The 3365/50 300(3M157806-100-ND) is no longer available from DigiKey. For an alternative you can use the following. This is the same cable it just comes from the manufacturer in a different quantity.
| MFR PART # | 3365/50 100 |
| DIGIKEY PART # | 3M157852-100-ND |
| MANUFACTURER | 3M |
| DESCRIPTION | Flat Ribbon Cable Gray 50 Conductors 0.050" (1.27mm) Flat Cable 100.0’ (30.48m) |
