBC2-PWH-ND
3167-RBC47-PWH-ND
3167-RBC35-PWH-ND
3414-NP12-12T-ND
3167-RBC4-PWH-ND
5326-GP12170B1B-ND
3167-APCRBC158-PWH-ND
3167-APCRBC162-PWH-ND
3167-APCRBC160-PWH-ND
5326-GP12400-ND
5326-GP12340-ND
2788-BG-12400NB-ND
3167-RBC22-PWH-ND
5326-GPL12520-ND
3167-RBC23-PWH-ND
2788-BG-12750NB-ND
3167-APCRBC155-PWH-ND
5326-GPL12800-ND
5326-PS-12750U-ND
5326-XTV121100-ND
522-1003-ND
522-1035-ND
522-1006-ND
522-1033RA-ND
3164-PHR-1290M6FR-ND
3164-PHR-12100M5FR-ND
522-1034RA-ND
522-BP40-12-I2-ND
2059-PCPL80-12HR-ND
2059-PCPL100-12FT-ND
2059-PCPL100-12HR-ND
BP1.0-6-T1-ND
BP4-6-T3-ND
BP5-6T2-ND
522-1004-ND
BP4-6-T1-ND
3414-PS-1220-ND
522-1036-ND
BP4.5-6-T1-ND
BP10-6-T1-ND
BP10-6-T3-ND
BP12-6-T3-ND
842-1005-ND
BP3-12-T3-ND
P679-ND
BP3.6-12-T1-ND
BP7.5-12-T2-FR-ND
522-1038-ND
BP5.5-12-RT-ND
HRC5.5-12-ND
NP4-12-ND
5326-HR1221WF2-ND
BC7-12-ND
522-1037-ND
BP12-12-T2-FR-ND
BC8-12-T1-ND
BP7-12-RT-ND
HR5.8-12-T1-ND
3414-PSH-1280F2FR-ND
5326-UPS12580F2-ND
SHR7-12-T2-ND
BP7.5-12-T1-ND
BP7.5-12-T2-ND
HRC1234W-T2-ND
NPX-25T-ND
HRC9-12-T2-ND
NP0.8-12-ND
EB12-12-ND
2788-BGH-12180NB-ND
522-1015-ND
BP17-12-B1-FR-ND
LC-P1220AP-ND
BP18-12-ND
LC-P1220P-ND
EVP20-12-B1-ND
LC-P1228AP-ND
LC-P1228P-ND
LC-P1224P-ND
3164-PHR-12150M6FR-ND
BC28-12-ND
BP33-6-B1-ND
BP26-12-B1-ND
EB24-12N-I1-ND
EP28-12-ND
NP18-12FR-ND
LC-P1238P-ND
BC35-12-ND
BP33-12H-B7-ND
BC42-12-ND
522-HR33-12FR-B1-ND
MPL55-12FRS-I2-ND
PC625-ND
BC75-12-ND
MPL80-12-ND
0769-6003-ND
MSB200FR-ND
MPL90-12-ND
MPL110-12H-B3-ND
EP100-12-ND
12HX400FR-ND
MPL135-12-I3-ND
MPL155-12-I3-ND
2946-787-878/001-3000-ND
2717-BWEV30-120IT-ND
P075-ND
P128-ND
P074-ND
P078-ND
P166-ND
P171-ND
P172-ND
P174-ND
P178-ND
P264-ND
P259-ND
P049-ND
P209-ND
P210-ND
P218-ND
P225-ND
P230-ND
P164-ND
P165-ND
P141-ND
BP10-4-T1-ND
BP7-6-T3-ND
522-1029-ND
BP13-6-T3-ND
BP4-12-T1-ND
BP4.5-12-T1-ND
BP17-12-T2-ND
BP26-12-T2-ND
MPL55-12S-B5-ND
EP7-12-T2-ND
EP12-12-T2-ND
EP17-12-B1-ND
EP26-12-B1-ND
EP33-12S-B7-ND
EP40-12-B2-ND
HR4-12-T1-ND
HR40-12S-B7-ND
HR50-12-B2-ND
EVP26-12-B1-ND
EVP35-12S-B7-ND
EVP44-12-B2-ND
BP4.5-12-RT-ND
BPL3.3-12-T1-ND
BPL7-12-T2-ND
BPL7.5-12-T2-ND
BPL12-12-T2-ND
