The GM1235PFV2-8.GN fan from Sunon Fans has been rendered obsolete. For a similar alternative take a look at MF35101V2-1000U-A99 below. Please review the datasheets to ensure the alternative will work for your application.
| MFR PART # | MF35101V2-1000U-A99 |
| DIGIKEY PART # | 259-2067-ND |
| MANUFACTURER | Sunon Fans |
| DESCRIPTION | Fan Tubeaxial 12VDC Square - 35mm L x 35mm H Vapo-Bearing™ 6.5 CFM (0.182m³/min) 2 Wire Leads |
