Altech offers configurable switches which require two pieces to make a full switch -the switch body which is basically the actuator, and the contact block which does the actual switching. The two switch sizes offered are 22mm and 30mm and are all interchangeable as any body will work for any contact block within the same size.
Click below links for product offerings, notice the two different sizes:
Click here for Switch Bodies
Click here for Switch Contact Blocks
Summary
S1
S2
S1-10WB
S11
S2L
S1E
S2-01WB
S4
S3
S12
S1-20WB
S2-02WB
S1-S2-WB
C2
C1
S5
S6
S22
S21
S7
S8
600.5151.157
600.6101.022
600.6101.036
600.6351.025
600.6351.039
600.6451.040
600.6201.044
600.6201.058
600.5101.156
600.5301.158
600.5801.159
600.5851.160
2AML4
2AS2-1
2AF2
2AF3
2AMPP4
2AS2-3
2AP3
2AM8
P2AMPP4
2AS2E-3
2AS2E-1
2AK2-01
2AK2-04
2AK2-08
2AMLKB4
2ATL5LB F3F4-024
2ATL5LB F3P4-IO-110
2ALF3LB-024
2ALMPP4LB-110
2ALMPP4LB-024
AM2
2ATF3-F4-IO
2AMLS4
2AS2-4
2AK2-02
2AK2-09
2AMLKB4-3095
2AP2-NB
2AF3-NB
2AF4-NB
2AF2-NB
2AF0
2AF0RH
2AP2
2AF4
2AF6
2AF8
2AP1
2AF2RH
2AF6RH
2AF3RH
2AF4RH
2AF8RH
2AF1
2AF1RH
P2AF1
P2AF2
P2AF3
P2AF4
P2AF6
P2AF8
P2AP2
P2AP3
P2AP4
P2AP6
P2AP8
2AP6
2AP4
2AP8
AF1
AF2
AF3
AF4
AF6
AF8
AP1
AP2
AP3
AP4
AP6
AP8
2AF1WA0
2AF2DWA
2AF3-ON
2AF3-START
2AF4-OFF
2AF4-STOP
2AF6WA
2AF3WA
2AF2WA0
P2AF1WA0
P2AF1WA90
P2AF2WA0
P2AF2WA90
2AF6RR
2AF4RR
2AF3RR
2AP4-OFF
2AP4-STOP
AM1
AM3
AM4
AM6
AM8
2AM4
2AM2
2AM6
2AM3
2AM1
P2AM3
P2AM4
2AB2
2AB6
2AB3
2AB3-NB
2AB4
2AB1
2AB8
2AF2B
AB1
AB2
AB3
AB6
AB8
AB4
2ATF3P4-IO-NB
2AMPP4-NB
2AML4-NB
P2AMPP4-NB
P2AMPP4-NB-NM
2ATF1-P2
2ATF8-P2
2ATF8-P2-IO
2ATF2-F1
2ATF3-F4
2ATF8-F2
2ATF8-F2-IO
2ATF2-F1-IO
2ATF1-P2-IO
2ATF3P4
2ATF3P4-IO
2ATL5LB F3P4-IO-NB
2AMJ2
2AMJ6
2AMJ3
2AMJ4
2AMJ1
2AMJ8
2AMLS2
2AMLS6
2AMLS3
2AMLS1
2AMLS8
2AMLJ4
2AMLJ2
2AMLJ6
2AMLJ3
2AMLJ1
2AMLJ8
2AML6
2AML8
2AML3
2AML1
2AMPP6
2AMPP3
2AMPP1
2AMPP8
2AMPP4-MW
2AML2
2AMPP2
P2AML4
P2AMLS4
P2AMPP2
AML4
AML2
2AMPPJ2
2AMPPJ6
2AMPPJ3
2AMPPJ4
2AMPPJ1
2AMPPJ8
2ALF5-110
2ALF5-024
2ALF6-110
2ALF6-024
2ALF7-024
2ALF3-110
2ALF3-024
2ALF3-NB
2ALF4-110
2ALF4-024
2ALF1-024
2ALP5-110
2ALP6-110
2ALP3-110
2ALP4-110
2ALP5-024
2ALP6-024
2ALP4-024
2ALP3-024
2ALP1-024
P2AM4-1S2
ALF1-230
ALF3-230
ALF4-230
ALF5-230
ALF6-230
ALF7-230
ALF8-230
ALF1-024
ALF1-110
ALF3-024
ALF3-048
ALF3-110
ALF4-024
ALF4-048
ALF4-110
ALF5-024
ALF5-110
ALF6-024
ALF6-110
ALF7-024
ALF7-110
ALF8-024
ALF8-048
ALF8-110
2AML4T
2AS2-3-NB
P2AS2-1