BPL26-12-B1-ND
BPL28-12-B1-ND
522-1024-ND
P629-ND
842-1006-ND
842-1007-ND
842-1009-ND
842-1010-ND
842-1011-ND
0859-0020-ND
5606947-ND
5606946-ND
P682-ND
P683-ND
P684-ND
P680-ND
P681-ND
5606945-ND
522-BP120-12-I2-ND
BP90-12-ND
BPL110-12-ND
BPL65-12-ND
BPL80-12-ND
EP65-12-ND
EP80-12-ND
LC-P127R2P1-ND
UP-VW1228P1-ND
UP-VW1236P1-ND
UP-VWA1232P1-ND
LC-RA1215P-ND
LC-RA1215P1-ND
LC-XC1221AP-ND
LC-XC1238P-ND
P692-ND
P695-ND
LC-P067R2P1-ND
2059-PC1.3-6F1-ND
2059-PC1.3-12F1-ND
2303-TPBAT6-180-ND
2612-PC100-12NB-ND
2717-BW6120F2-ND
2717-BW613-ND
2717-BWHR12-36WFR-ND
2717-BW12100-SF2-ND
2788-BG-1270F2-ND
2788-BGH-1290F2-ND
2788-BGH-1255F2-ND
2788-BGH-1275F2-ND
2912-NP7-12/250-ND
2912-NP24-12B-ND
2912-NP18-12BFR-ND
2912-NP7-12FR-ND
2912-NP5-12-ND
2788-BG-12120F2-ND
3414-EVX12200-ND
3414-HR1227WF2FR-ND
3414-PS-1280F1-ND
3414-NP2.3-12-ND
3414-NP18-12RFR-ND
PS-640 F1
PC1.2-12F1
BP1.2-12-T1
PC7-12F1
PC4.5-6F1
PS-670 F1
PC7.2-12F2
PS-1220 F1
PS-1250 F1
HR6-12-T1
PC9-12SF2
PS-6100 F1
PS-1270 F2
PS-1270 F1
BP2.3-12-T1
0810-0004
PC5-12F1
PC12-12F2
PS-1290 F2
HR9-6-T2
0800-0004
0860-0004
PS-12120 F2
PC18-12NB
PS-12180 F2
BP12-12-T2
HR9-12-T2
BC18-12-B1
BP17-12-B1
PS-12350 NB3
PC33-12NB
BP33-12S-B7
PS-121000 U
BP3-6-T1
PS-612 F1
PC5-12F2
BP3-12-T1
PC3.4-12F1
PS-630 F1
PC3.4-6F1
BP5-12-T1
BP5-6-T1
PS-1230 F1
PS-6100 F2
BP10-12-T2
PC6-6F2
BP12-6-T1
HR5.8-12-T2
HR22-12-B1
BP20-12-B1
0850-0004
EB50-12-I2
BP1.2-6-T1
PS-640F1
BW 645
BW 1213
NP4.5-6
BW 650S LANTERN
BW HR 12-30W FR
BW 1222
BG-612F1
BW 1250 F2
BW 685
BW 1250 F1
BG-1212F1
BG-640F1
PS-1250F1
BW 1234
PS-1223
PS-670F1
BG-610F1
BG-645F1
BG-621F1
BW 6120 F1
NP7-6
PS-1228
PS-1212F1
PC12-6XBF1
BW 1280 F1
BW 1280 F2
BG-1270F1
PS-1270F2
PS-1270F1
BGH-690F2
BW HR 12-60W FR
BG-1229F1
NP7-12
PS-6100F1
NPX-25/250FR
PS-1290F2
BW 1290 NB
BW 1290 F2
PC12-6TFP
BG-1290F2
NP10-6
GT12080
NPX-L35/250FR
TPBAT12-9
BW 12120 NB
BW 12120 F1
PS-12120F2
NP12-12
REPLACEMENT RPL-0922
0809-0012
BW 12180 F2
PC12-12NB
GA31462001
NP12-12FR
BW 12180 IT
BW 12180
LC-X1220P
BW 12220 NB
BW 12220 IT
NP18-12B
EVH12150
0810-0103
0810-0102
PS-12180NB
BW EVU1 NB (GROUP U1)
BW EVU1 IT (GROUP U1)
BW 12350 IT (GROUP U1)
BW 12350 NB (GROUP U1)
NPX-80RFR
PSH-12180FR
BW 12260 NB
BW 12260 IT
BG-12260NB
PDC-12200
PC22-12NB
BG-12350NB
PC20-12M
BW 12500 NB
BG-2412
NPX-100RFR
PS-12260F2
BW 12550 IT (GROUP 22NF)
BW 12550 Z (GROUP 22NF)
BW EV22 Z (GROUP 22NF)
BW EV22 IT (GROUP 22NF) 18 KGS
BG-1224B
PC40-12NB
BP65-12-B5
BW EV24 Z (GROUP 24)
BW EV24 IT (GROUP 24)
BW 22000
NP38-12B FR
BG-12550NB
NPX-150RFR
BW EV34 (GROUP 34)
BW 121000 Z (GROUP 27)
BW 121000 IT (GROUP 27)
BW 12750 IT (GROUP 24)
BW 12750 Z (GROUP 24)
SWU210-12FR
BW 121000 DT (GROUP 27)
PS-12400NB
BW 121100 IT (GROUP 30H)
BW 121100 Z (GROUP 30H)
PC75-12M
PC75-12NB
BW 121100 DT (GROUP 30H)
BW 23000
BW EVGC6-220A
BG-121000NB
BW EVGC8-170A
BAT412101104
NP65-12FR
BW 62000 (GROUP 27)
PC200-6M
BW EV12-155A
BW -8D
NPY5-6
NPY7-6
PS-628F1
NPY4.5-12
NP7.5-12FR
PS-260
0819-0010
NPY12-12-250
NP7-12F1
NP7-12F2FR
NP5-12T
NP7-12F1FR
NPY18-12
PS-6200NB
NP24-12T250
NP12-12F2FR
NP18-12NBFR
NP18-12NB
PC26-12F2
PHR-12100
PC110-12M FR
TPBAT12-180
BP5-12-T2
BP7-12-T2
BP7-12-T1
PS-12180 NB2
PS-12550 U
PC1.2-6F1
PS-1250 F2
PC7-6F1
BC7-12-T2
PC9-12SF1
EB20-12-B1
0859-0010
PS-12260 F2
PS-12350 M6
0820-0004
PHR-12350 M6 FR
PHR-1236 F2 FR
HR6-12-T2
PS-12260 NB2
HR15-12-T2
HR33-12-B1
PHR-12200 M6 FR
MPL55-12S-I2
PHR-12500 M6 FR
PC12-6F1
PC55-12NB
PCPL150-12FT
PCPL210-12FT
PS-612
BW 445
BW 634
PS-832F1
BW 670
BC8-12-T2
PS-1230
PS-1250F2
NP1.2-12
BW 1270 F2
BW 1270 F1
PSH-1255FR
PS-632F1
NP7-12/250FR
HR1224WF2F1
BW 6140 F2/F1
HR 1234WF2
BW 12120 F2
HRL 1234WF2FR
BW 2470
BW HR12-105W FR
BW 12140- F2
RBC45-PWH
A7966
APCRBC114-PWH
APCRBC154-PWH
GP 12120F2
RBC17-PWH
PS-6360F2
APCRBC110-PWH
APCRBC161-PWH
NPX-80BFR
PS-12260NB
BP40-12-B2
NP24-12BFR
RBC18-PWH
BW 12500 IT
PS-12280NB
PC26-12NB
NP38-12B
BW 12750 DT (GROUP 24)
APCRBC141-PWH
RBC11-PWH
PS-12750U
RBC55-PWH
BW -4D NARROW
BW -4D AGM
APCRBC152-PWH
BW EV8D- 330A
PS-630F1
NP1.2-12
PS-6120FP
NP5-12F1
NP2-12
GP 1272F2
RBC2-PWH
RBC47-PWH
RBC35-PWH
NP12-12T
RBC4-PWH
GP 12170B1B
APCRBC158-PWH
APCRBC162-PWH
APCRBC160-PWH
GP 12400
GP 12340
BG-12400NB
RBC22-PWH
GPL12520
RBC23-PWH