P2AS2-3
2AS2-1-NB
2PSM401
P2AMLT4
P2AS2-4
P2AS2E-3
2AS2-4-NB
2ATL5 F3F4-110
2ATL5 F3F4-024
2AS2-2
AS2-2P
AS2-2PSR
AS2-3P
2ALF5LB-230D
2ALF5LB-230
2ALF5LB-110
2ALF5LB-012
2ALF5LB-024
2ALF5LB-048
2ALF4LB-110
2ALF4LB-012
2ALF4LB-230
2ALF4LB-230D
2ALF4LB-024
2ALF4LB-048
2ALF8LB-110
2ALF8LB-012
2ALF8LB-024
2ALF8LB-230
2ALP5LB-110
2ALP5LB-230
2ALP5LB-024
2ALP4LB-110
2ALP4LB-230
2ALP4LB-024
2ALP8LB-110
2ALP8LB-024
2ALP4LB-012
2ALP4LB-048
P2ALF4LB-024
P2ALF5LB-024
2AS2-5
2AS2-6
2AS2E-2
2AK2-02-NB
2AS2E-5
2AS2E-4
2AS2E-6
2AK2-06-NB
2AK2-15-NB
2AK2-14-NB
2AK2-07-NB
2AK2-11-NB
2AMLKB4-NB
2AS4-4
2AS4-1
2AS4-3
AMKB2
AMKB4
AK2-2PB
AK2-2PI
AK2-2PO
AK2-2PO-KD
AK2-2POSR
2AK2-02-3095
2AK2-03-3095
2AK2-03-458
2AK2-03
2AK2-01-458
P2AK2-02
P2AK2-04
ALFR4L-110
ALFR5L-110
P2ATL5LB F3F4-230
AMLKB4
AMLKB2
AK2-3PB
AK2-3PC
AK2-3PC-KD
AK2-3PC-KD1
AK2-3PC-KD2
AK2-3PC-KD3
2AK2-05
2AK2-06
2AK2-07
2AK2-11
2AK2-13
2AK2-10
2AK2-12
2AK2-15
2AK2-14
2AMLKB6
2AMLKB3
2AMLKB1
2AMLKB8
2AMLKB2
P2AK2-06
P2AK2-07
P2AK2-08
P2AMLKB2
P2AMLKB4
2PSTF3P4-11
2ATL5LB F3P4-110
2ATL5LB F3P4-012
2ATL5LB F3P4-230
2ATL5LB F3P4-024
2ATL5LB F3P4-048
2ATL5LB F3F4-110
2ATL5LB F3F4-230
2ATL5LB F3F4-048
ALF4LB-024
ALF4LB-048
ALF4LB-110
ALF4LB-230
ALF5LB-012
ALF5LB-024
ALF5LB-110
ALF5LB-230
ALF8LB-024
ALF8LB-110
ALF8LB-230
2ATL5LB F3P4-IO-012
2ATL5LB F3P4-IO-230
2ATL5LB F3P4-IO-024
2ATL5LB F3P4-IO-048
2ATL5LB F3F4-IO-110
2ATL5LB F3F4-IO-012
2ATL5LB F3F4-IO-230
2ATL5LB F3F4-IO-024
2ATL5LB F3F4-IO-048
2ATL5LB F2F1-IO-110
2ATL5LB F2F1-IO-012
2ATL5LB F2F1-IO-230
2ATL5LB F2F1-IO-024
2ATL5LB F2F1-IO-048
2ATL5LB F3F4-012
P2AMPPT4
2ALF6LB-110
2ALF6LB-012
2ALF6LB-230
2ALF6LB-230D
2ALF6LB-024
2ALF6LB-048
2ALF3LB-110
2ALF3LB-012
2ALF3-012
2ALF3LB-230
2ALF3LB-048
2ALP6LB-110
2ALP6LB-230
2ALP6LB-024
2ALP3LB-110
2ALP3LB-230
2ALP3LB-012
2ALP3LB-024
ALF3LB-024
ALF3LB-048
ALF3LB-110
ALF3LB-230
ALF6LB-024
ALF6LB-110
ALF6LB-230
P2ALF3LB-012
P2ALF3LB-024
2ALMPP4-110
2ALMPP4-024
2PSS220-2P
2ASL6-1-110
2ASL6-1-024
2ASL3-1-110
2ASL4-1-110
2ASL4-1-024
2ASL5-1-110
2ASL5-1-024
2ASL3-1-230
2ASL3-1-024
2PSS201-2P
2ASL5-3-110
2ASL5-3-024
2ASL6-3-110
2ASL6-3-024
2ASL3-3-110
2ASL3-3-024
2ASL4-3-110
2ASL4-3-024
2ASL5-4-110
2ASL5-4-024
2ASL6-4-110
2ASL6-4-024
2ASL3-4-110
2ASL3-4-230
2ASL3-4-024
2ASL4-4-110
2ASL4-4-024
2ASL5LB-1-012
2ASL4LB-1-110
2ASL4LB-1-012
2ASL4LB-1-024
2ASL4LB-1-048
2ASL8LB-1-110
2ASL8LB-1-012
2ASL8LB-1-024
2ASL8LB-2-024