BG-12750NB
APCRBC155-PWH
GPL12800
PS-12750 U
XTV 121100
BP7-6-T1
SHR3.6-12
BP12-6-T2
HRL5.5-12P-T2 RA
PHR-1290 M6 FR
PHR-12100 M5 FR
BP5-12-T2 RA
BP40-12-I2
PCPL80-12HR
PCPL100-12FT
PCPL100-12HR
BP1.0-6-T1
BP4-6-T3
BP5-6T2
BP7-6-T2
BP4-6-T1
PS-1220
SH4.5-12-T1
BP4.5-6-T1
BP10-6-T1
BP10-6-T3
BP12-6-T3
0810-2044
BP3-12-T3
LC-P0612P
BP3.6-12-T1
BP7.5-12-T2-FR
BC10-12-T2
BP5.5-12-RT
HRC5.5-12
NP4-12
HR 1221WF2
BC7-12
BC12-12
BP12-12-T2-FR
BC8-12-T1
BP7-12-RT
HR5.8-12-T1
PSH-1280F2FR
UPS 12580F2
SHR7-12-T2
BP7.5-12-T1
BP7.5-12-T2
HRC1234W-T2
NPX-25T
HRC9-12-T2
NP0.8-12
EB12-12
BGH-12180NB
BP28-12-B1
BP17-12-B1-FR
LC-P1220AP
BP18-12
LC-P1220P
EVP20-12-B1
LC-P1228AP
LC-P1228P
LC-P1224P
PHR-12150 M6 FR
BC28-12
BP33-6-B1
BP26-12-B1
EB24-12N-I1
EP28-12
NP18-12FR
LC-P1238P
BC35-12
BP33-12H-B7
BC42-12
HR33-12FR-B1
MPL55-12FRS-I2
PC625
BC75-12
MPL80-12
0769-6003
MSB200FR
MPL90-12
MPL110-12H-B3
EP100-12
12HX400FR
MPL135-12-I3
MPL155-12-I3
787-878/001-3000
BW EV30-120 IT
LC-R0612P
LC-R061R3P
LC-R067R2P
LC-R127R2P
LC-R063R4P
LC-R122R2P
LC-R123R4P
LC-RD1217P
LC-S122BU
LC-R121R3P
LC-R1233P
LC-X1228P
LC-X1265P
UP-VW1220P1
LC-R127R2P1
UP-VW1245P1
LC-RA1212P1
LC-R064R2P
LC-R0612P1
LC-R064R5P
BP10-4-T1
BP7-6-T3
BP13-6-WH
BP13-6-T3
BP4-12-T1
BP4.5-12-T1
BP17-12-T2
BP26-12-T2
MPL55-12S-B5
EP7-12-T2
EP12-12-T2
EP17-12-B1
EP26-12-B1
EP33-12S-B7
EP40-12-B2
HR4-12-T1
HR40-12S-B7
HR50-12-B2
EVP26-12-B1
EVP35-12S-B7
EVP44-12-B2
BP4.5-12-RT
BPL3.3-12-T1
BPL7-12-T2
BPL7.5-12-T2
BPL12-12-T2
BPL26-12-B1
BPL28-12-B1
MPL55-12-B5
LC-X1228AP
0819-0010
0809-0010
0819-0012
0809-0012
0859-0012
0859-0020
5606947
5606946
LC-P127R2P
LC-X1220AP
LC-P067R2P
LC-RA1212P
LC-R067R2P1
5606945
BP120-12-I2
BP90-12
BPL110-12
BPL65-12
BPL80-12
EP65-12
EP80-12
LC-P127R2P1
UP-VW1228P1
UP-VW1236P1
UP-VWA1232P1
LC-RA1215P
LC-RA1215P1
LC-XC1221AP
LC-XC1238P
LC-RN063R4P
LC-RN122R2P
LC-P067R2P1
PC1.3-6F1
PC1.3-12F1
TPBAT6-180
PC100-12NB
BW 6120 F2
BW 613
BW HR 12-36W FR
BW 12100-S F2
BG-1270F2
BGH-1290F2
BGH-1255F2
BGH-1275F2
NP7-12/250
NP24-12B
NP18-12BFR
NP7-12FR
NP5-12
BG-12120F2
EVX12200
HR1227WF2FR
PS-1280F1
NP2.3-12
NP18-12RFR