2ASL5LB-1-110
2ASL5LB-1-230
2ASL5LB-1-024
2ASL4LB-1-230
2ASL8LB-1-230
2ASL5LB-5-110
2ASL5LB-5-024
2ASL4LB-5-024
2ASL5LB-3-110
2ASL5LB-3-230
2ASL5LB-3-024
2ASL4LB-3-110
2ASL4LB-3-230
2ASL4LB-3-024
2ASL8LB-3-110
2ASL8LB-3-230
2ASL8LB-3-024
2ASL5LB-4-110
2ASL5LB-4-230
2ASL5LB-4-024
2ASL4LB-4-110
2ASL4LB-4-230
2ASL4LB-4-024
2ASL8LB-4-110
2ASL8LB-4-230
2ASL8LB-4-024
2AMLKB4-A01
2AMLKB4-A02
2AMLKB4-A03
2AMLKB4-A04
2AMLKB4-A05
2AMLKB4-A06
2AMLKB4-A07
2AMLKB4-A08
2ALF7LB-110
2ALF7LB-012
2ALF7LB-230
2ALF7LB-230D
2ALF7LB-024
2ALF7LB-048
2ALF1LB-110
2ALF1LB-012
2ALF1LB-024
2ALM5LB-110
2ALM5LB-012
2ALM5LB-230
2ALM5LB-024
2ALM5LB-048
2ALM1LB-110
2ALM1LB-012
2ALM1LB-230
2ALM1LB-024
2ALM1LB-048
2ALM8LB-110
2ALM8LB-012
2ALM8LB-230
2ALM8LB-024
2ALM8LB-048
2ALM4LB-110
2ALM4LB-012
2ALM4LB-230
2ALM4LB-024
2ALM4LB-048
2ALMPP5LB-110
2ALMPP8LB-110
2ALMPP5LB-012
2ALMPP8LB-012
2ALMPP4LB-012
2ALMPP4LB-230
2ALMPP5LB-230
2ALMPP8LB-230
2ALMPP5LB-024
2ALMPP8LB-024
2ALMPP5LB-048
2ALMPP8LB-048
2ALMPP4LB-048
2ALP1LB-110
2ALP1LB-012
44-200-2S2
44-200
44-201
PBD
PBD-P
8100-2400
2AK2-02-KD1
2AK2-02-KD2
2ALP1LB-024
2ALP1LB-230
ALF1LB-024
ALF1LB-110
ALF1LB-230
ALF7LB-024
ALF7LB-048
ALF7LB-110
ALF7LB-230
P2PSK220-3PSR
2ASL6LB-1-110
2ASL6LB-1-024
2ASL3LB-1-110
2ASL6LB-2-024
2ASL3LB-2-110
2ASL3LB-2-230
2ASL6LB-1-230
2ASL3LB-1-012
2ASL3LB-1-230
2ASL3LB-1-024
2ASL3LB-1-048
2ASL3LB-3-012
2ASL6LB-6-024
2ASL3LB-6-110
2ASL3LB-6-024
2ASL3LB-5-024
2ASL6LB-3-110
2ASL6LB-3-230
2ASL6LB-3-024
2ASL3LB-3-110
2ASL3LB-3-230
2ASL3LB-3-024
2ASL6LB-4-110
2ASL6LB-4-230
2ASL6LB-4-024
2ASL3LB-4-110
2ASL3LB-4-230
2ASL3LB-4-024
2ASL3LB-5-110
2ALM3LB-110
2ALM3LB-012
2ALM3LB-230
2ALM3LB-024
2ALM3LB-048
ALMPP4LB-024
2ALP7LB-110
AK2-2PO-KD1
AK2-2PO-KD2
AK2-2PO-KD3
AK2-2PO-KD4
AK2-2PO-KD5
2PSLM4LB-024-01
44.9R-1S6
2ALM6LB-110
2ALM6LB-012
2ALM6LB-230
2ALM6LB-024
2ALM6LB-048
2ALMPP3LB-110
2ALMPP6LB-110
2ALMPP3LB-012
2ALMPP6LB-012
2ALMPP3LB-230
2ALMPP6LB-230
2ALMPP3LB-024
2ALMPP3LB-048
2ALMPP6LB-048
44.5R-2S6
44-200-T
2ASL7LB-1-110
2ASL7LB-1-230
2ASL7LB-1-024
2ASL1LB-1-110
2ASL1LB-1-012
2ASL1LB-1-024
2ASL7LB-2-024
2ASL1LB-2-024
2ASL1LB-4-024
2ASL7LB-3-024
2ASL1LB-3-012
2ASL1LB-3-024
2ASL7LB-6-024
2ASL1LB-6-024
2ASL1LB-4-110
2ASL1LB-5-110
2ALM7LB-110
2ALM7LB-012
2ALM7LB-230
2ALM7LB-024
2ALM7LB-048
2ALMPP1LB-110
2ALMPP7LB-110
2ALMPP1LB-012
2ALMPP7LB-012
2ALMPP1LB-230
2ALMPP7LB-230
2ALMPP1LB-024
2ALMPP1LB-048
2ALMPP7LB-048
44-200-S
